Dash Clock
Old Apr 9, 2006 | 06:03 AM
dafowl1's Avatar
Dash Clock
Does anybody know how to remove the dash clock on a 01 max. I looked everywhere and cant find anything on it.
Old Apr 9, 2006 | 07:43 AM
MaximaGT-R's Avatar
I'm a Happy Man!
That would definitely require a lot work the whole dash would have to come out I believe before you can take the clock out.
Old Apr 9, 2006 | 10:48 AM
Sly's Avatar
Sly
It's held in place with a few spring clips. Just pry it up with a wide screw driver and a protective cloth.
Old Apr 9, 2006 | 10:54 AM
Lontar1's Avatar
Puerto Rico-Maxima Lover
Old Apr 9, 2006 | 01:17 PM
misiek's Avatar
pull... harder
Old Apr 9, 2006 | 03:34 PM
Stardust's Avatar
F---ing Kangaroos
Actually you have to remove the engine. You get at the clock through the firewall.
Old Apr 9, 2006 | 04:26 PM
dafowl1's Avatar
Thanks I'll have to give it a try
Old Apr 9, 2006 | 04:37 PM
BRINKLEY's Avatar
I just took mine out today...... grabbed it with both hands and pulled, came right off.... mine is a 2000 though.
Old Apr 9, 2006 | 05:41 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Old Apr 9, 2006 | 05:54 PM
Stardust's Avatar
F---ing Kangaroos
Originally Posted by Metal Maxima
Whats so funny about that? Do you know an easier way to remove the clock? I thought engine removal was the only way.
Old Apr 10, 2006 | 12:08 AM
XyNoix-HIC's Avatar
Old Apr 10, 2006 | 12:58 AM
Stardust's Avatar
F---ing Kangaroos
Originally Posted by XyNoix-HIC
What, do you have a better idea?
Old Apr 10, 2006 | 09:08 AM
What was so funny is that it cannot be removed that way. After the engine has been removed, you left out the part when the firewall needs to be cut off in order to access and drain the clock-fluid resivour before it can be removed.
Silly n00b.
Old Apr 10, 2006 | 09:31 AM
Stardust's Avatar
F---ing Kangaroos
Silly n00b.
Oh yeah, I knew I left something out.
Old Apr 10, 2006 | 09:37 AM
Barc's Avatar
You forgot about the clock master and slave cylinders... not to mention all the lines and you all know the blinker fluid lines run right above them so they must be cut and then respliced upon reinstallation...
worldwiderecognized
Sep 30, 2015 01:16 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
