footwell lights
Old Jan 21, 2006 | 03:20 PM
Y2k2maxse's Avatar
footwell lights
i just installed footwell lights under the dashboard on both sides. anyone know a good thing to hook them up to so that they will come on when the car is stopped and or when the doors are opened? something fairly simple to wire up. i used to have a neon hooked up to the coin tray light so it would only come on when the lights are on but i dont want these lights on while driving. any ideas?
Old Jan 21, 2006 | 03:22 PM
MaxRain's Avatar
Try taping into the lighter for power so when the car is on the lights will be too
Old Jan 21, 2006 | 03:23 PM
Y2k2maxse's Avatar
but i want the lights to be off when i start to move or when the doors close.
Old Jan 21, 2006 | 03:26 PM
DJ2Max's Avatar
try tapping it to the courtesy lights onthe door. I think thats how they do it for the glowing door sills.
Old Jan 21, 2006 | 03:28 PM
MaxRain's Avatar
Yeah i think that this will be better
Old Jan 21, 2006 | 03:54 PM
Y2k2maxse's Avatar
i thought of that...but how do i get wires into the door? that may be a pain unless i wanna rig it, this car i wanna do stuff RIGHT lol can i get to the courtsey light wire anywhere else but next to the light itself?
Old Jan 21, 2006 | 04:04 PM
OHH NOES's Avatar
6spd Swapped
The wires from the door come in right behind the fuse box near the steering wheel. The only thing you have to do is find the wire color from the back of the light and find it from where it comes into the cabin and tap it. I also *think* the door lights are ground switched, so you can connect the lights directly to a power source using a fuse that would be suitable for the light, and tap the ground wire of the door lights, but Im not positive about them being ground switched.
Old Jan 21, 2006 | 05:02 PM
Y2k2maxse's Avatar
ok im kinda dumb when it comes to wiring. so ur saying hook up the positive footwell light wire to the positive courtsey light wire? and same for negitave or what?
Old Jan 22, 2006 | 05:14 AM
djsoniq's Avatar
Old Jan 22, 2006 | 06:57 AM
Jay_Alix's Avatar
They go through the rear door switch L/R to ground, and through the SECU then to the front door switch ground.
Old Jan 22, 2006 | 07:10 AM
Y2k2maxse's Avatar
ok lol still noone answered my question. do i hook up the footwell wires - and + to the courtsey lights - and +? or just the ground and the + to a switched power source?
Old Jan 22, 2006 | 07:32 AM
bugbite77's Avatar
you are makeing this way too complicated, just hook the lights up to a switch so you can have them on and off when you want them.
Old Jan 22, 2006 | 09:20 AM
JaKillz2's Avatar
Like DJ2max said, this would be similar to the anniversary door sills. You would need to tap into the courtesy light and "to do so there are positive and negative contacts in the rear of the assembly. You will need additional 24AWG wiring to reach the rear of that assembly so choice wisely." -Maxima.org instructional. As far as how to get it there which I understand is the real question at this point, I would somehow use the stock harness/gromet at the hinges of the door, other than that, I'm stumped as to do it any better. Lets see some pics of the final. Good luck
Old Jan 22, 2006 | 05:21 PM
Y2k2maxse's Avatar
ill do that soon and no, its not too complicated. nothing is to complicated, im determined to have things done right, would you want to have to flip a switch to turn on ur lights everytime? no so ill wire this up the RIGHT way in a few days ill repost and post pics. Thanks for your help everyone.
Old Jan 22, 2006 | 05:47 PM
BRINKLEY's Avatar
where did you get the lights from? I've been wanting to do this too.
fastcarny
Oct 6, 2015 10:42 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
