Oil change and ABS light
Old May 24, 2006 | 05:06 PM
Mass_Media's Avatar
Mass_Media™
Did my oil change yesterday when the car was lowered to the ground the abs light turned on. So i turned it off and back on, still there. I did some searching and found that if i disconnect the neg battery cable that it might reset the light (http://forums.maxima.org/showthread....ght=ABS+Light). It didn't still on (left off over night) Just to make sure it was a problem i hit the brakes pretty hard doing about 40 all 4 tires locked up. Im taking it to nissan for service might as well get this fixed just wondering how much this will cost.
Old May 24, 2006 | 07:20 PM
5thgenmaxima's Avatar
Go to autozone and find out what the code is.. Probably knocked one of the sensors on the wheel loose if it came on before you started moving. Could also be a broken tooth. First thing I would do is check the connections at all of the sensors.
FYI: anytime your abs detects a falt it will set your light and your entire abs system will shut down until the problem is fixed.
Old May 29, 2006 | 08:48 AM
piotroosh's Avatar
not true ;-)
i already posted it few times...
I had a bad FR speed sensor, and my abs qould not work. I replaced the sensor. abs started working again. but abs light is on all the time. if i disconnect the FR sensor, light disappears, and abs stops working. ;D
since abs is working fine (2.5 years now) i got used to the abs light being on...
i don't feel like paying $80+ to get it diagnosed.
oh, btw. i tried the auto diag. with grounding(afair) pin on the SECU, showed no ABS errors ;D
Old May 29, 2006 | 09:41 AM
MaxBoost925's Avatar
Drug Money
I had my ABS light come on a couple times, i havn't tried to lock them up like you though, so I don't know if ABS works or not under those conditions.
Old May 29, 2006 | 09:52 AM
SDR's Avatar
SDR
I had the same problem, turned out to be a faulty rear sensor. Part was $550 canadian for the sensor and I put in myself (pretty steep for a magnet on a wire...LOL). The light went off as soon as I started the car again.
Old May 29, 2006 | 01:11 PM
trigger005's Avatar
All right, completely pointless post.
what does changing ur oil have 2 do with the ABS light comin on? was it just a coincidence that ur ABS went out right after u changed ur oil or did the oil change somehow cause the ABS 2 go out?
Old May 29, 2006 | 03:47 PM
Mass_Media's Avatar
Mass_Media™
Nice job reading my original post. I was asking if it was related
Old Jun 1, 2006 | 03:46 PM
Originally Posted by piotroosh
not true ;-)
Intresting... I wonder if your light is on maybe because power to the light somehow shorted to another ignition power source.
mass_media:
Any update?? Is the mil light on? Any codes??
seeing as how it happened right after the oil change, I'm sticking with my guess that a wire came loose or tooth on the axle broke.
Old Jun 1, 2006 | 04:18 PM
Mass_Media's Avatar
Mass_Media™
mass_media:
No updates. Im waiting until things are a little less hecktic (graduating tomarrow) then its going to the dealer.
Old Jun 1, 2006 | 06:17 PM
awesome. Good luck at graduation.
Old Jul 4, 2006 | 08:39 AM
Mass_Media's Avatar
Mass_Media™
**********UPDATE*************
I was posting in another thread and forgot to update. So I took it to nissan and they said that my right ABS sensor had failed. Its like $290 so i told them just leave it in ill fix it when i get back (heading to cali!!!) I don't kno if im going to fix it. I have driven with out abs for so long now. So I might before winter I don't kno.
AnsonJ
Jun 2, 2017 01:35 PM
MatthewsMaxima
Sep 11, 2015 03:21 AM
tnewbs
Aug 28, 2015 10:15 AM
maxinout93
Aug 20, 2015 02:17 AM
