How Do I Advance My Timing?
#45
Originally Posted by reyrey
Where did you buy the consult 2 and how much did they want for it?
the timing increase is not an earth shattering mod, i noticed better low end response and better overall mileage. another way to increase more important timing is to have a fpr and bump up the pressure, then use an afc/emanage/etc to back the fuel out.
#50
Originally Posted by siren001
Hawaii has E10 so 92 is actually higher than that in octane. So would you guys not recommend 18degrees?
#51
In Central Jersey, they only have 93 as best option for fuel. Should I have 20 degrees or 17 done on my 02 SE? And how much mileage increase would I see? Also, anyone know any dealerships in Central Jersey who does the advance?
#52
#55
I'm actually going in for a 100-point inspection for free from the dealership I bought it from. Should I just talk to the tech who's gonna be doing it?
#56
Originally Posted by sloppymax
i did not buy the consult. i paid a shop 25 bucks to mess around with it for around 20 minutes. from what i have heard, they cost several thousand dollars. if you go above 17 degrees then you will have to do the idle air learning procedure. i always run 93 but i wouldnt advise running above 17 degrees without 93. i say this because 93 isnt available everywhere.
I will try the second suggestion later. By how many points is the suggested bump to the fuel pressure? Thanks again for the help
#64
Originally Posted by FriscoMaxima
the octane number is not the percentage of octane is gasoline
#65
seems simple to me http://auto.howstuffworks.com/question90.htm
#66
makes sense to me
Octane is an alkane with the chemical formula C8H18. It has 18 isomers.
One of the isomers, 2,2,4-trimethylpentane or isooctane, is of major importance, as it has been selected as the 100 point on the octane rating scale, with n-heptane as the zero point. Octane ratings are ratings used to represent the anti-knock performance of petroleum-based fuels (octane is less likely to prematurely combust under pressure than heptane), given as the percentage of 2,2,4-trimethylpentane in an 2,2,4-trimethylpentane / n-heptane mixture that would have the same performance. It is an important constituent of gasoline.
Octane has 18 isomers :
* Octane (n-octane)
* 2-Methylheptane
* 3-Methylheptane
* 4-Methylheptane
* 3-Ethylhexane
* 2,2-Dimethylhexane
* 2,3-Dimethylhexane
* 2,4-Dimethylhexane
* 2,5-Dimethylhexane
* 3,3-Dimethylhexane
* 3,4-Dimethylhexane
* 2-Methyl-3-ethylpentane
* 3-Methyl-3-ethylpentane
* 2,2,3-Trimethylpentane
* 2,2,4-Trimethylpentane (isooctane)
* 2,3,3-Trimethylpentane
* 2,3,4-Trimethylpentane
* 2,2,3,3-***ramethylbutane
* Octane (n-octane)
* 2-Methylheptane
* 3-Methylheptane
* 4-Methylheptane
* 3-Ethylhexane
#68
Originally Posted by NEED2BFAST
Soonerfan, I'm impressed, very smart. A+++ in schooling me in chemistry.
Knowledge IS power.
Knowledge IS power.
http://en.wikipedia.org/wiki/Octane
#69
Originally Posted by soonerfan
Starrider
09-17-2015 07:26 AM
rbaker100
08-31-2015 11:09 AM
