"Trip" button on steering wheel not working after installing stereo
Old Jan 25, 2006 | 05:45 AM
gold007eye's Avatar
New to the Maxi world...
Has anyone else run into the problem of the "TRIP" button on the left side of the steering wheel not working once you take the stock radio out? I installed a Jensen V9510TS over the weekend and everything works great.
I know the radio control buttons on the steering wheel won't work. Anyone know how I can get the Trip button to work though? Right now it just displays the outside Temp, and I can't get to the MPG, DTE, etc... Please Help!
Old Jan 25, 2006 | 05:47 AM
SgtSchulze's Avatar
Burn Dust. Eat my rubber.
You need to ground a wire from the stock harness. Look around for the how-to etc....
Old Jan 25, 2006 | 05:49 AM
gold007eye's Avatar
I have looked through all the How-To's but nothing about that. I looked before I posted, that's what I had used to find out how to take console, etc apart.
Old Jan 25, 2006 | 05:54 AM
SgtSchulze's Avatar
Found it......
Originally Posted by DaBoxSE
There is a connector that was connected to the back of the stock radio. If you look at the wires that are on it, you should find a brown wire. You need to ground this wire. What you should do is strip back the wire casing (don't cut the wire in case you want to reconnect the stock radio). Wrap the exposed wire to one of the screws that holds the bottom of the radio bracket in the dash. Make sure its tight and your info computer should work as normal.
Old Jan 25, 2006 | 06:02 AM
gold007eye's Avatar
Sweet Thanks. What did you do to find it? I was using the Yahoo Search for the forum cause it said I didn't have access to use "search" button at the top of the forum.
This is exactly what I was looking for.
Old Jan 25, 2006 | 06:19 AM
Deckdout2's Avatar
Play with my balls
pac-swi is your friend.
Old Jan 25, 2006 | 06:24 AM
gold007eye's Avatar
Would I use PAC-SWi or SWx for 2k3 Maxi?
Old Jan 25, 2006 | 06:34 AM
SEmy2K2go's Avatar
Go BUCKS!!!
He donated.
Old Jan 25, 2006 | 06:38 AM
gold007eye's Avatar
So if I donate I will be able to use the search function? How do I give a donation and how much do I have to give?
Old Jan 25, 2006 | 06:47 AM
TXT-1's Avatar
http://forums.maxima.org/payments.php
Do as I say, not as I do.
Old Jan 25, 2006 | 06:54 AM
gold007eye's Avatar
ok.. so I went and have now donated
Old Jan 25, 2006 | 09:40 AM
boondoxmax's Avatar
Donating is goodddd
Old Jan 25, 2006 | 11:26 AM
burnurass's Avatar
on a slightly similar topic..i just got the Eclipse AVN-5435 and the PAC SWI-ECL (the steeringwheel controller for the eclipse headunits). It works BEAUTIFULLY....I would recommend this set up. You dont even have to ground the trip computer wire...you just connected it to the SWI-ECL. GOOD job DON & Don JR.
Old Jan 25, 2006 | 11:34 AM
gold007eye's Avatar
Anyone know which PAC SWI version I should get for the Jensen VM-9510TS?
Old Jan 25, 2006 | 02:44 PM
Talyan03's Avatar
SWI-X i think
Old Jan 26, 2006 | 05:10 AM
gold007eye's Avatar
Thanks Taylan
Old Jan 26, 2006 | 06:48 AM
PoLo's Avatar
2-Wheelin it...
but wait, your'e question is for getting volume controls again, or JUST to get the trip button functioning. if it's just for the TRIP button to work, then you just need to strip that brown wire.
also, watch which wire. it's a brown with white stripe, but there are 2. one is for your left driver side speaker and much thicker. the thin thin one is for the trip monitor. just make sure that's grounded and trip functions work again
Old Jan 26, 2006 | 08:25 AM
gold007eye's Avatar
Yes it it was originally for JUST the trip wire as I can live w/out the steering wheel controls for now Thanks for the nfo. Now I just have to tear the dash back apart ughh.. I wish I had known before I put everything back together.. hehe.
Old Jan 26, 2006 | 05:59 PM
Cleck02's Avatar
ok I have read on how to get the trip function to work again. Does this include cycling through the temp, mpg etc....?
Old Jan 26, 2006 | 09:43 PM
PoLo's Avatar
2-Wheelin it...
yes yes....
Old Jan 27, 2006 | 02:13 PM
Cleck02's Avatar
Thanks Guys
MikesChevelle
Nov 23, 2024 11:17 AM
trasmadean
Feb 1, 2017 08:20 PM
jhontelj
Aug 17, 2015 04:07 AM
Flores94
Aug 13, 2015 01:17 PM
MikesChevelle
Aug 6, 2015 11:36 AM
