De-k Sos!
Old Apr 24, 2006 | 10:16 PM
Jar's Avatar
Jar
De-k Sos!
Ok i've searched and looked through the FAQ's about the vias problem, couple things. Other than the JB weld fix would I have to replace the entire unit that screws to the side of the intake or is there something else to look at first? what exactly does the JB weld do, I was a little unclear as I found no plastic cup just metal. also the runners look like they stick as they move back and forth but will turn freely. What else should I check? when at half throttle or a little more, just after 3k rpm's where the intake should open it bogs down hard and revs VERY slowly. I dont have a warranty and not a lot of money so any additional help would be GREATLY appreciated. thanks guys.
Old Apr 25, 2006 | 06:49 AM
Jar's Avatar
Jar
Noones got any help or advice for me other than the jb weld?
Old Apr 25, 2006 | 07:04 AM
Stardust's Avatar
F---ing Kangaroos
Give them some time to reply. Most people are sleeping between 12:30 and 9:30.
Old Apr 25, 2006 | 05:58 PM
Jar's Avatar
Jar
the cup is still firmly attached and there is no freeplay but the valves are still not opening, what else could be causing this? or is there something i'm missing?
Old Apr 25, 2006 | 06:10 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
have you had someone rev the car above 5k rpms and looked under the hood to see if the actuator (elbow piece) is moving?
Old Apr 25, 2006 | 06:17 PM
D-Bo's Avatar
Droppin logs
Pacific time FTL...
I agree with the poster about watching it to see what is going on when the problem occurs.
Good luck bro.
Old Apr 25, 2006 | 06:55 PM
Jar's Avatar
Jar
I hadnt looked yet (only one up at the time) but decided to do a thin layer of JB weld to head off future problems, tonight when I put it back on I will let it warm up and do the 5k test, if it doesnt move, then where do I go from there?
Old Apr 25, 2006 | 11:31 PM
Jar's Avatar
Jar
FIXED!!!! did the jb weld kwik and it looks like at some point....dunno when, that two vacuum lines on the vias had been switched? this is odd since the problem was ocurring before I even tore into it.....might have to track down an *** to kick. but anyways intake installed, tb cleaned and vias operational
NOW THAT B to da ITCH NEEDS AN EXHAUST!!!!!
Old Apr 26, 2006 | 07:05 AM
sloppymax's Avatar
the left vacuum line going into the box is for the vias but the one on the right is for the swirl control valve that is found on cali spec cars. just fyi.
Old Apr 26, 2006 | 07:56 AM
Jar's Avatar
Jar
it would seem that one of the lines toward the rear of the box that hook to the metal line that goes toward the pass side was left off or got switched at some point and the vacuum direction was off or something I dunno but as soon as the lines got put back and everything was hooked up right, it was like a lightswitch being turned on.
Old Apr 26, 2006 | 08:07 AM
FriscoMaxima's Avatar
or you can just turn the wheel that a throttle cable is attached to. left of throttle body.
mans
Mar 13, 2005 07:31 AM
lokobreed
Mar 5, 2005 07:34 PM
zerphyte
Detailing
Mar 27, 2004 05:57 PM
kingston
Oct 23, 2001 05:39 AM
Avalon Racing
Dec 1, 2000 04:20 PM
