Whats wrong? Slower than a 4th gen....
Old Jul 9, 2006 | 10:16 AM
rmh3093's Avatar
Only gentoo powered Maxima!
So last week sometime I raced a 4th gen and lost by about 0.5-1.0 car lenths; we went up to about 80mph. Whats wrong? The driver of the 4th gen said he had a cat back and ecu but still, shouldn't I have won, or at least been closer? I was thinking it might be my VIAS but can accelerate all the way to redline. I have disconnected the cables to my VIAS and can tell no difference when I pass 5k rpm though. I have 94k miles on my car and was thinking maybe my spark plugs could be causing timing issues though out the entire powerband. I dont know though.... any input would be appreciated
Old Jul 9, 2006 | 10:30 AM
sciff5's Avatar
Why do you think you should have won? you have more HP but your car is also heavier. If you were a 5.5 gen than I would say yes something is wrong there
Old Jul 9, 2006 | 10:36 AM
MaxBoost925's Avatar
Drug Money
remove cables?
those are vacuum lines. it should make your car EVEN slower since the VIAS doesn't know when to open and it stays closed throughout the RPM range.
what you should do is remove the power valve. you'll notice power right away. in fact i was REALLY impressed by that mod.
Old Jul 9, 2006 | 10:47 AM
ChromeSE5's Avatar
Originally Posted by MaxBoost925
remove cables?
I think that is what he means. He means that he tried testing the VIAS by removing the vacuum cable witch activate it and he couldn't tell a difference so he doesn't think the VIAS is broken.
Old Jul 9, 2006 | 11:15 AM
rmh3093's Avatar
i though the MEVI was activated by the vacuum and the 00vi was activated by the ECU, there are electical harnes connectors connected to the VIAS which I disconnect (not hoses). Did I disconnect the wrong thing to test the VIAS?
Old Jul 9, 2006 | 11:16 AM
rmh3093's Avatar
whats the weight difference between the 4th and 5th gen?
Old Jul 9, 2006 | 11:21 AM
SoonerFan's Avatar
Cletus
street racing FTL
Old Jul 9, 2006 | 11:22 AM
SoonerFan's Avatar
Cletus
www.google.com
Old Jul 9, 2006 | 11:36 AM
monty31's Avatar
Most of the 4th gens had a better power/weight ratio than the 5th gens. Especially a fully loaded SE with 17" wheels.
Old Jul 9, 2006 | 12:51 PM
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
very true. rmh3093- consider racing someone is not that great of a benchmark for comparison. you said you ran to 80, everything from traction to maintenance to shiftpoints could come into play. if you think you are low on power then get a dyno done. you can see where/if you are losing power. very quick way to determine if the vias is not functioning. even with a broken vias, it will accelerate all the way to redline but with poor efficiency. btw, if your plugs havent been changed at 94k miles then have that done soon along with the fuel filter.
Old Jul 9, 2006 | 08:41 PM
carsarecool's Avatar
I have a 2k1 SE, 17's and 5 speed and my buddy has a 97 GXE auto 15" steelies but its been through a LOT of maintenance, great condition, if we go from a roll i get him by about a half to one car and from a stop it goes either way honestly, if i get a good launch and so does he though i usually pull ahead through second
Old Jul 10, 2006 | 09:26 AM
NmexMAX's Avatar
dot dot dot ...
Unless you have a dyno proving a definate powerloss, then
Old Jul 10, 2006 | 04:26 PM
rmh3093's Avatar
there is a place back in buffalo i can get 3 pulls for $50, I will get one this weekend
Old Jul 10, 2006 | 05:00 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
sh$t happens.....
Old Jul 10, 2006 | 05:04 PM
NYPD-Arnold's Avatar
Z
250lbs should not negate a 32HP advantage. Period.
Old Jul 10, 2006 | 05:11 PM
NmexMAX's Avatar
dot dot dot ...
Maybe the dude you were racing was an anorexic
Old Jul 10, 2006 | 05:15 PM
Z
Or the other way around? What do you weigh, RMH3093? =P
Old Jul 10, 2006 | 06:07 PM
sciff5's Avatar
Its not that simple.. I meen if these were both manual tranmission cars, and the 32HP is only observed higher in the rpm range that 32 hp could be completly lost by not shifting late enough, and the extra weight would slow you down
Old Jul 10, 2006 | 06:19 PM
rmh3093's Avatar
180.... and i have a heavy *** sub box with dual 12s and 2 amps
Forge277
Jun 13, 2016 09:26 PM
BobTX10
Oct 7, 2015 08:43 AM
bigfrank
Oct 1, 2015 12:51 PM
worldwiderecognized
Sep 24, 2015 06:56 PM
