Clutch Pedal squeak????
Old Jun 13, 2006 | 02:56 PM
Bulldawg's Avatar
When I push the clutch pedal in on my 2k2 I get a squeak/grinding....I followed the noise up to the engine where the little pivot fork is and it seems as if something behind that little rubber boot on the tranny housing needs to be lubricated, just kinda wondering if anyone has ran into this before and what I need to do to fix it.
Old Jun 13, 2006 | 03:01 PM
SoonerFan's Avatar
Cletus
squeak? or howl?
http://maxima.theowensfamily.com/tsb/NTB02-084.pdf
Old Jun 13, 2006 | 03:07 PM
Bulldawg's Avatar
thanks but I have already had that TSB performed.
It isn't an issue with the clutch persay, mainly the pivot fork. It will make the same noise when the car is off and nothing is spinning. I just found my old ESM and it shows to grease the pivot fork with "Lithium Based grease including molybdenum disulphide". Just want to know if anyone has done this and how to get in there to grease it??? Should be pretty easy since it is a regular maintenance thing.
Old Jun 13, 2006 | 03:12 PM
MyBlue02's Avatar
http://forums.maxima.org/showthread.php?t=476001
your not alone brother i can't tell if its the fork pivot...or the slave piston/fork contact area...i do get a wierd clicking noise as i accelotate...but i think its the factory flex since the car was lightly tapped in the back (one tip is pusshed in
let me know what hwe have to do to fix it cause its anoying!
Old Jun 13, 2006 | 04:14 PM
crazy97's Avatar
This is common in the 4th gens and now it's a 5th gen problem too?
I have this squeek also but I'm not going to risk spraying anything into the tranny and risk getting anything on the clutch disk.
Old Jun 13, 2006 | 04:47 PM
MyBlue02's Avatar
lol..now my squeek is gone but the clicking is louder (prolly the preasure plate fingers)
i do notice the squeek goes away after the car is a little warm
Old Jun 13, 2006 | 05:09 PM
Barc's Avatar
Mine squeaks every now and then and ticks every now and then and has done so for at least 45K miles. I remember a thread a while back about it and most everyone seemed to think that a) it wasn't hurting anything (probably) and b) it was probably not the pivot fork. Anyone else care to chime in?
Old Jun 13, 2006 | 05:40 PM
Chris.s's Avatar
I also have this quite squeak intermittently on my 2k2. Sound is exactly the same while idling and with engine off. I just figured that the fork was dried up on its pivot point. Something that wouldn’t get fixed until my next clutch.
Old Jun 13, 2006 | 08:44 PM
Bulldawg's Avatar
If anyone who has some way to get a pdf on this forum and email that i can send them the pdf from my ESM then i, will be able to show you where to lubricate the problem area at. I am about 98% sure that my particular noise is coming from the "withdrawal lever" where it mounts to the "release Bearing" , items 9 and 10 on the PDF file. The manual shows that these areas require lubrication.
So if someone has a way to get it uploaded to here then shoot me an email and I will send it along so we can all look and possible come up with a way to get rid of this annoying problem.
BTW if anyone else has an ESM it is page 5 under the Clutch Section(CL)
Old Jun 14, 2006 | 02:43 PM
MyBlue02's Avatar
gtpunderboost@optonline.net and i can get in on here
Old Jun 14, 2006 | 04:39 PM
2k2nismo.PL's Avatar
my 2k2 does the same thing but only when i beat on it time to time after it sits for about an hour it goes away ?????????
Old Jun 14, 2006 | 05:12 PM
BLK2BLU's Avatar
10 ch
Old Jun 14, 2006 | 06:50 PM
Barc's Avatar
So, from looking at the manual, you would have to remove the clutch disc (13) and the clutch cover (12)? Then lubricate parts 9 and 10?
Old Jun 14, 2006 | 06:55 PM
Barc's Avatar
If that doesn't work...
http://img143.imageshack.us/img143/7...titled20yh.jpg
Old Jun 14, 2006 | 07:21 PM
Chris.s's Avatar
Your suspicions are prob correct. This was my first guess. Only problem is how to lubricate that point without taking the trany out.
Old Jun 15, 2006 | 11:51 AM
jimmycapp's Avatar
mine creeks like a dry hinge.
Just havent tried to grease it yet
James
Old Jun 15, 2006 | 03:46 PM
MyBlue02's Avatar
my crap is acting up..won't le me convert to jpeg
ef9
Oct 4, 2015 08:43 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
