stock intake sensor
Old Jun 9, 2001 | 10:10 PM
flipmode_cali's Avatar
i was a maxima day and seen a few maximas that removed there stock intake scoop ive been trying to remove mine but i cant get the back sensor off to remove it all the way the and if its removed do you leave both sensors hooked up please help me out i hate this freakin thing
Old Jun 9, 2001 | 10:21 PM
i was at maxima day my car says zero tolerance on it it looks totally different than the car you see know
Old Jun 9, 2001 | 10:26 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Hi! I'm sure you remember me at Maxima Day. Which sensor are you taking about? Is it the boost sensor? I zip-tied it to another hose. Could you show me some pictures?
BTW, nice car!
Old Jun 9, 2001 | 10:46 PM
BTW, nice car!
im not sure which one it is but there is one on top and there is another one thats that is in the middle and is connected from directly to the plastic and part of it is inside the outlet part of the whole scoop thing. the engine bay and those groundcontrols are tight how is your ride though
Old Jun 9, 2001 | 10:59 PM
Y2KevSE's Avatar
One is the boost sensor (black thing on the outside) and I believe the other one stuck inside the scoop is the temperature sensor. You can take both of them off and zip-tie them to something.
Thanks! The GC's are stiff but I'll take the handling over ride quality anyday. BTW, I didn't catch you name.
Old Jun 9, 2001 | 11:21 PM
travis
Old Jun 9, 2001 | 11:25 PM
Y2KevSE's Avatar
Thanks.
Old Jun 10, 2001 | 08:41 AM
i understand that they need to come off and what to do with them but how do you take the temprature sensor oout of the scoop
Old Jun 10, 2001 | 08:51 AM
UMD_MaxSE's Avatar
Got Bent?
For the sensor that is stuck in the tubing, just pull straight out. Give it some force and it will come out no problem. The one on the front of the scoop will require a wrench to remove the bolt holding it in.
Old Jun 10, 2001 | 01:38 PM
i finally got the scoop off thanks. but underneath the battery there is a white box with an upward tube connected that dosent seem to be doing anything do i remove that box and how
Old Jun 10, 2001 | 06:02 PM
UMD_MaxSE's Avatar
Got Bent?
That box is the resonator. It supposedly cuts down on intake noise. However, it really does nothing. Infact the 2001 modles don't even have this box or tube. You can take the L-tube out along with the scoop and ignore the white box. It won't do a thing. If you really want though, you can remove the white box. You will probably have to take out the battery and the batter tray. In my opinion, it isn't worth the trouble. Just leave it there.
cruce91
Sep 20, 2015 10:23 AM
220k+ A32
Sep 11, 2015 02:18 AM
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
