2000 Torque Specs for Wheel Nuts
Old Jun 11, 2006 | 09:31 AM
trigger005's Avatar
on a 2000, is it 72-87 ft-lbs all around?
Old Jun 11, 2006 | 09:35 AM
BRINKLEY's Avatar
I always thought it was tight right before you started to pass out? lol check your manual, I think its in there but I would think 72-87 would be more than plenty.
Old Jun 11, 2006 | 09:42 AM
trigger005's Avatar
manual says that for the front axle but doesnt specify for the rear
Old Jun 12, 2006 | 04:53 AM
Puppetmaster's Avatar
I use 80 lbs all round, per the manual.
Old Jun 12, 2006 | 06:44 AM
9DTALON's Avatar
I'm paranoid after almost losing a wheel on my DSM. I always do an even 100ft. lb. And put anti seize on your lug studs to get a more even torque.
Old Jun 12, 2006 | 10:38 AM
myktek's Avatar
80lbs according to the manual, but i do 85lbs just in case....
Old Jun 12, 2006 | 03:08 PM
SgtSchulze's Avatar
Burn Dust. Eat my rubber.
I haven't had any issues.
Old Jun 12, 2006 | 03:14 PM
spdfreak's Avatar
I hope you don't strip the threads out one day and kick your self in the butt
85 sounds correct.
Old Jun 12, 2006 | 03:36 PM
5thgenmaxima's Avatar
80 is accurate. No need to over-tighten just to "be safe". With the potential for lawsuits the manufacturer is already being MORE than safe.
Old Jun 12, 2006 | 03:48 PM
Ammi's Avatar
350 Detroit Muscle
Same here. I use 80 lbs for all my cars.
Old Jun 12, 2006 | 04:46 PM
00MaxSE's Avatar
Pointy Elbows
I do 85 lbs.
Old Jun 12, 2006 | 05:09 PM
steven88's Avatar
Need A Light?
i do 80lbs...it works great...and never had a problem loosening them either...
sometimes you get those tire shops who over tq it with an air gun...and its soooo hard to remove afterwards...its like breaking loose a suspension bolt!
Old Jun 12, 2006 | 06:34 PM
I checked my torque stick with my wrench. They tighten the lugs to about 93 LBS. Never had a problem with one snapping or stripping after 15 + rotations, but they are tighter than specs. (A little over isn't really a big deal as long as they are all tightened the same amount IMO) more of a pain in the *** for you. hehe
Old Jun 12, 2006 | 06:52 PM
steven88's Avatar
Need A Light?
after going through some stripped lug studs, I'm never tightening them over 80lbs anymore...I probably went 100+ accidently becuz I was probably pissed this one time....welp, it cost me two new studs...oh well....you live and you learn
80 is what the FSM calls...i'll prob go to 90 at the absolute max...cuz i know after that, it will break!
lowpost99
Oct 26, 2025 06:53 PM
dcam0326
Sep 8, 2015 11:02 PM
jfl330
Sep 4, 2015 01:44 PM
Samedi
Sep 3, 2015 01:07 PM
