help with angel eyez
Old Jul 14, 2006 | 06:18 PM
STyLeZ4o1's Avatar
okay I just had some professionals insall my headlights with the dde's yesterday. Now im really mad because 2 angel rings went out. 1 in each headlight. 1 is not as bright and the other is flickerin a bit. Could this be a wiring problem? or do u guys think i need new rings? I hope its a wiring problrm because i really don't want to pay these people more money to take it apart and what not. I paid too much already. thanx
Old Jul 14, 2006 | 06:23 PM
MAXRB8's Avatar
If these guys are "profenssionals" odds are it's the rings if one in each side is working properly. Umnitza's?
Old Jul 14, 2006 | 06:30 PM
STyLeZ4o1's Avatar
yeah these are umnitzas. Has any1 had this kinda problem? Especially 2 rings in 1 night?
Old Jul 14, 2006 | 11:51 PM
xnyc's Avatar
might be the inverters. the angel eyes i have flickered before the inverter went.
Old Jul 15, 2006 | 12:07 AM
MaxBoost925's Avatar
Drug Money
LED FTW.
i dont want to open headlights over and over so i decided not to get DDE's
Old Jul 15, 2006 | 12:31 AM
Elfzors's Avatar
Could be the inverters, or it could be the angel eyes themselves. I installed some on my friends car, and they all burnt out within a week. Bad batch i guess.. Good luck with resolving the issue.
Old Jul 15, 2006 | 12:32 AM
Maxima112's Avatar
Curb Rash Repair 100 a wheel
check the wiring. if you they didnt wrap them up in electrical tape and you got water in there some how...like washing the car.....then the pos and neg are touching (water in between).....hard wiring them is the best bet with shrink wrap....that will prob solve the flickering one, but if one is already burnt then its too late..you'll have to get a new ring looks like...also seal up the ballast with some silicone...
Old Jul 15, 2006 | 12:33 AM
Maxima112's Avatar
dispite what people say i think DDES are the best (in non cold weather, yay! for so cal) you just gotta do all the little things to make is last....hardwire and silicone.....3 years and running *knock on wood*
Old Jul 15, 2006 | 07:02 AM
TheBigDu's Avatar
Back when I installed mine, I cut the dust cover back a little bit for the wires to pass through the back of the headlight. When I did this, it left a sharp edge on the plastic, and at some point in the first few days, one ring got very very dim and had a little burnt spot on it. Turns out the plastic cut through the insullation and shorted out the ring. That sucked because I had to open the headlight again to replace it. Since then (over a year now) the DDEs have worked fine. I would say they look great too, but the replacement ring I got has started to rust or something at the ends where the wires connect (not sure if there's metal there so it might not be rust but it's something brown and is getting darker). Also, my headlights decided to start letting moisture in again. Yay.
Old Jul 15, 2006 | 08:01 AM
Crooklyn's Avatar
I bought CCFL angel eyes, They sell em in colors too I have seen red & blue I bought the white ones. About to install them. maybe today..
http://pg.photos.yahoo.com/ph/crookl...nm=8015re2.jpg
http://pg.photos.yahoo.com/ph/crookl...nm=12afre2.jpg
Old Jul 15, 2006 | 09:05 AM
CKOTuHA's Avatar
Mine have the same thing. I think its because of HIDs. It just gets hot and eventually rubber gets burned. There is nothing you can do about it.
Old Jul 15, 2006 | 11:14 AM
STyLeZ4o1's Avatar
Whats the inverter? Im not electrical or car smart. If so i wouldn't have paid these people to get these done for me. The guy also said I might have bad ballest's.
Old Jul 15, 2006 | 11:54 AM
xnyc's Avatar
the inverters convert your dc power source (your battery) into ac. basically a dc-ac converter
Old Jul 15, 2006 | 03:31 PM
STyLeZ4o1's Avatar
could it be the ballest by any chance?
Old Jul 16, 2006 | 05:46 AM
norvelly's Avatar
dde's
check the wiring. mine have been doing the same thing. If you get water on them I think this problems occurs. Take the time to hard wire them. Hope things work out for you.
Old Jul 16, 2006 | 11:25 AM
bugbite77's Avatar
to see if its the ballest, take the wores off the good ring, and ut them on the bad ring, if the bad ring lights up, its your ballest, they should be all hard wired, no dumb black clip connectors. New ballest is $35 from umnitsa.
Old Jul 16, 2006 | 05:10 PM
STyLeZ4o1's Avatar
Ok, I did this already and its the same problem. So im guessing its the damn bulbs. It hasn't rained since I had them installed so it couldn't be water. Only thing I can think of is to hardwire the ballest to the rings but I doubt that'll do anything. Oh btw the bulbs that are bad were the replacement rings. Does umnitza give out bad replacement rings or something because I remember reading something about they were'nt as good as the original one's that you get. Now I gotta pay these people again to open the damn thing up and replace the rings on both headlights. Dammit. I hope umnitza replaces the rings for free. Thanks guys....
Old Jul 17, 2006 | 10:26 AM
bugbite77's Avatar
be firm, they will say "y didnt you check the rings first" which im sure the installer did (since he is "professional") and tell them you want new rings for FREE
Old Jul 17, 2006 | 01:53 PM
STyLeZ4o1's Avatar
Do u guys see anything wrong with this picture? Someone said the ring blew because it was touching the metal part. I'm thinkin the metal part damaged the wire. Any ideas? The 1 on the left isnt working but the right 1 is.
umnitza
Sep 1, 2015 01:03 PM
Car Addict
Audio/Video/Electronics
Aug 27, 2015 09:01 AM
Y2KevSE
72
Aug 4, 2008 08:21 PM
SteVTEC
Feb 5, 2003 09:08 AM
stock6speed
Feb 3, 2002 07:52 PM
