any one install a VAFC 1
Blake, go to the website to see what each wire needs to be connected to (throttle, tach, etc.). In the front passenger floor, there is a black piece of plastic that is covering the ECU. It's on the left side, by the center console. Remove that and unconnect the harness. Look at the 3.0 ECU diagram to figure out what wires you need to use with the AFC.
Here are the instructions for the V-AFC I install.
http://www.apexi-usa.com/pdfInstallation/23.pdf
Here is the ECU wiring diagram.
http://vq35de.com:2002/A33x_ECM.pdf
Good luck, Blake. It should be simple and straight-forward. Just buy some t-taps and tap into those wires.
MaxLife17
Jun 27, 2019 01:37 PM
