Check Engine = P0720
Old Apr 1, 2006 | 01:18 PM
fall97's Avatar
My check engine light came on today and I immediately bought an OBD II scanner at the local auto store. I plugged the thing in and I got P0720.
In the book its listed as a Output Speed Sensor Circuit Malfunction. Does anybody know what that means or what specifically should be replaced. I thought it may have been the MAF since I'm at 96k and I havent had it done, but now I'm not so sure
Old Apr 1, 2006 | 02:12 PM
jvienneau's Avatar
Are you sure it's 720? There's no such DTC in the shop manual.
Old Apr 1, 2006 | 02:34 PM
fall97's Avatar
That was definately the return code. I was using an Actron OBD II PocketScan
<p>
CODE: P0720
Old Apr 3, 2006 | 07:05 AM
Superduck's Avatar
Can that pocket scan be used to determine which ignition coil isn't firing??
Old Apr 3, 2006 | 07:33 AM
qballjr13's Avatar
According to my Haynes manual that code equals Vehicle speed sensor or Circuit fault...other than that I have no idea what any of that is...hopefully it points you in the right direction.
Old Dec 22, 2012 | 06:56 PM
WR54321's Avatar
@fall97 - see if this thread helps you with the P0720 code:
http://forums.maxima.org/5th-generat...lp-please.html
it also includes pics as to where the speed sensor is located and what it looks like in the car
Old Dec 22, 2012 | 10:13 PM
rebelhell's Avatar
You do realize this is a six year old thread right? I'm guessing if he hasn't solved the problem by now, he never will.
Old Dec 23, 2012 | 10:58 AM
rblower2012's Avatar
Lol ^
captchaos
Mar 15, 2016 12:18 PM
6spd4dsc
Mar 4, 2016 05:19 PM
jfl330
Sep 4, 2015 01:44 PM
mikebla
Sep 3, 2015 05:37 PM
A32goldylocks
Sep 2, 2015 06:39 AM
