UD pulley
Old Mar 7, 2006 | 01:55 PM
  #41
kcowden's Avatar
Originally Posted by Puppetmaster
I got one of those forever ago and its still sitting on my desk.
Cool looking paperweight I bet.....
Old Mar 7, 2006 | 01:57 PM
  #42
Puppetmaster's Avatar
Definitely.... the best conversation starter ever...
Old Mar 7, 2006 | 03:20 PM
  #43
Deckdout2's Avatar
Play with my balls
Seems like a trend to me. Buy stuff and leave it lying around.
Old Mar 7, 2006 | 03:45 PM
  #44
amimaxima
can someone post pictures of there udp installed
Old Mar 7, 2006 | 07:22 PM
  #45
jenk01SE's Avatar
Why? It looks like a reduced diameter crank pulley....
Old Mar 7, 2006 | 07:28 PM
  #46
Hoooper
its not like you can really see it. go out to your car and try to take a peek at the crank pulley.
Old Mar 7, 2006 | 08:05 PM
  #47
You should see my other "paperweights".... 6th Gen calipers, 5.5 upper and lower IM, VAFC-II, H-techs....
Old Mar 7, 2006 | 09:51 PM
  #48
5thgenmaxima's Avatar
Been waiting to see where this goes.
A UDP doesn't create HP so you can't measure it.... it free's up HP that the engine was using to rotate that heavy azz stock pulley. Imagine pedaling a bike with a heavy azz rear tire.... then think about the same with a lighweight wheel.... same goes for you engine; you can only generate so much energy to pedal the tire, it's easier to pedal a lighter tire.
In theory, if you can get going faster with the the tires off the ground (weight of car not being a factor) then you would have more foot pounds of torque would you not?
I put one on about 3k mile ago, didn't notice this HUGE difference but I did notice that the engine revs a lot more freely when moving up through the RPM range. .
I've heard this from several people. I'm not denying your right, but it doesn't make sence why it would rev quicker w/o some sort of performance gain. I question if it's psychological and if your just buying the hype.
Originally Posted by Bpe383
A couple of things. Weight is miss leading. As most may or may not know less weight can hurt on some rotating things, and help on others. When it comes to pulleys it’s not the weight so much as the diameter of the pulley that helps.
Incorrect.
http://www.cyberauto.com/index.php/unorthodox.htm .This is from a seller of Unorthodox products, so take there dyno results with a grain of salt.
Even Unorthodox and their sellers have conflicting info, if that tells you anythings.
You don’t want to lighten up your crank pulley but so much because of crank harmonics.
IIRC, I beleive that depends if your crank is externally or internally balanced.
Beside a pulley couldn’t weight but so much (crank will weight more). So by cutting 1-3LBs you will see little effect. It’s the Dia. Of the pulley that makes a UPD effective. It’s like gearing. Think of your pulley system as a bike. As you switch gears the sprockets are changing in Dia. Same thing with a UPD. You are simple making it easier for the engine to turn the item with the new Dia. Pulley, thus freeing up energy needed to turn it.
You where almost onto something here, until you got past your first sentence. How in the hell are you going to compare final drive gear ratios to accessary gear ratios and even begin to think your point is valid? Gear ratios directly effects the speed/torque of the tire. Accessory pulleys don't, not even indirectly.
You ever notice performance mags will do a intake swap and dyno before after? Or they will do an exhaust before/after dyno? Well I challenge you to look through as many performance mags as you can find and show me just ONE UNBIASED dyno with before/after dyno results with out ANY other mods or tuning done and of course on the same day with the exact same conditions.. Performance mags don't do this for 1 reason. They are advertisers and don't want to run them away. Yes, of course, you can pull before/after dyno results up all day that shoe an improvement. They're either 1.) A seller of such product. 2.)A sponsor of such company.. Or they dynoed on a different day with a potentially different atmospheric pressure, different tuning, different fuel, etc.
Here's the only unbiased info I could find.
http://www.teamscr.com/pulleys.htm
Also,Making any other pulley than the crank pulley lighter doesn't make any sence either...The bearings that rotate the pulley having less friction would play a larger factor than the pulley weight itself. Manufacturers spend billions every year making sure their accessories already operate at there most efficient and everything is created around that concept. One could assume even creating near frictionless bearings with stock pulleys would/could be a priority.
I don't know what to tell you other than the word under drive means Dia. not weight. It it was all abou the weight then why call them UDP, why not light weight pulleys?
Without doing research on the history of UDPs, I would assume that was the selling point. As more and more people got smarter they may have changed there selling tactics.
Old Mar 7, 2006 | 09:53 PM
  #49
joebangaa's Avatar
you should see my paperweights... in addition to having a motostorm UDP sitting around since that GD, i've had ksports sitting around for months, and more used car audio than a flea market
Old Mar 7, 2006 | 10:01 PM
  #50
NmexMAX's Avatar
dot dot dot ...
50 posts and no one has dyno or track results...
Old Mar 8, 2006 | 02:35 AM
  #51
jafo2com's Avatar
That must be a good size desk. At least it's not going anywhere.
Wish I had that problem though, as my mods have been limited to my allowance the wifey gives me, which currently sits at $0. So yeah, basically foglight rewire and maybe stepping it up a notch to do the GAB conversion.
My guess is that noone has recently done this conversion...yet...for before and after results. *shrug
Old Mar 8, 2006 | 09:05 AM
  #52
NewLoveI30's Avatar
bpe383, thank you for posting a bunch of info I already know.
I can post quotes too!
"First, and most important, is the weight lose. An average of 2.7 HP is gained from every pound lost off the crank shaft. 85% of the gains are from weight loss. The rest of the gains are from underdriving which accounts for about 15% of the total gains."
Im not arguing with you about underdriving (yes, I know what the word means), but I totally disagree with your idea that gains arent made from weight reduction. UR also makes a stock diameter lightened pulley. So how does this increase efficiency if weight has negligible? You may not make that much power, but UD pulleys arent going to have fantastic gains either.
You want to get into flywheels next?
Old Mar 8, 2006 | 09:15 AM
  #53
upstatemax's Avatar
My Motostorm UDP...
Old Mar 8, 2006 | 09:21 AM
  #54
upstatemax's Avatar
I like my UDP, but saying that for every pound taken off the crank gives 2.7hp is unrealistic.... It really depends on the car, if that was the case I would have FELT the power difference when I installed it. The stock pully is REALLY heavy, the Motorsotrm one is easliy 1/3 the weight...
I still have the stock one sitting around upstate, the next time I am up there I will try and see the difference in them.
Puppet; if by chance you do install before I go back upstate can you throw the two on a scale?
Old Mar 8, 2006 | 10:05 AM
  #55
03maxima1's Avatar
Tell me about it. I did that for a while and just sold everything.
Old Mar 8, 2006 | 12:43 PM
  #56
NewLoveI30's Avatar
Probably due to driveline loss. Maybe they translate the gains to hp at the crank. Doubt if you would really be able the feel a 5whp difference in the first place. And yes, numbers are always going to be different between different cars.
Old Mar 8, 2006 | 12:59 PM
  #57
kcowden's Avatar
What the he!! does this mean??????
Because driving these accessories at higher rpm is a waste of energy, running them at a much higher rate than it needs to for optimum effectiveness. This is energy which could be put toward acceleration instead. Not psychological or hype.
This wasnt even my quote..... make sure your double checking your work before handing it in.
"Each accessory uses rotary power - each accessory is turned to perform it's function, whether it's an electrical component (the alternator) or a fluid displacing component (the water pump and power steering pump). They all have a pulley which takes power from the crankshaft pulley via a belt.
Some of the engine accessories take more power than they really need, dramatically affecting engine performance.
Driving these accessories at higher rpm is a waste of energy, running them at a much higher rate than it needs to for optimum effectiveness. This is energy which could be put toward acceleration instead.
An underdrive pulley is a replacement accessory pulley that bolts up the same as stock, but has a different size (ratio) and material specifications intended to free up lost horsepower. By increasing the diameter of each accessory pulley, the speed at which the accessories are turning relative to engine RPM decreases.
Does this actually make horsepower?
Underdriving the accessories does not add power to the engine, it frees up the power that is normally wasted on overdriven accessories. The theory is that a larger pulley will drive the accessories slower thus reducing their parasitic horsepower loss. No more power total, but more power sent to the wheels. As an additional benefit, the reduction in wear (less usage) on the accessories due to the lower duty cycles can extend the life of these parts."
Old Mar 8, 2006 | 08:41 PM
  #58
NmexMAX's Avatar
dot dot dot ...
You guys should spend your energy and time on something a little bit more useful rather than a pulley.
Old Mar 8, 2006 | 08:48 PM
  #59
upstatemax's Avatar
I only put mine on since I could pick one up for $75 shipped and I had to replace my belts anyway... I figured it could not hurt, I would never spend $200+ on other ones or go way out of my way to replace it.
Old Mar 8, 2006 | 09:20 PM
  #60
NmexMAX's Avatar
dot dot dot ...
I wasn't referrig to you.. But moreso the guys with paragraph after paragraph of .
Old Mar 9, 2006 | 05:31 AM
  #61
I'll let ya know if I get to that.... or anything else for that matter.
Old Mar 9, 2006 | 05:33 AM
  #62
The neverending debate just keeps going on doesn't it?
Old Mar 9, 2006 | 07:10 AM
  #63
kcowden's Avatar
Well said.....
Old Mar 9, 2006 | 07:11 PM
  #64
jenk01SE's Avatar
F'ing A Cotton, F'ing A...
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
02PearlSE
Feb 1, 2016 12:37 AM
rbarnes
Dec 31, 2015 06:29 PM
DarjeelingRose
Sep 15, 2015 01:20 AM
