2000 Maxima Speedometer: Needle is not lined
Old Aug 10, 2006 | 08:12 PM
tvn_1010's Avatar
2000 Nissan Maxima SE
Hi,
My speedometer needle for the mph is not lined correctly. The speed is at 40 mph. I remember reading in the past on how to get that lined correctly. I had recently bought this new one cause my old one was broke.
The speedometer is not on the car.
All the rest of the needle; rpm, temperature are all resting on the needle rester except for the mph one.
Your input is greatly appreciated.
Thanks.
Old Aug 11, 2006 | 04:08 AM
Orgullo's Avatar
$$ Ballin on a Budget $$
You can just pull the needle straight off. Connect the cluster to your car. Start the car and lightly push the needle back on. When you put it on just make sure it's resting on the "rester." You should be fine with that.
Now get on the freeway and hit it, let the HHP clock you and see what he says your speed was.
J/K
Old Aug 11, 2006 | 04:43 AM
phenryiv1's Avatar
Mod her. Ate her.
NOOOOOOOOOOOOOOOO! Where do you get this information?
You remove the needle rest with a pair of needlenose pliers and turn the needle- gently- ONLY in the counter-clockwise direction until it is resting in the natural resting position. (The natural resting position will most likely be below (past) the needle rest. It is on a 4th gen.) Then you even MORE gently bring the needle up past the rest in a clockwise direction and re-install the needle rest.
You will feel gentle resistance when turning it counter-clockwise. This is the needle actually turning while the center post remains stationary. You should NOT feel and pressure (other than the spring slightly uncoiling) when moving it in the clockwise direction, because the center post will be turning with the needle.
If it were a 4th gen I could tell you the exact speedo needle resting position, but I have never dissected a 5th gen to know where it rests.
If anyone has installed aftermarket gauges, they may know the resting position.
Old Aug 11, 2006 | 04:50 AM
phenryiv1's Avatar
Mod her. Ate her.
This is an easy fix, if the spring is not bent. See my post above, and/or look for install instructions for indiglo gauges or aftermarket gauge faces- they may tell yo umore abotu where to "clock" the needle when at rest.
I would be worried that the spring in the gauge may be messed up, if it is resting above the needle rest.
Old Aug 11, 2006 | 08:05 AM
Orgullo's Avatar
Apologies for the mis-information however, I did what I said and I have no problems. I took the car in to make sure it was calibrated correctly and everything was in order.
Just to be safe though follow what phenryiv1 said and you should be cool.
Old Aug 11, 2006 | 10:14 AM
phenryiv1's Avatar
Mod her. Ate her.
Do you remember where the needle dropped to when the rest was removed, or did you not remove it?
Old Aug 11, 2006 | 04:04 PM
Orgullo's Avatar
I actually marked it with a pencil before I took them off. I know where my idle was and where the temp rest. The only thing that I was really sweating was the gas needle but it worked out. At least I haven't stranded myself somewhere yet!
halfpol
Oct 17, 2022 12:16 PM
Nintensity
Aug 13, 2015 05:41 PM
jholley
Aug 11, 2015 09:38 AM
niZ
Aug 7, 2015 10:18 PM
egali045
Aug 5, 2015 09:02 AM
