2002 Maxima stalling problem
Old Apr 15, 2006 | 11:12 PM
98BLKONBLKSE's Avatar
Hey Guys,
I recently purchased a 2002 Nissan Maxima SE Automatic, today when I went to start it, it stalled. It turned over fine revs went up to ~1500 then dropped down and stalled. Turned over fine when I started it again. The car other then that runs perfectly fine, it doesnt run rough or anything. I did notice when I smelt the exhaust it smelled a little rich. Ive read that o2 sensors and MAF's are common things to go, but I havent been able to find anyone with the same problem. Also the SES light is not on. Ive searched and checked the faq to no avail. Also I havent pulled the codes yet, but I am wondering if the 02 sensor throws a ghost code or if it triggors the SES light. It still has rougly a year left on the powertrain and around 4 years left on the emissions, and would anyone recommend gettting an extended warrenty on the car? (4year/80,000km)
2002 SE, 89,000km (55,315 miles).
Phil
Old Apr 16, 2006 | 10:02 AM
anyone else have this problem? or know what is wrong?
Old Apr 16, 2006 | 03:35 PM
CKOTuHA's Avatar
I have exactly the same problem. I've noticed that my car starts up fine when the engine is cold. If I shut off the engine and start it a few minutes later, it revs up and then shuts off. No codes or any symptoms of the car running bad besides the famous 1500-2000RPMs rattle once in awhile.
Old Apr 17, 2006 | 11:11 AM
bump...anyone else resolve this problem??
Old Apr 17, 2006 | 11:38 AM
GBAUER's Avatar
O2 is out.
Old Apr 17, 2006 | 02:18 PM
For sure the o2 sensor??, and specifically which one? I appreciate your quick response, thanks a bunch.
How do we go about testing them, with an ohmeter?
Phil
Old Apr 17, 2006 | 06:02 PM
2001AESE's Avatar
I have a 2001 AE SE, which is a different engine, but I recently had the same kind of problem. I would start it up normally, the rpms would go up then lower than where it would normally idle and stall. It would actually do an up, down, up, then stall. Once it is started and stays running, it seems ok.
I am guessing something with the MAF, O2 sensor?
Old Apr 17, 2006 | 07:28 PM
ecsdesignz's Avatar
Codename: Frankie
MAF (mass air flow) sensor
If the car dies after you rev the car up, the car will throw a code for MAF malfunction and O2 bank 1 code. Replace the MAF sensor and it will run like new or >> http://forums.maxima.org/showthread.php?t=463385
more info:
http://forums.maxima.org/showthread....ht=updated+MAF
http://forums.maxima.org/showpost.ph...0&postcount=18
Old Apr 17, 2006 | 08:45 PM
CKOTuHA's Avatar
The thing is that there are no codes. It starts up fine in a morning, it does it only after the engine is warm and the breaks between shut off and start up is not too long. Needle jumps up and then slowly goes down until it dies. If you rev it up a little, it stays on with no problem. From the second try it always starts up.
Old Apr 18, 2006 | 06:42 AM
ecsdesignz's Avatar
Codename: Frankie
It's a sign that it's dying. If it's totally dead you'll get the codes ^__~
Old Apr 18, 2006 | 04:20 PM
cuk133's Avatar
Hi... I have similar but not exact kind of problem.... car will stall at stop signs and when started, will have very low rpms and if held there for too long, it will also stall. However, code was thrown and was the IACV (intake air control valve). Car's been fixed since then... thanks ot DaveB.
Old Apr 18, 2006 | 09:14 PM
96blkonblkse's Avatar
damn..MAF are expensive for the 02-03, I wonder why they are so much cheaper for the 00-01. If i were to clean the MAF sensor with the MAF cleaner stuff would that fix the problem 100% or is it more or less a temporary thing?
Old Apr 18, 2006 | 09:32 PM
ecsdesignz's Avatar
Codename: Frankie
get one of these n be done with it ^__~ If you just bought the car maybe they'll throw in a free update.
http://www.nissanparts.cc/cart/?pn=2...=14&submit.y=6
Old Apr 20, 2006 | 04:47 PM
just thought id post this. for sure it is the MAF sensor. Just had it tested at nissan under the warrenty and they said for sure it is, just thought id let you guys know.
fastcarny
May 18, 2020 10:40 AM
fastcarny
Aug 12, 2015 03:50 PM
papo99
Aug 9, 2015 07:24 AM
yat70458
Aug 3, 2015 01:16 PM
