Installed CAI, now SES light
Old Apr 6, 2006 | 06:12 AM
RLW001's Avatar
I just installed my Berk Technology Short Ram Intake and ever since I have had a "Service Engine Soon" light. Is this common? The manual says to give the car a few "cycles" to go away and contact your Nissan dealer if it does not. Is there a way to clear codes? I always disconect my battery when working on the car. Also, how you read your codes? Is a code reader required?
Maybe I need to clean my MAF? I was careful not to over oil my K&N.
Thanks for the help.
Old Apr 6, 2006 | 06:17 AM
qballjr13's Avatar
Bring it to any Autozone and they will do it for you.
Old Apr 6, 2006 | 06:25 AM
chr0nos's Avatar
K&n comes oiled from the factory. if you added more oil to it, it's overoiled. take off the intake and see if the midpipe is oily on the inside. if that's the case, you may have oil on your MAF as well.
Old Apr 6, 2006 | 01:30 PM
carabuser's Avatar
Were you careful with the MAF and the wiring when installing? Make sure everything is plugged back in correctly. Also, does car idle and run any different?
Buttom line, go to autozone, pick up an obd-2 reader, check the codes, clear them and see if they come back.
Old Apr 6, 2006 | 02:34 PM
alpinestars™'s Avatar
THIS IS...
Pick up some CRC MAF cleaner at your local AutoZone Or Checker. That may solve your problem before you go buy a new MAF.
Old Apr 7, 2006 | 04:23 PM
RLW001's Avatar
I had Autozone run the code and clear them. No more SES light.
Old Apr 7, 2006 | 05:17 PM
carabuser's Avatar
What was the code?
Old Apr 7, 2006 | 06:50 PM
RLW001's Avatar
I don't remember: Something about low-voltage to maf (I forgot to plug in the maf - DOH), and IAT.
Old Apr 9, 2006 | 05:53 AM
maxmumsxspd's Avatar
Yeah, I ordered my Berk intake w/the Apexi filter for my 6 speed friday...supposed to get it the 14th (what bryan said)...Do SES lights come on very commomly when you install the intake? or if i do everything right w/the install i wont get it?
thanks
Old Apr 9, 2006 | 10:42 AM
carabuser's Avatar
SES does non come on often, unless you start you car with the MAF unplugged. Usually there are not problems with installing an intake if you do it right (and it's reaaally hard not to).
Old Apr 9, 2006 | 01:38 PM
Bezzle01's Avatar
I just installed mine yesterday and no ses light. I got the apexi filter with mine so no oil worries.
Old Apr 9, 2006 | 01:41 PM
Bezzle01's Avatar
BTW did anyone have trouble getting the silicone connector hose around the apexi filter, I had to fight it on and it took me almost 30 min.
lowpost99
22
Sep 2, 2015 04:38 PM
kirkhilles
Aug 8, 2015 10:53 AM
MikesChevelle
Aug 6, 2015 11:36 AM
yat70458
Aug 3, 2015 01:16 PM
maxima297
Aug 3, 2015 12:50 PM
