safcII/vafcII
Old Jan 23, 2006 | 08:02 AM
  #41
Puppetmaster's Avatar
Originally Posted by Deckdout2
Finally, some pics regarding Fuel controllers instead of......how to this, and how to that. My eyes can't steer away from that Navi man.
I liked the way you installed it... just that I wouldn't want mine sitting up top like that. I'm gonna have to think of something different when the time comes. I may just cover the damn trip computer since I never look at it anyways.
Old Jan 23, 2006 | 08:51 AM
  #42
HotshotVQ35's Avatar
i like it installed there, thats where mine will go once i install it. what did you guys use for your initial setup?
Old Jan 23, 2006 | 08:52 AM
  #43
Steven88's thread in the All Motor forum has info on that.
Old Jan 23, 2006 | 08:58 AM
  #44
Deckdout2's Avatar
Play with my balls
I also have 18% tint registered on the meter. Very difficult to see in. If I didn't have that, I'd have different thoughts about it.
Old Jan 23, 2006 | 11:37 AM
  #45
Hoooper
excellent, im thinkin about getting one and tuning it by the a/f i got on the dyno before and then going back once ive got more money to do a dyno tune
Old Jan 23, 2006 | 11:42 AM
  #46
NmexMAX's Avatar
dot dot dot ...
... this statement makes no sense.
Old Jan 23, 2006 | 11:47 AM
  #47
Hoooper
I carefully dremeled out a slot on the top of the vents is why you can't see any creases in the dash where the wire goes into it. Dremeled a little and tested, if I needed more room I took out a little more material. It fits snug and perfect. I also ran the wire via the center of both vents to have a cleaner install.
did you pop the dash trim off or did you just somehow feed the wire through there until it came out on the bottom?
Old Jan 23, 2006 | 11:59 AM
  #48
Deckdout2's Avatar
Play with my balls
The vents were removed to feed the wire through and mount the unit. It's best to do it that way or else there is no way for you to get behind there and feed it through.
Old Jan 23, 2006 | 12:12 PM
  #49
Hoooper
i might pm you about that once i get mine, hopefully i can get more info bout it. i like your install cause its real clean and looks good, was thinkin bout bein a copycat if that arright.
Old Jan 23, 2006 | 12:19 PM
  #50
Deckdout2's Avatar
Play with my balls
No worries, just shoot me a pm when you are ready. I can do this for you but you'll have to ship me your vents and unit and I return the shipping. Let me know.
Old Jan 23, 2006 | 02:37 PM
  #51
Yeah, I don't have tint and probably won't be getting any for a while. Anyways, I had an idea for an alternative placement. You have email.
Old Jan 23, 2006 | 02:50 PM
  #52
Deckdout2's Avatar
Play with my balls
If you sent it to my Uvest.com email, I'll get it in the morning. Haydn has his mounted in his gauge cluster, just double sided tape I believe.
Old Jan 23, 2006 | 02:58 PM
  #53
OOmaxSE's Avatar
Another place someone put it was in the sunglass casing near the sunroof controls. That's pretty serious but could get annoying when trying to read.
Old Jan 23, 2006 | 03:01 PM
  #54
NmexMAX's Avatar
dot dot dot ...
VAFC wont reach that far, different sub harness.
  #55
The S-AFC II wiring will reach there, but not the V-AFC II. You could extend the wires, but IMO, its more trouble than its worth.
Old Jan 23, 2006 | 03:03 PM
  #56
Deckdout2's Avatar
Play with my balls
You can extend the wires of course, but yes.....straight out of the box, it will not reach.
OOmaxSE - SAFC II will reach out of the box, with no modifications to harness.
  #57
Deckdout2's Avatar
Play with my balls
Quit beating me to posts dammit.
Old Jan 23, 2006 | 03:07 PM
  #58
It wasn't just me who beat you either...
Old Jan 23, 2006 | 03:08 PM
  #59
NmexMAX's Avatar
dot dot dot ...
I knew someone would be on it so I typed a very quick, yet sublte (forgot to mention SAFC being able to reach) message...
Old Jan 23, 2006 | 07:04 PM
  #60
Hoooper
sooo, judging by the a/f numbers, would there be any point in me getting a vafc2? if it will just get me a little power id say so, so do you guys think that i could pick up a lil power from it?
Old Jan 23, 2006 | 07:06 PM
  #61
NmexMAX's Avatar
dot dot dot ...
Where's your a/f?
Old Jan 23, 2006 | 07:10 PM
  #62
Hoooper
kinda small, click and much bigger...i think
Old Jan 23, 2006 | 07:13 PM
  #63
Hoooper
its got the hp and tq on there too, but i bet you can figure out which one's the a/f
Old Jan 23, 2006 | 07:15 PM
  #64
NmexMAX's Avatar
dot dot dot ...
You wont know unless you hook it up, tune and see a difference.
I would if I were you. Your #'s look like mine, except mine being a slight bit leaner.
Old Jan 23, 2006 | 07:54 PM
  #65
Hoooper
arright thx. will do soon, just gotta somehow convince the parents it will help the engine run better and get me better gas mileage...hmm
Old Jan 23, 2006 | 09:21 PM
  #66
Deckdout2's Avatar
Play with my balls
ya, that's what i had to convince the significant other with.
Old Jan 23, 2006 | 09:51 PM
  #67
Hoooper
always a tough fight, but enough bs will always get you the win...
Old Jan 24, 2006 | 05:38 AM
  #68
Deckdout2's Avatar
Play with my balls
I don't even try anymore, she can read straight through me.
Old Jan 24, 2006 | 07:07 AM
  #69
steven88's Avatar
Need A Light?
are you guys just being sarcastic?
cuz from what i've read, the AFC does not modify close loop...aka, it has nothing to do with fuel economy...those are up to the o2 sensors...
Old Jan 24, 2006 | 07:43 AM
  #70
Hoooper
were sayin that to convince other people that it is a good buy, the fuel economy thing is a good sell.
Old Jan 24, 2006 | 08:22 AM
  #71
You're right... it works on % throttle and won't work for > 40% throttle AND > 3k rpms (both conditions necessary for closed loop) because the ECU is in self-learn.
But if you're running rich up top and use the AFC to pull fuel to level out the AF, wouldn't that help fuel economy? I'm still learning here...
Old Jan 24, 2006 | 09:42 AM
  #72
steven88's Avatar
Need A Light?
Thats true, your leaning out the mixture....but I mean, your going WOT and running 5k+ RPMs...lots of fuel is being consumed even if you were running lean like Nmex...gas mileage is crap on the vq35s...I never ever broke 20mpg all city...man, when I think about it, I don't even think I broke 18mpg all city either...it's 17 or less ALL the time
Old Jan 24, 2006 | 11:04 AM
  #73
Deckdout2's Avatar
Play with my balls
Lay off the gas mang
Old Jan 24, 2006 | 05:56 PM
  #74
FTW
Old Jan 24, 2006 | 06:12 PM
  #75
Hoooper
lol, yeh my dad got 26 when he was drivin my max, i get about 18-19 and thats with running the quarter 4-7 times a tank (at the track, relax).
Old Jan 24, 2006 | 06:15 PM
  #76
NmexMAX's Avatar
dot dot dot ...
Let's hopefully not turn this into a gas mileage thread
Old Jan 24, 2006 | 10:12 PM
  #77
Hoooper
no, just a short term situation.
Old Jan 25, 2006 | 04:03 AM
  #78
let it end now.
