A/C behavior
Old May 31, 2006 | 08:11 PM
fhs8860's Avatar
A/C behavior
Guys and Gals
I have a 2003 Maxima SE.
IS THIS NORMAL A/C BEHAVIOR?
I set Fan control to 1,
Air recirculation to ON (light on),
Temperature Control to just before MAX AC (before the click, at MAX AC, your AC light comes on, so mine is just before that and the AC light is OFF),
Air Flow set to FACE ONLY,
A/C to OFF
and outside temperature 92F.
I GET COLD AIR OUT OF THE VENTS. The A/C is supposed to be OFF. Is this normal. Is the A/C running in ECON mode or something. Is the A/C running?
Can someone check this in your maxima and let me know please.
I went to the dealer today and everything is perfect in the car. They said that the a/c comes on with air recirculation. I want to hear this from other maxima owners.
Faisal
Old Jun 1, 2006 | 12:07 PM
fhs8860's Avatar
someone...
comeone you guys, u own maximas. Help me out
Old Jun 1, 2006 | 01:21 PM
UGAd13's Avatar
Just out of curiosity...why does it matter? Do you not want to run A/C?
Sorry I can't help you out I have the auto climate control.
Nice diagram though.
Old Jun 1, 2006 | 01:56 PM
TXT-1's Avatar
Maybe it's the remaining cold air from when your AC was on??? The air your feeling coming out is not heated nor cooled. If the inside of your car is hot, than the blowing air may feel colder than your ambient air since it is 92 degrees outside according to your post. Just a thought.
Old Jun 4, 2006 | 03:02 PM
mdloops's Avatar
Originally Posted by fhs8860
Guys and Gals
A/C to OFF
Faisal
Seems somewhat normal to me I guess. I am a little unsure about what the problem is. You do know that there is a big difference in acceleration when the AC is off compared to on right? If you shut off the AC and do not feel an increase in available power your AC might not be off. Conversely, if you turn on your AC and do not feel any kind of added strain on the engine then it may also not be shutting off. Seems like you may be obsessing a little too much over a small amount of cold air coming from the vents.... I do this too over certain things at times.
Old Jun 4, 2006 | 05:25 PM
Ranger Talon's Avatar
More information is needed. What is the air temperature inside the car when the blowers are turned on? What is the temperature of the supply air as it comes out of the vents? As long as the air temp inside the car is significantly lower than the occupant's body temperature, the supply air can feel cool in recirculate mode.
Old Jun 4, 2006 | 06:34 PM
mdloops's Avatar
that one made me LMAO
Old Jun 4, 2006 | 07:40 PM
fhs8860's Avatar
ok
here is the scenario,
i get into my car which is sitting outside in 95F heat.
i turn the fan to 2, recirculation to OFF and i am driving off. there is hot air coming from the vents because right now, the air is being brought from the outside. The temp bar is where i have shown in the pic. Now i turn the recirculation to ON. Now, i do feel the drain in acceleration, cold air coming from the vents. please note that i havent turned the a/c ON and its light is off. if i do turn the a/c on, no difference in the temp of air blowing from the vents, nor any difference in the engines power.
So my guess is that the a/c comes on with recirculation.
I note little things, i just bought this car 3 months ago, and cant bear the thought that there is an electrical problem with the car. the dealer said thats normal behavior for the car. Just wanted to ask the opinion of u guys.
Old Jun 5, 2006 | 01:14 PM
mdloops's Avatar
All recirculation does is stop pulling air from outside through your cabin filter. Instead it pulls air from inside the car, thus recirculation. Still have no idea what the problem is I think your only bet is to take it to a mechanic.
Sounds to me like that is how my car works. Here ia AC in a nutshell: 1) It works and you get cold air, 2) something doesn't work and you take it to a technician who can properly diagnose the problem.
Old Jun 5, 2006 | 11:20 PM
fhs8860's Avatar
I also think this is how the car is supposed to behave.
noticed similar behavior in 2005 civic also.
Old Jun 6, 2006 | 08:24 AM
weshaley20's Avatar
When my air unit if off, I still feel cool air coming from the under-dash vents. I think it is fairly normal.
05RLS2
Sep 27, 2015 09:24 PM
mclasser
Sep 24, 2015 11:57 PM
homewrecker
Sep 24, 2015 07:01 PM
EdRomo86
Sep 12, 2015 07:49 PM
Maxima30
Sep 7, 2015 06:13 PM
