belt tensioner????
Old Jul 17, 2006 | 06:56 PM
ornery1's Avatar
belt tensioner????
2k max with 70k on the clock, the tensioner seems to be making noise when the ac is on, when off it is quiet, is this common problem????
Old Jul 17, 2006 | 07:04 PM
NmexMAX's Avatar
dot dot dot ...
WHat kind of noise? Maybe the belt needs tightening.
Old Jul 17, 2006 | 07:54 PM
ornery1's Avatar
sounds like a bad clutch fan on an older car, shut ac off and goes away
Old Aug 7, 2006 | 07:47 AM
AcidJake75's Avatar
Mine did the same thing - belts just need to be tightened - no more problem
Old Aug 7, 2006 | 10:17 AM
kcowden's Avatar
Same problem here but not sure what the deflection should be with UDP.... anyone??? For those 02-03 running w/o a UDP the deflection is 4.2 - 4.6 mm. for a used belt. You tighten the adjustor clockwise. Also make sure you loosen the bolt in the center of the pulley itself or any adjustment is pointless.
05' MaximaMan
Oct 8, 2017 06:36 PM
02PearlSE
Feb 1, 2016 12:37 AM
markevans999
Oct 25, 2015 08:27 AM
homewrecker
Sep 24, 2015 07:01 PM
2kmaximel
Sep 24, 2015 03:55 PM
