Full time VAIS
Old Jul 10, 2006 | 06:26 AM
beancooker's Avatar
Full time VAIS
Has anyone tried to bypass the vacuum actuator on the VAIS to keep the VAIS open all the time. It can be done easily with a short piece of wire. Will this add to the HP?
Old Jul 10, 2006 | 07:01 AM
9DTALON's Avatar
Are you talking VAIS or the SCV valve. The VAIS is the fully electric valve on the driver side. The SCV valve is the vacuum actuator on the pass side. The SCV is a Swirl Control Valve. The idea for the SCV as I understand is to swirl the incoming air from the intake runners before it enters the intake port area. This swirling effect is supposed to increase the effeciency of the air-fuel charge to the cylinder. At higher RPM's though it is open completely and is a minimal restriction. But you could always try it out to see how it reacts. I'd be interested to know.
Old Jul 10, 2006 | 07:31 AM
beancooker's Avatar
The VAIS (drivers side just in front of the throttle body) which opens up at 5k RPM. But if it was open at a lower RPM would I gain any power?
Old Jul 10, 2006 | 07:56 AM
ChromeSE5's Avatar
yes you can but you will have a tq penalty below 5k rpm. According to those who have done it though, it is suppose to be a screamer above 5k rpm.
Old Jul 10, 2006 | 08:04 AM
Kevlo911's Avatar
Kevlo for President
I would be better to take the rod out instead of keeping it "open" at all times.
Old Jul 10, 2006 | 09:23 AM
NmexMAX's Avatar
dot dot dot ...
Keeping it open all the time you lose tq below 5k, and gain nothing after 5k, taking the rod out you lose tq before 5k and gain a little bit above.
Old Jul 10, 2006 | 11:20 AM
beancooker's Avatar
How much TQ do you lose, a lot or not enough to notice???
Old Jul 10, 2006 | 11:36 AM
MaxBoost925's Avatar
Drug Money
not too much torque. but you definitely can notice it.
the high end power is incredible.
Old Jul 10, 2006 | 11:42 AM
Progress's Avatar
It's business time.
I say we all take our rods out.
Old Jul 10, 2006 | 11:56 AM
Drug Money
sloppymax's Avatar
IMBOUTTOBUSTSOMEGHOSTS
my dynos showed around a 10-14lb torque loss across the board til 5k where the power band is moved to. i think i made around 15lbs of torque more at redline. the hp is only slightly higher than one with a properly working vias.
Old Jul 10, 2006 | 03:12 PM
xlcrew's Avatar
I’m Back
yeah i showed 15lb loss across the board. i don't think it's worth the loss. it screamed up top, but not enough to off set the torque loss in my books. and it was dynoed on the same day when i took it out. my HP numbers were better, but that's because it wasn't working on my first two runs.
Old Jul 10, 2006 | 03:55 PM
SuperStasiu's Avatar
So what about someone running cams or nitrous wouldnt they benefit from this. What about takeing out the rod and putting in bigger injectors?
Old Jul 10, 2006 | 05:16 PM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by xlcrew
yeah i showed 15lb loss across the board. ................... it screamed up top
That makes no sense.
That wouldn't do anything but make it run richer (N/A of coruse)
Old Jul 10, 2006 | 05:18 PM
steven88's Avatar
Need A Light?
i wish i had a full time VIAS
Old Jul 10, 2006 | 05:21 PM
NmexMAX's Avatar
dot dot dot ...
Then it would eliminate the "V" in VIAS...
Old Jul 10, 2006 | 06:55 PM
xlcrew's Avatar
I’m Back
how does that not make sense. it lost torque but gained hp. the car ran hard all the to redline from 5000 but before that it was a dog. now if i could rev my car to 7200 then i think i would keep the valve out because the car would continue to make power. but it doesn't so i'll keep it in.
Old Jul 10, 2006 | 07:01 PM
NmexMAX's Avatar
dot dot dot ...
If it lost 15 ft/lbs across the board then it NEVER showed a gain in hp or tq.
Across the board, to me, means over all RPM points.
Old Jul 11, 2006 | 05:07 AM
sloppymax's Avatar
while you do lose torque in certain rpms, remember since horsepower and torque have a relation, that the torque is higher where the hp is higher.
Old Jul 11, 2006 | 05:20 AM
Deckdout2's Avatar
Play with my balls
That sounds made up.
Old Jul 11, 2006 | 05:40 AM
NmexMAX's Avatar
dot dot dot ...
Some ancient greek physicist made it up and we believe him sloppy is his predecessor, just passing the word.
Old Jul 11, 2006 | 05:59 AM
Progress's Avatar
It's business time.
True. Especially if horsepower is higher at 5,200 RPM.
Old Jul 11, 2006 | 07:31 AM
NmexMAX's Avatar
dot dot dot ...
I make more torque at 1200 than I do at 7000 but @ 7000 my HP is much higher than my tq
Old Jul 11, 2006 | 07:33 AM
sloppymax's Avatar
thats because you got the JDM option.
Old Jul 11, 2006 | 11:19 AM
beancooker's Avatar
What JDM option?
Old Jul 11, 2006 | 03:34 PM
lol
Old Jul 12, 2006 | 03:38 PM
VaporHead
You guys get to 7000k RPM? at the track? I don't think mine has never reached over the red line.
Old Jul 12, 2006 | 03:48 PM
beancooker's Avatar
Don't know how, my redline is 6500rpm. must be a TCM mod or electronic upgrade.
Old Jul 12, 2006 | 03:49 PM
sloppymax's Avatar
you are just bitter cause you dont gotz da jdm.
VaporHead-the reason NmexMAX is reving that high is because the technosquare ecu.
Old Jul 12, 2006 | 04:02 PM
steven88's Avatar
Need A Light?
i can rev my car to 6900...and i have a stock ecu
Old Jul 12, 2006 | 04:12 PM
NmexMAX's Avatar
dot dot dot ...
You must have the JDM option too..
Both my A's are JDM y0!
Old Jul 12, 2006 | 04:30 PM
sloppymax's Avatar
speedo error ftl. ive seen my tach goes as high as 6800 on stock ecu but both vafc and obd scan said a few hairs under 6600.
Old Jul 12, 2006 | 04:36 PM
NmexMAX's Avatar
dot dot dot ...
The A32 tach has always been faithful to me. I have a 7200 shot but its at work
Old Jul 12, 2006 | 04:56 PM
steven88's Avatar
Need A Light?
wow, SES on both of your cars FTL
Old Jul 12, 2006 | 05:05 PM
NmexMAX's Avatar
dot dot dot ...
I was wondering who the 1st to notcie that was going to be
Matt93SE
May 24, 2019 02:58 PM
Matt93SE
Apr 8, 2018 09:23 AM
vingodine
45
May 21, 2016 12:46 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
