Seafoam saved $$$$
Old Feb 24, 2006 | 02:45 PM
SuperStasiu's Avatar
Seafoam saved $$$$
Well heres the deal a while ago I did the VIAS repair on a friends 2000 fed spec max. We cleaned it off did the JB Weld repair but still his VIAS wouldnt open at full throttle. We even checked the sensor and it was good, we worked on it for like 6 hours on a saturday but still couldnt get it. A friend suggested maybe he has low vacum so that would mean his intake manifold was cracked or his vias was completely crapped. So we went to the gym on wendsday and after we raced i raped him, we talked he said he was going to buy a new manifold for like 300 bucks( his buddy works at nissan) and I sugggested hey why not a 6 dollar can of SEAFOAM . I told him what it does and was like ok Well we did it yesterday his car has around 105K miles never done it before. Alot of smoke came out looked like we clam baked my garage even though the door was wide open and then hes like im gonna take it for a drive to see if it did anything. As soon as he punched it i heard tha vias kick in i was like DID HIS VIAS JUST ACTIVATE?? Sure enough he pulls back into my garage big smile on his face we pop the hood hand rev the engine sure enough vias was working. So 6 bucks is better then 300 plus bucks. Just posting this incase anyone had a problem with it even after the JB weld fix. I guess his vacum lines were pretty clogged up. Now hes got extra money in his pocket and wants to get Hotshots.
Old Feb 24, 2006 | 03:16 PM
scopium
where do i buy seafoam?
Old Feb 24, 2006 | 03:37 PM
n3985's Avatar
大陆弟弟
Pretty much all automotive stores sell them. BUT, do it before an oil change as it makes the oil very dirty afterwards.
Old Feb 24, 2006 | 03:42 PM
ChromeSE5's Avatar
napa 13234234
Old Feb 24, 2006 | 04:58 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
autozone....etc.....
Old Feb 24, 2006 | 05:27 PM
DrKlop's Avatar
Driving is the next best thing
You could actually hear it? I know that mine works 'cause I feel the increase in power over 5 rpm but I cant really hear the difference.
Old Feb 25, 2006 | 03:33 AM
peachman's Avatar
Mabey a stupid question but what is seafoam, what does it do and where do you add it? Thanks.
Old Feb 25, 2006 | 06:03 AM
upstatemax's Avatar
There is a intake tone change.
Old Feb 25, 2006 | 09:34 AM
DrKlop's Avatar
ok, I'll try to listen more carefully next time I go over 5k... lol
It's a solution designed to clean internal parts of your engine, intake manifold, injectors and fuel lines. While there are many other products that can clean your fuel system and engine better than seafom, seafom if probably the best thing to use to clean your intake manifold.
Old Feb 25, 2006 | 09:36 AM
n3985's Avatar
大陆弟弟
http://www.seafoamsales.com/
Old Feb 25, 2006 | 10:31 AM
JaKillz2's Avatar
besides seafoam is there any other things youd recommend doing at the same time to help clean internals?
Old Feb 25, 2006 | 10:32 AM
n3985's Avatar
大陆弟弟
A good dose of REDLINE once in a while.
Old Feb 25, 2006 | 10:35 AM
JaKillz2's Avatar
on the seafoam website it says for use in 2 and 4 stroke engines...
Old Feb 25, 2006 | 10:41 AM
DrKlop's Avatar
yes, check out fluid and lubricants section
Old Feb 25, 2006 | 01:26 PM
trigger005's Avatar
Ughhhhhhhh...
Thanks for the heads up on the Seafoam though
Old Feb 25, 2006 | 01:37 PM
Belteshazzar's Avatar
That stuff is crazy. Add it to the fuel, put it in the oil, works in the tranny too. You read all the stuff it cures on the bottle, and it makes you think someone with AIDS ought to drink some.
And yet I've heard about a million stories of it really working.
Old Feb 25, 2006 | 04:09 PM
Hey the stuff does what it claims and its not hugely advertised, which is true off alot of great products
Old Feb 25, 2006 | 04:19 PM
steven88's Avatar
Need A Light?
Thats if you put it in the crankcase....in this case, he didn't put it in the crankcase...he fed it thru the IM...this has no affect on the motor oil and u don't have to change your oil until you need too...
Old Feb 25, 2006 | 04:59 PM
Maxima-Ness's Avatar
From day one here, I have been seeing this talked about on the forum. Im starting to get curious about it. I already understand how to do it and where to get it, but do you think it would be at all beneficial to do it at 60K?
Old Feb 25, 2006 | 06:05 PM
YESSS humm yes yes and yess as i did it on my car at around 65k and lots of sht came out
Old Feb 26, 2006 | 08:40 AM
maximadave's Avatar
detailerdaveb@gmail.com
will it help pinging probs on the 3.5?
Old Feb 26, 2006 | 09:03 AM
BRINKLEY's Avatar
I did mine yesterday for the first time, I'm right over 100,000 and I'm sure its never had any run through it.......wooooooo I was feeling bad for the neighbors.....lol At first I didn't think it was gonna work, I guess it took a little while to get through the system, but mang it blew a BUNCH of chit out, I'll be doing this every couple months.... thanks for the how to!!!!
Old Feb 26, 2006 | 11:53 AM
Never hurts to try, maybe try running it in the crankcase but change the oil after that
Old Feb 26, 2006 | 01:11 PM
DrKlop's Avatar
I doubt that it will. It might help pinging only if the cause of pinging is sludge, but VQ engines are not prone to sludge formation.
Old Feb 26, 2006 | 02:41 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
even through the brake booster method, some of the released particles from the IM can make their way into the oil. most is blown through the exhaust but the couple of times i have used it, the oil draining out afterwards was darker than typical. i follow fairly strict guidelines for when and with what i use in an oil change or i would not claim that.
Old Feb 26, 2006 | 06:53 PM
Paulie Walnuts's Avatar
Hmm I never knew that you should put in your oil.
Are you inviting disaster by putting this in an having it free up a bunch of stuff and send it tumbling through your engine.
Old Feb 26, 2006 | 07:21 PM
vastmax's Avatar
i used seafoam on my 92 prelude, i put it in all 3 suggested places. I could not believe the difference it made!! I usually got 300 miles on a tank of gas, but the week after i tried seafoam, i got 350 miles on the tankful, same driving routine and everything. The car ran so much smoother and the VTEC (don't flame me for this) transition kicked in as smoooth as it did originally. Very highly recommended!!!
Old Feb 27, 2006 | 10:31 AM
Max_Vader_2K's Avatar
I haved used seafoam in all 3 areas (crankcase before and oil change, brake booster vacume line, and gas tank) as well and have not had any problems with it and will continue using it.
Old Feb 27, 2006 | 11:09 AM
Jasovanni's Avatar
So if you're throwing sludge out the tail pipe, could this clog the cat converter???? Or at least contribute to its demise....
J
Old Feb 28, 2006 | 07:29 PM
VQuick's Avatar
Chassis Freak
Good question about the cat...
Otherwise Seafoam really does sound great. I'm gonna try it.
Old Feb 28, 2006 | 07:33 PM
upstatemax's Avatar
I have used it twice and have not had a problem with my cat.
Old Feb 28, 2006 | 07:37 PM
spirilis's Avatar
Man he just told us more about his sex habits than I needed to know...
Old Feb 28, 2006 | 07:47 PM
upstatemax's Avatar
your trying to hard...
Old Feb 28, 2006 | 10:48 PM
trigger005's Avatar
Actually, by the looks of your avatar I'd say that isn't too far fetched...
Old Feb 28, 2006 | 10:50 PM
peachman's Avatar
Thanks DrKlop! Also is there a how to for this stuff?
Old Mar 1, 2006 | 05:18 AM
Swisscheese's Avatar
Here is a picture of where this stuff goes, the rest of the instructions are on the bottle. Be sure to give it hell when you are finished waiting the 5 minutes.
It is O2 Sensor and Cat Converter safe(According to the bottle, says it right on it)
Here is the pic:
Old Mar 2, 2006 | 09:51 PM
Muahahah I have started a Seafoam attack on the forum muahahahahahaha lol I think you guys should of just posted in here instead of makeing new threads,lol tenoobftwtyhvaniceday
Old Mar 3, 2006 | 12:31 AM
mjk's Avatar
mjk
Head shot!!!
I'm assuming that the when trying to clean out the IM, you pour/spray it in right after the filter?
Old Mar 3, 2006 | 01:25 AM
mjk's Avatar
mjk
Head shot!!!
http://forums.maxima.org/showthread.php?t=346574
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Andy29
Sep 29, 2015 05:32 AM
dcam0326
Sep 26, 2015 05:20 AM
220k+ A32
Sep 23, 2015 03:38 PM
