Car seems slow.
Old Aug 6, 2006 | 05:57 PM
97Se5spd's Avatar
Car seems slow.
My car seems slow while getting on the highway at 100% throttle. I think its becuase my tranny only went into 3rd instead of 2nd. Im having some trouble with the tranny. I mean the acceleration is comparable to that of my old 98 AUTO SE. I do have an auto now but, it seems sluggish while getting on the highway and in most other examples, except from a dead stop. MAF? o.0
EDIT: Car does have 93k on it, but it is all highway mileage and was very very well maintained. I have all records.
Old Aug 6, 2006 | 06:40 PM
ctrent86's Avatar
Does sound MAF related perhaps. Get some CRC MAF cleaner and see if that does the trick.
Old Aug 6, 2006 | 06:59 PM
97Se5spd's Avatar
Where can I find that? AutoZone or a place like that?
Old Aug 6, 2006 | 07:16 PM
ctrent86's Avatar
Yes sir I believe so I found mine at pep boys and sometimes there selection sticks so I imagine so. CRC is a fairly large company with a reputable name in cleaning products such as brake parts cleaner. You should be able to find it. Good luck.
Old Aug 6, 2006 | 08:15 PM
97Se5spd's Avatar
OK. Thanks, and BTW did it make a difference when you used it? (If you did)
Old Aug 6, 2006 | 08:45 PM
ctrent86's Avatar
I use it as part of my semi annual mantience. After discovering it and using my first time. I noticed a smoother power delivery as well as smoother shifting.
Old Aug 6, 2006 | 08:51 PM
SuperStasiu's Avatar
Its a maxima what you expect put in some rocket fuel that might work muahahahah
Old Aug 7, 2006 | 06:03 AM
Orgullo's Avatar
$$ Ballin on a Budget $$
Have you changed out your fuel filter? I was having the same problem as far as sluggish starts and hesitation. I changed it at 90,000 miles, the car drives and idles smoother and the acceleration is insane.
Old Aug 7, 2006 | 03:47 PM
97Se5spd's Avatar
Changing the fuel filter seems like a ***** to do. Ill try the MAF cleaning stuff this weekend. -- Then go from there.
Old Aug 7, 2006 | 06:02 PM
DaGGer's Avatar
do you have any hesitation because that would show a fuel problem. You could also check out your spark plugs and such, and when was the last time you did a tune up.
Old Aug 8, 2006 | 07:07 PM
ctrent86's Avatar
Fuel Filter isnt that bad it is esier than you think. There is a recent really well done write up in here.
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
altome15
Aug 10, 2015 07:05 PM
