Stillen rear sway bar write up.
Old Feb 3, 2006 | 04:37 PM
Battle Max's Avatar
To make a long story short. Bought a sway bar used no instructions need to install it. someone help.
on a side note: dont flame i searched for about 20 minutes and got nothing but dead links etc.
Thanks everyone.
Old Feb 3, 2006 | 07:06 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
here you go..
http://vqpower.tripod.com/rsb.htm
Old Feb 3, 2006 | 07:48 PM
bvenvert's Avatar
I bought a used Stillen Rear Sway bar and used the instruction that are referenced above, but if you have the Y2K3 Maxima, like mine, you will probably have to remove the rear brake line bracket on each swingarm. It's no big deal, just two bolts on each side and remove the bracket. Just remember to thread the brake line, back through the top of the Stillen bracket on each side before you tighten down the bolts. The Stillen brackets are designed to go over the intergrated brake line bracket that they used on the 5th gen prior to the o3 model. Once you get past the Stillen bracket on each side, I just zip tied the brake line to the emergency brake cable.
It's pretty easy once you see the instructions. Should only take about an hour or so. You'll like the difference in the handling. I thought the RSB made a big difference when cornering.
Old Feb 3, 2006 | 08:17 PM
Battle Max's Avatar
Originally Posted by Lontar1
That was the link i was looking for and couldnt find. THANKS!!!!
Old Feb 3, 2006 | 08:30 PM
CCS2k1Max's Avatar
Here's another good one. http://www.greghome.com/Greg's%20Gar...StillenRSB.htm
ef9
Aug 27, 2015 07:21 AM
seesole
Aug 26, 2015 11:22 AM
Dasmith
Aug 25, 2015 10:15 PM
Maxboy23
Aug 20, 2015 09:33 AM
MaxStock
Aug 14, 2015 10:03 PM
