VIAS stripped screws
Old Jul 30, 2006 | 05:23 PM
AceofSpds's Avatar
wat
Ok well i want to check on my vias to see how its holding up, and i was ondering if i could buy a stronger set of bolts that dont strip as easialy, and how much are new ones from the dealer?
Old Jul 30, 2006 | 05:25 PM
irish44j's Avatar
retired moderator
If you're careful and use the correct size screwdriver, you won't have any problems. I've removed and re-installed my VIAS screws 3x and they are not stripped at all. Just make sure to use a large philips head, not a standard.
Old Jul 30, 2006 | 05:36 PM
ibag8rfan's Avatar
I replaced mine with some metric bolts.
Old Jul 30, 2006 | 10:19 PM
foodmanry's Avatar
Da Roller Coaster!
I replaced mine with hex head bolts. I found it easier to get an allen wrench in there than a screwdriver.
Old Jul 31, 2006 | 01:45 PM
westler92
When your VIAS goes out........does the check engine light come on or does your car just run crappy for no reason
Old Jul 31, 2006 | 01:50 PM
dfownz's Avatar
I think we all hear you man. When I did mine I had a philips head and flathead that I thought fit perfectly and no matter how hard I pushed in and turned 2 of the screws I couldn't get them out. I ended up putting the flathead on the side of the screw a little off center and smacked it with a hammer to undo it. Once you manage to get them out just get new bolts that are the same thread, I think they're M6 X 1.0, but you should double check, I did this last week and can't really remember.
westler92: Nothing informs you of it going out, the cup of the VIAS will gradually loosen and not turn to switch to longer runners. The only indication is that at 5 grand you don't keep on pulling. Its kind of hard to recognize, but once you fix it you realize what you were missing out on.
DF
Old Jul 31, 2006 | 02:18 PM
MaxBoost925's Avatar
Drug Money
I went to the hardware store with my stripped VIAS screws and found some hex head screws that are the same size. I can now use a ratchet to get those out with ease... not that i ever have to because i dont have a power valve.
Old Jul 31, 2006 | 02:25 PM
AceofSpds's Avatar
wat
thanks guys ill run up to ace and get me the bolts tomorrow, to get mine off the first time i had to use penetrating oil... it helped a bunch
Old Jul 31, 2006 | 02:54 PM
irish44j's Avatar
retired moderator
ugh...I would NEVER use hex-head screws for anything on my car. All it takes is a little bit of rust on them, and they will strip like crazy....
Old Jul 31, 2006 | 07:48 PM
carsarecool's Avatar
alright, mine are stripped too, do i have to use bolt extractors or can i just use a flathead screwdriver off-center? you mean in between the screw and the manifold?
Old Aug 1, 2006 | 06:51 AM
Kevlo911's Avatar
Kevlo for President
We had to use a screw/bolt extractor on my friends 00. It was FCKING gay. I don't why but those cheap *** screws are also on the other side of the IM(rod removal)...
We got 3 screws out and then the bottom one stripped and it was a b1tch to make the drill fit in there.
Old Aug 1, 2006 | 06:43 PM
michaelnyden's Avatar
what do you guys think after you removed your power valve? what was the midrange/low end loss like? did you get used to it..?
Old Aug 1, 2006 | 08:11 PM
AceofSpds's Avatar
wat
I didnt remove my power vaulve... but if my jbweld fix breaks im gonna have to cause mine was pretty messed up.
Old Aug 1, 2006 | 09:21 PM
I was referring to maxboost and irish (which I think also removed his power valve)...
Old Aug 1, 2006 | 09:32 PM
Drug Money
Well that's cuz you're in Virginia Josh.
Out here in Californayay we have no rust
Old Aug 1, 2006 | 09:35 PM
steven88's Avatar
Need A Light?
yup, i stripped a few screws using my phillips screwdriver...cuz nissan tighten these screws SOOOO much and made the stupid screws so brittle...pwnt
Old Aug 1, 2006 | 09:40 PM
Drug Money
I can honestly say my low end was and midrange was decent (a little less than stock) but high end powah was unbelieveable.
My low end was improved by like 50% with my Consult2 timing advance.
So all in all my low end is a little less than a stock 5th gen. but high end i will blow a stock one out of the water.
Old Aug 3, 2006 | 11:30 PM
we need to take out the power valve and shave it so it still seals (I wonder if it can be done or if there is enough there)...but then we will keep most of our low-end/mid-range if not all and gain some top end...kind of a between fix of having it in and working and having it out...
doctorpullit
Mar 29, 2016 11:08 AM
rbarnes
Dec 31, 2015 06:29 PM
RealityCheck
Oct 2, 2015 06:34 PM
sliptap
Sep 30, 2015 05:57 AM
King_Ten_Ahead
Sep 27, 2015 02:24 PM
