Stupid auto transmission is leaking!
I believe my 2002 auto transmission's main pump seal is leaking. Also, I was told both my transaxle seals are leaky and need to be replaced.
Any one else had this problem?
I've had both my differential seals replaced. I have a MT but I guess it's similar. If it's just your seals then it shouldn't be more than a $210 fix. I'd take it in unless you are confident at taking your axles out.
I'm starting to think I drive my cars too hard.
89 240sx, blew the tranny had to have it rebuilt.
Now the 02 maxima, blew the main pump seal. Maybe I should drive a tank.
Aluminium shavings in the pan..
Yup its time for a rebuild. Question is, the rebuild might cost $2,100.. so should I just buy a new transmission and drop that in?
Thanks.
Thanks.
Wow, ok. Guess nobody cares much.
Some screw came loose and a roller pin "cut" metal out of the differential. More details once I get the invoice from the shop.
So, this was a pure mechanical failure. Additives, driving habit.. none of those were the cause.
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
The Wizard
24
Oct 1, 2015 08:47 PM
A32goldylocks
Sep 16, 2015 01:33 PM
ag90fox
Sep 9, 2015 12:22 PM
