Catch Can...does it make a hissing noise?
I just installed a couple of days ago the catch can mod. After I drove the car for a while, I opened the hood and the i heard this hissing noise. The hoses were very warm and you could move them around easiley. There was a little oil in the hoses and after driving about 100 miles with it...there was only a little oil in the cup.
Is this normal?Could I have a little hole or something in the one of the hoses? Could the hoses be melting from the inside? I got the braided ones just like I saw it here.
I had the same problem when I installed it too! after a week the hissing got louder and i noticed it was coming from the hose closest to the pcv valve (check it there) my hose was shrinking from the heat so im guessing the air was having a hard time getting thru. Now im back to no catchcan untill i get some better hose....
yeah...I think the hose is not holding up. Some people didnt have any problem with the same hose that I got.
Could this damage the engine? or turn on a check engine light if there is a hole in one of those hoses?
![](https://maxima.org/forums/images/smilies/support.gif)
you might have the catch can facing the wrong way...make sure the arrow is facing the firewall, because the filter is unidirectional....there is a VERY slight noise, but i could only hear it when i put my ear up to the catch can itself....and if i were you, i would go to autozone and get some 3/8" ID fuel line...it can hold up to a lot higher heat and pressure than the stuff you can get at home depot...i got 4 ft. for $3.50 or so....
I hear hissing too
I installed my catch can on Saturday. I used the Husky filter and some black rubber, 3/8" fuel line hoses from Good Year. I am using some pretty long hoses since my can is next to the black relay box.
I HAD THE HISSING NOISE SINCE THE MOMENT I INSTALLED THE CATCH CAN.
My hoses have NOT collapsed at all after 300miles and my catch can WORKS. I have 1/4 of it filled with oil already. This tells me that i haven't installed anything the worng way. This "hissing" is just there and I don't know why. I used hose clamps and everything. The arrow on my catch can/filter points in the direction of the IM. (oposite direction of the PCV valve)
PCV valve - hose - Husky air filter (arrow => ) - hose - IM
This should be correct, right? Let me know.
I also get a hissing sound. I believe the what we are hear is the turbulence of spinning air inside the filter.
As an experiment I have added a second filter in series(more hissing). It accumulates oil at ~1/5 the rate of the first, this makes me believe that one filter does an excellent job. The though to add the second filter because I could see oil in the hose running from the filter to the intake. Has anyone else added a second filter?
Originally Posted by The Law
EVERYONE WHO HAS DONE THIS MOD NEEDS TO UPGRADE THEIR BRAIDED HOSE TO THE BRAIDED FUEL LINE HOSES ASAP!! as you can see in the pic below my braided hose stated to collasp
![](http://memimage.cardomain.net/member_images/1/web/805000-805999/805783_57_full.jpg)
![BangHead](https://maxima.org/forums/images/smilies/banghead.gif)
![nupe500](https://maxima.org/forums/images/smilies/maddance3.gif)
ballerchris510
09-11-2015 05:29 PM
