Exhaust leak :(
Old Jul 11, 2006 | 08:14 PM
jdmaxima89's Avatar
On the pedobear bandwagon
Exhaust leak :(
Well after annoying me for about a week... I finally got my car on a lift so that I could figure out where my exhaust leak was coming from. It's coming from the flange where the pipe starts to go above the axle. Living in Illinois... it's rusted pretty bad anyways... Should I just break down and get either the Cattman or Budget bpipe(I think that's what I need)? Any other brands? Just get the OEM replacement (@ dealer cost)? Let me know what you guys would do. I've already got a Ypipe and muffler....
Thanks.
Old Jul 11, 2006 | 08:30 PM
DrKlop's Avatar
Driving is the next best thing
You could get it rewelded for like 40 - 50 bucks.
I had the same exact problem, and for some stupid reason I ended up buying a rear section from Cattman. (instead of going the right way) Off course, now my car sounds much better, looks better from the rear and even pulls a little better at the top of the RPM range; but does it worth $400?
Old Jul 11, 2006 | 08:35 PM
upstatemax's Avatar
A Cattman muffler will gove NO noticable gains. If anything in a Cat-back gives any form of gain it is the B-Pipe and that is only max 5hp. You only have the Muffler, sorry to rain on your parade, but that perfomance gain is in your head...
Old Jul 11, 2006 | 09:26 PM
DrKlop's Avatar
That's exactly what I thought when my exhaust was fully stocks. I was not expecting any performance gains when I was buying it, but yet I felt the difference. It didn't change anything under 5k but with open VIAS it does pull better than stock. Well, at least that's what I think, and it's definitely not placebo because, as I said before, I did not expect to see any difference.
Old Jul 11, 2006 | 09:36 PM
upstatemax's Avatar
I have Headers, HF Cat and a Cattman B-Pipe and I felt NO difference when I pulled off my Cattman Muffler to back on a stock muffler.
So if anyone if going to feel a difference between a stock and Cattman muffler it will be me.
Old Jul 11, 2006 | 09:38 PM
upstatemax's Avatar
Thanks.
If you can spring for the Cattman B-Pipe just do it...
Old Jul 11, 2006 | 10:06 PM
DrKlop's Avatar
that's all I can say. lol
Old Jul 12, 2006 | 03:26 AM
Progress's Avatar
It's business time.
Why would someone with other exhaust mods feel the affect of another mod over someone with a stock setup?
Old Jul 12, 2006 | 06:09 AM
Pri63's Avatar
Might want to check out a thread I started late last year. Should be helpful and most importantly is cheap and DIY.
http://forums.maxima.org/showthread.php?t=445956
Old Jul 12, 2006 | 06:34 AM
Progress's Avatar
It's business time.
OT: Whatever happened to your most recent leak?
Old Jul 12, 2006 | 06:49 AM
jdmaxima89's Avatar
[QUOTE=DrKlop]You could get it rewelded for like 40 - 50 bucks.QUOTE]
I don't really think that is an option. It's rusted pretty badly... I think I'm gonna go ahead and spend the $275 for the Cattman Bpipe. If I'm correct... that replaces from the cat... all the way to the flange on the muffler... right?
Old Jul 12, 2006 | 07:08 AM
upstatemax's Avatar
Yes it does.
Old Jul 12, 2006 | 07:11 AM
upstatemax's Avatar
If it was that restricitive it would show up even more with the increase of flow from the other mods.
Old Jul 12, 2006 | 07:14 AM
jdmaxima89's Avatar
Well... Brian Cattman is going to call me back, but his Bpipe is 275 + shipping. Budget would be 290 shipped, but that is Canadian dollars... so roughly 255 shipped US. I don't know which one I'm going to go with yet... but is the Bpipe going to change the exhaust tone? I mean, it will obviously be different than a leaky exhaust, but will it change the sound of the setup I had before?
Old Jul 12, 2006 | 07:56 AM
Pri63's Avatar
took it to smith's in convington. They told me I had a leak in front manifold and where the front manifold connects to the y-pipe. They said they wouldn't fix it because of something to do with steel bolts in an aluminum block. So i said f it. I got home and looked at the exhaust diagram in the Nissan Service Manual I realized I never put the gasket back where y-pipe connects to the manifold when I originally did the install. I did that this weekend and the car sounds amazing now, a lot quieter and doesn't pop like it used it.
Old Jul 12, 2006 | 08:16 AM
Progress's Avatar
It's business time.
Sweet!
That's odd about steel bolts in an aluminum block. What would the block have to do with taking the y-pipe off the exhaust manifolds? Anyway, cheers to fixing it. Jeers to forgetting the gasket in the first place. You have the Cattman Y, right?
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Justin Kroll
Oct 1, 2015 07:03 PM
09maxshawn11
Sep 30, 2015 10:28 AM
Socalstillen
Sep 26, 2015 12:01 PM
