getting mudflaps off
Old Apr 14, 2006 | 01:27 PM
JaKillz2's Avatar
Is there an easy way to get to the screw which is behind the wheel on a 5th gen mudflap? A screwdriver can easilly access the more outside one, but there is no way to get it behind the wheel to the other.. i didnt know if you had any tricks or anything.
Old Apr 14, 2006 | 01:45 PM
KCMC582's Avatar
get a ratchet and a small sized socket, 6 or 7 mm, put the socket on, and then use a small interchangeable screwdriver head in the socket, and basically remove the screw like its a bolt. thats how i did mine.
Old Apr 14, 2006 | 02:57 PM
JaKillz2's Avatar
i tried that actually, the gap is like.. an inch.. and that adapter and bit and ratchet take up about 2in
Old Apr 14, 2006 | 03:34 PM
KCMC582's Avatar
i used a very small socket and ratchet, but if that doesnt work, vice grips or pliers and the screwdriver piece...thats all i can think of.
Old Apr 14, 2006 | 03:36 PM
JaKillz2's Avatar
tried that too ha, couldnt really get good torque, is it really worth it though, wouldnt the sides of the car get scratched up?
Old Apr 14, 2006 | 03:38 PM
KCMC582's Avatar
i took mine off the next day, i didnt see any added scratches, i think its worth it...but i dont really have any other suggestions to get it off.
Old Apr 14, 2006 | 03:51 PM
Whtmax'01's Avatar
Would it be easier with the wheel off?
Old Apr 14, 2006 | 03:56 PM
KCMC582's Avatar
yeah, it will take 2 seconds with the wheel off, but hes trying to avoid that. its possible, i did it when i bought my car, but i must have had a small enough socket set.
Old Apr 14, 2006 | 04:15 PM
nismo0604's Avatar
tuen the wheel all the way to the right or left, depending wich side, it helped me out
Old Apr 14, 2006 | 04:24 PM
merovi's Avatar
i have little rust spots under my flaps...so mine stay on.
Old Apr 14, 2006 | 04:48 PM
JaKillz2's Avatar
ahh finally got them off, i was havig trouble with the rear. I think it looks better with them off, but as merovi said, there is some small rust around the screw holes (thats it on mine) but thats not metal so i figure its just from the screw itself and will wash off in time.
Old Apr 14, 2006 | 04:52 PM
merovi's Avatar
the little rust spots for me are under the flap ont he side of the car, where the skirt first tarts. Kinda sucks.
Old Apr 14, 2006 | 05:02 PM
JaKillz2's Avatar
ohh i had a line there.. no biggy, dulled it with scratch remover, not at the point of rust quite yet
Old Apr 14, 2006 | 06:18 PM
paulpearl's Avatar
I was trying to take mine off on my 01 because they are black and the car is pearl white. Do most people think they look better with them off???? I can't get my two rears off because the center screw behind the wheel is worn from debris/pebbles hitting the screw. There is not much of the head left....Any suggestions.. I have two philips screwdrivers that I bought at home depot that are turned 90 degrees at the head that worked great for the front.....They fit fine without taking the wheels off but the heads are worn....
Old Apr 14, 2006 | 07:24 PM
misiek's Avatar
next time use a 6mm wrench and a screw driver head
Old Apr 15, 2006 | 04:47 AM
JaKillz2's Avatar
Ya i ended up doing that.. i had to put pressure on the bit with my fingers to get anough torque too. Kind of a PITA. As for yours paulpearl, the only way I know how to get stripped or worn screws out is by using a reverse bit or a cut-off wheel. I couldnt get the top screw off on one so I took the other two out, and kind of forcefully rotated the flap as i pulled away from the screw/car. This caused the hole for the screw on the mudflap to kind of enlarge and it eventually came off with some effort. The screw was then protruding about 1cm (with the absence of the flap), making it easy to turn with plyers.
Old Apr 15, 2006 | 08:11 AM
paulpearl's Avatar
JaKillz2 thanks for the info. I was thinking that also because two out of the three screws I can get to so taking those out probably will loosen the other screw for me to get with pliers. I am going to buy the painted ones to match my car... Do you know if the new ones come with the hardware (screws...) and also a good place to get them..My local stealership wants $94 for a new painted set...Thanks...
Old Apr 15, 2006 | 08:34 AM
JaKillz2's Avatar
check the for sale maybe, otherwise i think you have to go to them. Correct me if I'm wrong, but I hear about people paying 100$ for them, so I'm guessing they too went to their dealer. I doubt it comes with hardware, but you should probably use better quality screws anyways, you saw what happened to the cheap OEM.
Max139617
Sep 6, 2015 06:02 PM
92 SE-R 02 SE
Mar 9, 2003 11:04 PM
Proceedbob
Nov 3, 2002 09:20 AM
mdmartin92
Oct 7, 2002 04:53 PM
