Engine Mods AKA getting more power
Old Aug 10, 2006 | 08:33 AM
Hardcore's Avatar
I've read the FAQs on intakes, exhaust, and timing. (Most are dated by the way and the vendors in them aren't around)
Here's what I gather
Intake -> helps with power and MPG, fairly cheap
Exhaust -> headers and B-pipe help power
Mufflers don't help much power, mainly sound
Timing -> Advancing timing modifies the base Timing, more responsive below 2,500 rpm
Grounding kit -> More responsive according to people's butt dyno
What other mods are there other than these? I'm not talking about the serious stuff such as engine swap, FI, and Nitrous. Basic bolt ons for the 3.0 that'll add more power.
Old Aug 10, 2006 | 08:36 AM
dfownz's Avatar
Get a new y pipe, intake, springs, and new cd player.
DF
NmexMAX's Avatar
dot dot dot ...
UDP, Piggy back ECU fuel tuning, larger MAF's/custom intakes, different throttle bodies, modified IM, P&P.
Old Aug 10, 2006 | 08:37 AM
acidbbg's Avatar
UDP (pulley), lightened flywheel (if you have mtx), some sort of piggy back.
Old Aug 10, 2006 | 08:40 AM
Hardcore's Avatar
Who sell's larger MAFs and TBs. How much gain are we talking about?
Old Aug 10, 2006 | 08:48 AM
Hardcore's Avatar
DF
The Y-pipes in the FAQ section are from Catmann and Stilen, both are offroad use only.
Intake- mentioned
Springs - Can't lower car considering New Orleans potholes
CD Player - Done
Old Aug 10, 2006 | 08:58 AM
Gapp's Avatar
A Maxima.Org sticker is the best mod.
Old Aug 10, 2006 | 09:03 AM
NmexMAX's Avatar
dot dot dot ...
Originally Posted by Hardcore
Who sells larger MAFs and TBs. How much gain are we talking about?
No one for our car specifically, but that doesn't mean you can't think of something up using a parts bin. Mods go hand in hand, and work with each other, think that through and read through the All Motor forum...
Old Aug 10, 2006 | 09:06 AM
wade's Avatar
racing stripes add 30 - 40 HP
lol but in all seriousness...
I would suggest front strut bars, will help when ur not going in a straight line
upstatemax's Avatar
The best bolt on power mods for the Max are the headers and a piggyback. If you are running headers I think an intake like the Berk shortram intake is a good idea. If you are close to stock, just keep the intake stock, at most GAB it. Injen intakes should never see a Maxima engine bay, period.
The only other exhaust mod worth putting on would be a Cattman B-Pipe... But only if you need to replace your exhaust (trust me you will).
If you can find an UDP for a good price then go with it, but I would never pay $300 for it... BTW, I paid under $80 shipped for my Motorstorm UDP, I just had it thrown on when I needed my belts changed.
I don't see a larger MAF making that big of a deal power wise. Unless you are trying to get every last bit of power out and you have all the other major mods, on a stock car... pointless.
Old Aug 10, 2006 | 09:08 AM
upstatemax's Avatar
Strut bars add more power! Nope, so why are some tards suggesting suspension mods?
He asked about getting more power!
Old Aug 10, 2006 | 09:20 AM
wade's Avatar
Originally Posted by upstatemax
Strut bars add more power! Nope, so why are some tards sugggesting suspension mods?
true but no matter how many mods u put on to increase speeds..
when u go and take a corner, u will hafta slam on ur brakes cuz u can't take the corners at a decent speed
therefore reducing the power that u can use on your car
unless the only power u want is in a completely straight lines and I dunno about you but where I come from there are turns.. tard
Old Aug 10, 2006 | 09:27 AM
upstatemax's Avatar
Yes, then your strut bar suggestion was perfect... We all know how how much better they make a Maxima handle.
You tard.
Old Aug 10, 2006 | 09:42 AM
LA02MAX's Avatar
Intake- mentioned
CD Player - Done
what does 'offroad use only' mean? I hear you on the NO potholes though...i had to back up several times going through the quarter last week....everything already suggested are the main mods for the maxima without going FI...get headers, piggyback, b-pipe, and you're pretty well off...many people are using the pathfinder TB as well
Old Aug 10, 2006 | 09:48 AM
vq356sp's Avatar
El Mas Noob Del Org.
Go thru these links and read as much as you can, Im pretty sure you will find alot of your answers in there.
http://forums.maxima.org/forumdisplay.php?f=53
http://forums.maxima.org/forumdisplay.php?f=55
http://forums.maxima.org/forumdisplay.php?f=79
http://forums.maxima.org/forumdisplay.php?f=48
Old Aug 10, 2006 | 11:07 AM
Stardust's Avatar
F---ing Kangaroos
You're not funny, go away
Old Aug 10, 2006 | 01:33 PM
Crooklyn's Avatar
I would suggest what I did so far.
Cattman Y-Pipe, B-Pipe(mid-pipe), Stillen rear section muffler, Stillen Rear sway bar, injen cold air intake(DONT FLAME ME I KNOW) I have not seen any real conclusive proof as to injen being a bad intake. Going to do suspension and brakes soon also high flow cat is a must when u change ur pipes I learned the hardway, I have a stillen bodykit just laying around I might sell it I need da money
Old Aug 10, 2006 | 01:44 PM
NmexMAX's Avatar
dot dot dot ...
Y-pipes are a waste of $$ on 3.5L's.
All that stuff you mentioned there wont get you much in the way of power.
Old Aug 10, 2006 | 01:48 PM
bigfy39's Avatar
is vafc II a piggyback?
Old Aug 10, 2006 | 01:53 PM
MaxBoost925's Avatar
Drug Money
I suggest aspiration mods to clear up the flow of air.
otherwise man up and boost.
/thread.
Old Aug 10, 2006 | 02:16 PM
NmexMAX's Avatar
dot dot dot ...
Yes ......
Old Aug 10, 2006 | 02:27 PM
SEmy2K2go's Avatar
Go BUCKS!!!
You've read all the stickies and FAQ's, and still don't know? Try the All Motor section.
Old Aug 11, 2006 | 04:13 AM
The Flash's Avatar
My buddy owns ASPracing, they make some awesome pulleys, and they do custom jobs too.
Old Aug 11, 2006 | 04:44 AM
Puppetmaster's Avatar
You do know that most mods are "offroad use only", including ALL y-pipes and headers.
Old Aug 11, 2006 | 04:45 AM
Originally Posted by vq356sp
He actually did say bolt-ons excluding FI, swaps, etc.
Old Aug 11, 2006 | 04:50 AM
While that is a good point, he's asking for "engine mods" to increase power output, not for mods that will increase the ability to handle better at high speeds. If you want to go down that road, then add RSB, LTB, SFC, struts/springs, coilovers, lightweight and wider rims, camber kits, etc. to that list; all of which are way more effective in improving handling than a strut bar.
Old Aug 11, 2006 | 04:52 AM
To increase "effective" power, I'd also add stiffer motor mount inserts and lighter wheels to the list.
Old Aug 11, 2006 | 07:03 AM
Hardcore's Avatar
The aftermarket Y-pipes I've seen do away with the CAT on my 2001, thus it won't pass a visual emmissions check, AKA not for street use, AKA offroad only
Old Aug 11, 2006 | 07:04 AM
Aftermarket y-pipes eliminate ONE (rear) pre-cat on your CALI spec 2001. You will still have the other (front) pre-cat and the main cat.
Old Aug 11, 2006 | 07:20 AM
Hardcore's Avatar
The stillen website pops up a warning saying you cannot run the y-pipe on the street
Cattmann's website states
1995-2001 Y-pipes eliminate factory-installed “pre-cats” and are not intended for use on public roads or highways.
Old Aug 11, 2006 | 07:33 AM
I know that, please see post #24.
That being said, its only an issue if you are caught.
Old Aug 11, 2006 | 07:53 AM
Hardcore's Avatar
Just making sure there are no inspection friendly Y-pipes out there.
Getting caught is the issue, the inspection places around here are getting serious about checking emmisions stuff. Maybe I need to start looking for the shady places
Guess I'll put off the y-pipe and get a B-pipe for now and look at some other mods.
Old Aug 11, 2006 | 07:58 AM
Hardcore's Avatar
Yes ......
Any other options for a piggyback for a 2001. I've seen some of the websites that flsh PCMs that they won't due tuning on the 2001 computer for whatever reason
Old Aug 11, 2006 | 08:19 AM
If they don't do a visual, it is easy to pass with a y-pipe or headers. I've passed the VA state inspection (OBD-II test) with no pre-cats and an O2 simulator to cover my secondaries. Even if they had a tail pipe sniffer, I would have passed since my main cat is working fine.
Old Aug 11, 2006 | 08:21 AM
See the header thread in the stickies for consolidated information on piggybacks.
Technosquare is the only place that can reflash a 2001 ECU, but they've only done it for one person (Larrio) and aren't doing it any more for whatever the reason.
Old Aug 11, 2006 | 09:43 AM
shysmax's Avatar
Even with the suggested bolt-on mods, how much is he gonna gain in hp and tq??
ShysMax
Old Aug 11, 2006 | 10:12 AM
Stardust's Avatar
F---ing Kangaroos
Joel, 8 posts in this thread FTL
MAXSE5SPD
Sep 17, 2022 04:00 AM
The Frye
Sep 2, 2021 11:03 AM
sdotcarter
Sep 2, 2015 09:53 PM
A32goldylocks
Sep 2, 2015 06:39 AM
maxinout93
Aug 20, 2015 02:17 AM
