2k3 hid lights
Old May 2, 2006 | 09:09 PM
panchosmax00's Avatar
2k3 hid lights
hey guys..i just recently bought a pair of 2k3 OEM hid's and was wondering how hard the installation was really..i know the hid lights are a sensitive topic of theft issues but how difficult is it to install in a 2000-01 max? do i need a wiring harness..the one from courtesynissan?? can i even use my old wiring??thanks
Old May 2, 2006 | 09:19 PM
shift_2kmaxima's Avatar
it is easy to install.....
did u get any wires with it? if u have the turn signal wires, and high beam ones, than u should be fine w/o buying the harness.but if u have 49 bucks, go ahead and buy one frm courtesynissan....it'll be easieer to installl...
but afterall, if u just know basic electric things you'll be fine.....
good luck
huso
Old May 3, 2006 | 05:59 AM
MIXXMAX's Avatar
Buy the harness from Dave B. It's much cheaper to buy from him than Courtesy. It should run around $35.00 or so. As far as the install, the harness makes it a lot easier and cleaner install. Good luck!
Old May 3, 2006 | 08:31 AM
† ErV †
you don't need it but it will make it all better. just find a spare bulb and fool with the wires till you get them marked. there was a diagram but experimenting is more fun and you learn.
just don't test anything on the hids though.. also i fused mine since i don't trust the default fuse in the panel. i used some low amperage one too, and it hasn't blown yet
Old May 3, 2006 | 09:11 AM
MaxBoost925's Avatar
Drug Money
You need an OEM wire harness kit from Nissan. I got mine for $49 from my local Nissan dealer.
Wiring is easy, I'd tell you how to do it, but then I need proof of purchase. It's really easy and it's common sense, all you need is $10 worth of radioshack wiring components, 1 hour, and know-how.
Good luck.
Old May 3, 2006 | 06:56 PM
i didnt get the turn signal wires and the high beam wires /sockets..what does the harness kit provide?? the sockets and all wires(turn signal,high beam,parking light and all sockets?).so best bet is buying the harness? and Dave B sells them cheaper? anyone know his email?
thanks
Old May 3, 2006 | 06:58 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
call him DaveB 1-888-254-6060... you need the wire harness to install them.... good luck
Old May 3, 2006 | 06:59 PM
Y2k2maxse's Avatar
just wondering how much $ did you pick up the headlights for?
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
Maxie40
Sep 14, 2015 11:28 AM
mpbclutch33
Sep 8, 2015 06:21 PM
MaxLife17
Sep 8, 2015 02:36 PM
