Change Flywheel leave stock clutch?
Old May 18, 2006 | 07:00 PM
PeteusMaximus's Avatar
Would you put a light flywheel in and use the stock clutch? Nothing wrong with my clutch but I want the benefits of a light flywheel.
Old May 18, 2006 | 07:27 PM
makavelisk's Avatar
If you are spending the money to have the whole thing taken apart might as well spend a little more and get a stage 1 act, clutchmaster, ect cluch and get rid of the stock.
Old May 19, 2006 | 05:50 AM
jvienneau's Avatar
No way would I pull a trans, or pay someone else to, and put the used clutch back in.
Old May 19, 2006 | 01:10 PM
boondoxmax's Avatar
This is a no brainer. Just put a brand new stock clutch in and the lighter flywheel, but don't reuse the old clutch after you've pulled the tranny
Old May 19, 2006 | 02:09 PM
inspiredbykev's Avatar
You should thank my D***
I heard that it would be harsh. Since our clutch disk is solid and the lightened flywheels is solid it will be harsh. From what I heard is that you can get the oem setup but an aftermarket sprung disk then lightened flywheel.
Also I heard with flywheels you hear startup grind because of the starter ring gear or because we have a dual mass flywheel.
Old May 19, 2006 | 02:28 PM
mtrai760's Avatar
'Trynna' is not a word
you need to quit listening to whoever is filling your head with crap.
Old May 19, 2006 | 02:30 PM
Jeff92se's Avatar
I'm needing a caw
Can you "harshly" hit whomever you reference for automotive information in the ***** in rapid fashion?
Old May 19, 2006 | 04:14 PM
makavelisk's Avatar
That is correct.....I have a fidanza flywheel and it grinds on startup. Fidanza claims that it is normal. I have had no issues with it and is has been on the car for 10k miles.
Old May 19, 2006 | 04:25 PM
OK what clutch should I get then??
Old May 19, 2006 | 06:32 PM
http://www.ultrarev.com/Fidanza_Alum...29-p31620.html
now read the part
Note "Replacement of dual mass flywheel may cause added gear noise"
here is the other link about our oem clutch disk
http://forums.maxima.org/showthread.php?t=458000
I would listen to these people since they have actually experienced doing these mods
Old May 19, 2006 | 08:07 PM
jvienneau's Avatar
The truth is you should just leave it alone. There is almost no benefit to a lightened flywheel. No matter what others on here may say.
Old May 19, 2006 | 08:41 PM
makavelisk's Avatar
I noticed a difference in performance with my setup. So Im not sure where you get that there is no benefit.
Old May 20, 2006 | 04:25 PM
jvienneau's Avatar
Because it's true. I'm sure you believe it made a difference and maybe it did make a small one. The lower mass might let it spin-up a tiny bit faster, but you give up the inertia on launch. Defintely not worth pulling a trans for IMO.
Old May 20, 2006 | 06:57 PM
makavelisk's Avatar
I had to get a new clutch anyways so it was worth it for me....if I had to do it all over again, I would just get a clutchmaster stage 2 clutch and get the oem flywheel resurfaced.
Old May 20, 2006 | 08:34 PM
Derrick2k2SE's Avatar
What brand flywheel do you have that showed no performance gain?
I've had my tranny out several times and have tried several clutch setups. I've felt the gain after install and the loss when going back to the stock flywheel for a short time. The car just feels heavier with the stock flywheel. sort of like having a car full of people.
Did you experience a loss of inertia with your setup? Even with HLSD and drag radials my biggest challenge when launching is not spinning the tires. I even bark the tires going into 4th with the drag radials on. I'm definately not suffering from a lack of inertia. If you're experiencing problems after installing your flywheel it may be something else on the car. Maybe the clutch is slipping.
Did you do the install yourself or have it done?
Old May 20, 2006 | 09:51 PM
ColdSHO's Avatar
i noticed a huge difference when i got my fidanza installed. the whole car just seems so much more responsive.
wouldnt lightening the load on the crank have an effect on the power u can put to the ground, like going with lightweight wheels just even more so?
Justin Kroll
Sep 2, 2015 11:06 AM
maximusrising
Sep 2, 2015 09:55 AM
coasterswim
Sep 2, 2015 07:43 AM
RealityCheck
Aug 5, 2015 06:18 AM
