Creaking noise from rear suspension
Old Jul 28, 2006 | 12:45 PM
beancooker's Avatar
Put Eibach & Illuminas on about 3 months ago. Now when I leave my driveway and drive over the rolled curb the rear suspension creaks, not really a squeak, but not metal on metal sound either. Any ideas???
Old Jul 28, 2006 | 04:23 PM
chigga's Avatar
the same thing happens to my front right ones when I go in or out the driveway. it happens so randomlly that i don't give a ****. lol but seriously i don't know what could be the cause or fix for it
Old Jul 28, 2006 | 07:47 PM
footballplyrdan's Avatar
i had the same problem. I took my max into the dealership for oil change/tuneup and told them about the problem. They did something but it fixed the problem. I don't remember off hand, but ill look up my service records to see what they did to fix it.
Old Jul 29, 2006 | 03:38 AM
cpsmaxima's Avatar
I recently had Tein H Techs and Illuminas installed on my Max and have that same crecking noise in the front suspension also!
How do we fix it? I thought I read a thread that suggested overtightening as a possible cause for noises. I will have a mechanic friend check the torque of the nuts and see if this is the cause and possible solution.
Old Oct 25, 2006 | 05:33 PM
EastSideMaxima's Avatar
A swift Bimmer driver
Bump!
This is happening to my '02 Max with the Tein SS coilovers...
It's coming from the back!
Any more updates on this?
Old Oct 25, 2006 | 06:04 PM
Ephraim's Avatar
try to tighten down all 6 of the nuts for the rear suspension in your trunk, that fixed the problem for me.
Old Oct 25, 2006 | 06:07 PM
what kinda tools do I need for this?
I wanna try to do this on my own to save $$
Old Oct 25, 2006 | 06:09 PM
Ephraim's Avatar
well i believe a 14mm (i think...) long reach socket and a matching rachet wrench will do the the trick. you might also need an extender rod for the socket/wrench.
Old Oct 25, 2006 | 07:58 PM
steven88's Avatar
Need A Light?
yes a 14mm is necessary...and a deep socket for the center nut (the one on top of the strut)
btw, I tried this awhile back, and it didn't work for me...I still get the creaking...argh...I even pulled apart the suspension to see what is wrong...nothings wrong as far as I can tell...!!
Old Oct 25, 2006 | 08:08 PM
A33 VQ30DEK's Avatar
might be your strut mounts
Old Oct 25, 2006 | 08:30 PM
lowincash's Avatar
No More Maxipad
gee my suspension is stock and i get this creaking too nothing bad but kinda annoying sometimes haha oh i think mine started to be more noticeable after i hit the curb with my right rear wheel while making a right turn i'm going to have the shop take a look at it when i get my next tune up =/
Old Oct 26, 2006 | 02:34 AM
thanks boys! Im going to start this by tightening the nuts and go from there
Old Oct 26, 2006 | 06:36 AM
steven88's Avatar
Need A Light?
it seems like a few people in this thread have REAR creaking noises....anybody else? I'm wondering if this is common..post up your suspension setup as well
EastSideMaxima - do the tein SS coilovers require you to reuse your stock spring hats?
Old Oct 26, 2006 | 07:33 AM
NISMAX03's Avatar
Just the other day I started to get a creaking noise from my rear passenger side. I have S-techs with Illuminas set at 3.
Old Oct 26, 2006 | 01:17 PM
steven88's Avatar
Need A Light?
dude...thats where i'm getting it from too! pass rear...under what conditions can you hear it?
with me, you can roll in 1st gear and drag the car...and as the car bucks back n forth...you can hear it the loudest...then when you drive at 40mph and hit small bumps on the road, you can also hear it squeak...etc
Old Oct 26, 2006 | 01:31 PM
NISMAX03's Avatar
I hear it whenever the suspension is active. While I am driving on a smooth road without bumps, there is no noise. The harder the suspension is used the louder the noise.
Old Oct 26, 2006 | 05:54 PM
steven88's Avatar
Need A Light?
i went out and tried this earlier...i can't torque the center nuts (the ones on the strut hats)...they seem to twist along with the piston when I try to ratchet it
as for the side nuts...they were all pretty tight...I torqued them at 20-25lbs (according to the FSM)..actually I didn't even do anything...cuz when I went to tighten them, they were already at the specified torque...
Ephraim - how tight did you go?
Old Oct 26, 2006 | 06:27 PM
Kruppa's Avatar
I get the same creaking sound from the rear passenger suspension with H-Techs and Illuminas...but only when it's cold...haven't been able to figure it out
Old Oct 26, 2006 | 06:34 PM
steven88's Avatar
Need A Light?
mine usually happens any temperature.
can you hear it in the parking lot, low RPMs, when you throttle and buck the car?
Old Oct 26, 2006 | 07:23 PM
Hey man
I am not too sure... cuz I had this shop do the install for me...
I do remember that they ended up using some stock parts though...
Matt93SE
May 24, 2019 02:58 PM
maxinout93
Oct 27, 2015 01:29 PM
kingw323
20
Oct 21, 2015 08:36 AM
Huttig2009
Sep 25, 2015 03:31 PM
george__
Aug 18, 2015 07:06 PM
