Catman/Progress RSB is in...wow!
Old Jul 16, 2006 | 11:50 AM
MyBlue02's Avatar
now this is how the car should have handeled from the factory...thet rear is so much more surefoot feeling...feels like its more in control and not as confused in the turens....
next up illum's/ebiach's...maybee a stage 1 subframe
Old Jul 16, 2006 | 12:35 PM
Jung Yun's Avatar
:-D i loved that feeling when I first put mine on
Old Jul 16, 2006 | 12:37 PM
sciff5's Avatar
Sounds like your future modding process is similar to mine. I felt the exact same way about the RSB. To me there is no reason it shouldent have been there from the factory, it deff made a large difference.
I can say that with the Eibachs/Illuminas, SFCs, RSB, and FSTB no one riding in the car has ever commented about the car riding hard. Most people dont even know how high the limits of the car are untill I push it fast into a corner at which point people get nervous but are soon surprised that the car just swallows the corner without a peep. I am pretty happy with its performance.
Old Jul 16, 2006 | 12:42 PM
ShIft_uR FacE's Avatar
Sorry but...what is an SFC??
Old Jul 16, 2006 | 01:20 PM
RLW001's Avatar
Subframe Connector: {img} http://memimage.cardomain.net/member...2340299_28.jpg {/img}
Old Jul 16, 2006 | 05:35 PM
Whtmax'01's Avatar
Since this is a RSB thread i would like to know how do those with RSb jack up the rear of their cars with the RSB in the way?
Old Jul 16, 2006 | 05:39 PM
Lontar1's Avatar
Puerto Rico-Maxima Lover
best money ever spent
Old Jul 16, 2006 | 05:40 PM
sciff5's Avatar
It is kinda a pain in the a$s, but I have 2 jacks and I use the rear jacking points in front of the rear wheels. Once the car is up in the air there is enough space on the rear beam between the inside of the wheels and either end of the RSB that you can fit a jackstand on either end.
Old Jul 16, 2006 | 07:03 PM
carsarecool's Avatar
How long does this take to put in? Ive been thinking about getting one, the responses from you guys are rediculous, now i really want one cause it seems like one of the best ways to improve handling short of lowering springs/struts
Old Jul 16, 2006 | 07:09 PM
02maxxxSE's Avatar
If only installing one, which of the two improves handling the most, FSTB or RSB?
Old Jul 16, 2006 | 07:12 PM
sciff5's Avatar
Not even a contest the RSB FOR SURE!!
Old Jul 16, 2006 | 08:40 PM
MaximusMorpheus's Avatar
I've been meaning to get a RSB since it gets good reviews. What is the best place to buy a RSB? Thanks.
Old Jul 16, 2006 | 08:57 PM
CKOTuHA's Avatar
Would I feel a huge difference if I already have Illuminas set on 5 with H-techs and FSTB?
I don't want to get it if its small of a difference
Old Jul 16, 2006 | 09:42 PM
sciff5's Avatar
Well I have Eibachs, and illuminas set to 5 with a RSB and I still think my car rolls quite a bit compared to most every sports car I've been in. So for me its a must, regardless of suspension setup.
Old Jul 17, 2006 | 06:37 AM
Puppetmaster's Avatar
Like this:
Old Jul 17, 2006 | 06:59 AM
BigFly_2K2SE's Avatar
I recently installed a new Progress RSB on my otherwise stock 2K2 and was AMAZED at the difference. I have done a few other minor "performance" mods (K&N Filter, GAB intake, Timing advance, Redline MT-90) and noticed very little difference, so I was skeptical about how much I would notice with this one. However the difference the RSB made in reducing body roll and the feeling of understeer was truly phenomenal.
By the way, IMO, this mod isn't just for the performance-oriented driver. My wife, who drives very conservatively, immediately noticed the redued body roll rom the RSB when doing something as simple as exiting in a right-turn lane at normal speeds. Why Nissan wouldn't have done this from factory is a mystery to me.
Old Jul 17, 2006 | 07:24 AM
02maxxxSE's Avatar
eBay is $165 shipped. Is that the cheapest?
edit: Addco RSB for $129+shipping @ shox.com
$139+shipping @ cattman.
anywhere else?
Old Jul 17, 2006 | 07:34 AM
02maxxxSE's Avatar
Originally Posted by RLW001
Is this similar to a BlehmCo Stage II Lower Tie Bar (http://www.mattblehm.com/suspension.htm)?
Old Jul 17, 2006 | 10:03 AM
NisMoN00B's Avatar
+Cru OG
At least an hour. When you get your RSB, check the hardware first and make sure you're not missing a nylock nut or a bolt. I found this out the hard way when I installed mine.
Old Jul 17, 2006 | 10:08 AM
NisMoN00B's Avatar
+Cru OG
By the pictures alone, SFCs and LTBs are completely different units but work in the same principle (e.g. stiffen frame to prevent flex). Installation also is another major difference, BlehmCo's LTB connects with nuts & bolts and an SFC is welded on to the frame.
Old Jul 18, 2006 | 07:40 PM
hogey228's Avatar
Check the group deal section, Brian had a special going. $120 Progress RSB shipped! I think normally it's anywhere from $150-180 shipped. Well worth the money.
Old Jul 18, 2006 | 08:14 PM
footballplyrdan's Avatar
Shouldn't take much more than an hour. I found this installation guide for the addco RSB on 5th gen Maximas: http://www.moodym.com/maxima/tech/addcorsb.html
Old Jul 19, 2006 | 11:33 AM
SoonerFan's Avatar
Cletus
yes, the RSB is great. and you dont need to jack up the car to install it, though it does make it easier
Old Jul 19, 2006 | 03:28 PM
mist max2000's Avatar
The RSB is awsome i felt the same way when i put mine on,..instructions say to take off the rear tires and jack up the car,.. but i jacked it up and left them on,.. took about an hour by myself.. WELL worth the money IMO
Old Jul 19, 2006 | 03:42 PM
sciff5's Avatar
screw that.. get some ramps they make life so easy
Old Jul 19, 2006 | 03:55 PM
DrKlop's Avatar
Driving is the next best thing
How did you guys tighten the trailing arm brackets without taking the wheels off?
I have done 99% of the job on the ramps, but I just couldn't reach some of the bolts with the socket wrench so I also had to jack up the car and take off both of my rear wheels.
Old Jul 19, 2006 | 04:15 PM
n3985's Avatar
大陆弟弟
Two people, one with a crescent wrench, one with a ratchet.
Old Jul 19, 2006 | 04:18 PM
well i jacked it up from the back real high and then put 2 stands up on the sides, and fished aruond with the bolt till i got it to catch lol.. was kind of a PITA at times by myself but it worked out fine ,.. hardest part i think was messing with the brake lines...
Old Jul 19, 2006 | 05:33 PM
SoonerFan's Avatar
Cletus
it can be done alone with the car on the ground. when i went to the salvage yard to take it off my totaled 00, i had to lay in gravel and take it off...what a PITA!!!!
thatcollegestudent
18
Oct 5, 2015 02:29 PM
Cumalot
Dec 16, 2000 11:55 AM
clee130
Nov 17, 2000 12:46 PM
