Slight "whistle" sound during acceleration
Old Apr 8, 2006 | 10:05 PM
mannetti21's Avatar
So I've noticed over the past few days that during moderate to heavy acceleration, the engine makes a slight whistle. My first thought was that the sound was being caused by air, but I'm not really sure. The whistle isn't very loud, and maybe this is common to these Maximas, but I have just begun to notice it so I am assuming it wasn't there when I got the car 2 months ago. I wish I could describe it better, but it almost sounds like someone snuck in a mini turbo kit when I wasn't looking.
It also seems like I am having to push the pedal further down to make the car downshift when passing. Feels like there might be a loss of horsepower or responsiveness.
Any ideas?
Old Apr 8, 2006 | 10:07 PM
Progress's Avatar
It's business time.
It is common. It's, evidently, the butterfly valve in the TB. Get an intake and it's even louder.
In regards to the other issue, is this a problem comparative to when you first bought the car?
Old Apr 8, 2006 | 10:19 PM
mannetti21's Avatar
Ok, as long as its normal I'm fine with it...I was afraid to say that I actually liked the sound lol.
As for the unresponsiveness, I am comparing it to when I first bought the car. A friend mentioned to me something about a computer chip learning the way I drive and adjusting the shifting accordingly...and that maybe I should reset it somehow???
I do majority of my driving on the highway at a constant speed of about 70mph, so not sure if that makes any difference at all for when I'm driving around town in the city.
Old Apr 9, 2006 | 06:04 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
it is a normal sound...
Old Apr 9, 2006 | 06:27 AM
MaximaGT-R's Avatar
I'm a Happy Man!
you will get use to that. i was worried when i first noticed it on my maxima i'm sure mines is even louder than us because i have a cold air intake. i have everything checked out from exhaust manifold to catalyst converter but i couldnt find anything so i have just been dealing with it ever since.
Old Apr 9, 2006 | 08:32 AM
GBAUER's Avatar
Loss of power + whistling sound = vacuum leak. Been there, done that. Try resetting your ECU and see if you gain your power back. If so, you have a vacuum leak most likely.
Old Apr 9, 2006 | 08:42 AM
mannetti21's Avatar
So if I reset the ECU and gain my power back, it IS a vacuum leak?
Old Apr 10, 2006 | 12:06 PM
ope2k4's Avatar
Thats a normal sound. It even sounds better with an Intake. As for losing power or responsiveness here is a clue
Do a power injector flush. it costs about $60 but believe me its worth it. Its not like the regular injector cleaning that you pour the cleaner into your gas tank. This one is way better and you will feel the difference. Plus Lets hope you only put premium gas in your car.
Hope this helps
Old Apr 10, 2006 | 12:27 PM
GBAUER's Avatar
possibly. I'm still screwing with an evap leak on mine. I reset the ECU every other day now. Gotten pretty good at it!
Old Apr 10, 2006 | 03:03 PM
BlackMaxima21's Avatar
i get a pretty loud hissing sound when i accelerate too, i have a berk intake w/ apexi filter. the hissing sound is there at low rpms to about 3000. is this normal or do i have an air leak somewhere??
Old Apr 10, 2006 | 03:29 PM
00MaxATC's Avatar
Where do you get a power injector flush?
Old Apr 10, 2006 | 05:58 PM
ope2k4's Avatar
You could get this done anywhere oil change and transmission flush is done. It is done with a machine though. Most Mobil service centers do it.
Old Apr 10, 2006 | 08:00 PM
fishpony's Avatar
could the whistle be coming from your speakers possibly? I get this every once in awhile with my aftermarket "stereo". Just throwing something out there.
Old May 9, 2007 | 11:57 AM
ajamil's Avatar
Hey, were you able to get the problem fixed?? My situation is exactly identical to yours. Purchased an auto '00 a couple months ago. Didnt notice the sound or lack of acceleration, but lately I here the whistling sound, and my acceleration/gas mileage suck hugE!!!! I'm considering getting my MAF cleaned or replaced. What did you do to resolve this?? I would really like to know what you did to take care of this...
Thanks in advance.
Any ideas?
Old May 9, 2007 | 12:05 PM
AcidJake75's Avatar
Completely normal...mine does the same thing and I also have your same setup...
Old May 9, 2007 | 12:18 PM
mist max2000's Avatar
. . . mine whistles too,... thats exactly what it sounds like ..a whistle.. i never really thought much of it..
Old May 9, 2007 | 08:25 PM
Domf3's Avatar
Mine whistles while it works. I like it
Old May 9, 2007 | 08:27 PM
The Law's Avatar
I R The Law
It must be turbo spoolin!
Old May 9, 2007 | 08:30 PM
upstatemax's Avatar
You stole my smarta$$ response...
Old May 9, 2007 | 08:32 PM
godlyone's Avatar
ahhh! cliMAX!
you sure its not the alternator bearing? open the hood... pull the accelerator cable and listen....
Old May 9, 2007 | 08:33 PM
NmexMAX's Avatar
dot dot dot ...
Mine whistles more after I clean the TB.
Old Jul 31, 2010 | 03:31 PM
QT1 5MT AE's Avatar
Gram Lights addict
is this really normal??
I have a 5MT AE with 83k, 100% stock. I had no whistle at all. the other day i took factory air box off and cleaned TB and changed the pcv valve while i was at it. put everything back together and now i have this constant HSSSSSSSSSSSSS sound and there is a clear whistle sound when i tap the throttle body.... its driving me crazy because it has caused this very noticeable vibration in the gas pedal too. its not a vacuum leak cuz i checked everything 20 times. everything is 100% plugged... could a dirty TB really mask this hssssss sound and whistle???
only thing i can think of is that the TB slipped out my hand two times and slammed shut, would it be bent or something?
Old Jul 31, 2010 | 03:47 PM
PBMAXX's Avatar
My Maxima whistles too!! My sound comes from the little gray colored can that sits on top of the throttle boby. The throttle cable rests against it @ idle. I must admit it does sound good!
Old Jul 31, 2010 | 04:08 PM
Grand_hustle17's Avatar
The whistle is fine, unless its some loud abnoxious type whistle then u got me
Old Jul 31, 2010 | 04:22 PM
NmexMAX's Avatar
dot dot dot ...
Holy bump an old thread Saturday...
Old Jul 31, 2010 | 05:21 PM
SoonerFan's Avatar
Cletus
EDIT: realized this in an old thread...carry on
Old Jul 31, 2010 | 05:24 PM
SoonerFan's Avatar
Cletus
since its constant, probably a vacuum leak...did you reconnect everything properly?
Old Jul 31, 2010 | 05:50 PM
QT1 5MT AE's Avatar
Gram Lights addict
yeah everything was connected back properly........ the HSSSSS is constant but the whistle lasts about a half sec when u tap the throttle.
Mahmuth
Aug 16, 2024 08:23 PM
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
D Mason
Jun 21, 2016 04:43 AM
Need help
23
Oct 2, 2015 08:56 AM
