drivers side rear window wont go down
Old May 28, 2006 | 07:41 AM
SlowJoeMax's Avatar
Finally its not raining in new england and i go to roll all my windows down and my rear drivers side window wont go down, neither of the buttons work from the drivers side button or the button on the door itself. all other windows work fine and its not the window lock, or child safety lock either....it sounds like it wants to go down but it just doesnt move, any one had this problem before?? i searched but found nothing
Old May 28, 2006 | 11:54 AM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
its the regulator....if you here the motor turn when you press the button down then thats it...if you DONT hear anything then it is the motor....i ran into this problem two weeks ago....and had an open window stuck in the down position for two weeks. i changed the whole thing...60 bucks, saved myself 400 by not gonig to the dealer.
Old May 28, 2006 | 02:09 PM
ABC's Avatar
ABC
Max112,
I just picked up a 2k1 AE and the right drivers side window goes down slowly and is a little uneven at the bottom of the travel. Is this a symptom of the regulator? I think for now it is going to stay up until I can make sure it is in good working order.
Thanks so much,
ABC
Old May 28, 2006 | 06:35 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
its the regulator...most of the time.... that's what goes first
Old May 28, 2006 | 06:36 PM
Lontar1's Avatar
Originally Posted by ABC
Max112,
Thanks so much,
ABC
It is common, in our cars
Old May 28, 2006 | 07:51 PM
SlowJoeMax's Avatar
is there a write up on fixing it anywhere???
Old May 28, 2006 | 07:57 PM
Maxima112's Avatar
not really, it is really easy.... you just have to take off the plastic cover that is under the door panel....cut under the plastic where the adhesive is with a sharp blade. UNDER do not cut the actual plastic...then you just have to work inside the door...it is like two bolts on for the window and 3 i think for the motor.
Old Jun 3, 2006 | 09:38 AM
DesiGLE's Avatar
The Boy Wonder
My front passenger window has been stuck down for two days. I took the SAT's this morning and it started pouring rain, I was so pissed, I definitely did awful this time on the test. Doesnt matter I did fine the first time.
*edit: I opted for the extended warranty from Nissan when buying this so im covered
fastcarny
May 18, 2020 10:40 AM
homeyclaus
Sep 3, 2015 06:15 PM
mpbclutch33
Aug 21, 2015 06:09 AM
shaunkey1
Aug 18, 2015 10:09 PM
