5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Feb 2, 2008 | 08:06 PM
  #4881
00MaximaGLEgrl's Avatar
Originally Posted by Professor`
We scan some ppls car if we know them, most of are stores wont do it, it depends on who the parts pro is. If its not to busy i useually do it.
JUST BEEN PROMOTED TO RETAIL PARTS PRO !!!!!! btw. yes i work at advance auto parts.
congrats on the promotion and thanks for the info!
Im taking it back to the dealer on monday and they are going to take care of it. Good thing i got the 2 year extended warranty on it too hehe
Old Feb 3, 2008 | 08:45 PM
  #4882
Nicktard's Avatar
I just bought PIAA 9004's for my Lows...its confusing because it says I need 9003's but these 9004's say they will work as 9003's as well. Will there be any potential problems if i hook them up and they dont work? Could they ruin my wires and stuff?
Old Feb 3, 2008 | 09:21 PM
  #4883
vinco's Avatar
Parts interchange - rear axle???
I just bought a 2000 SE 5MT, and upon closer inspection (after I got it home and the cash is gone, of course) the rear axle beam is bent slightly, kicking both rear wheels out of alignment. While this isn't a huge deal in terms of changing the part, it would be a whole lot easier to find one if I knew better what else might interchange with it. I know that 2K-2k3 Maximas and I30's would be the same, but would the 95-99 fit as well? This would make my junkyard searching a whole lot more productive. Also, does the SE have any different specs than any other Maxima for this particular part - just the axle beam itself?
Thanks in advance!
Old Feb 4, 2008 | 12:42 PM
  #4884
Eastern's Avatar
When driving a stick is it really "bad for your car" if you shift really early sometimes (1500rpms) also I heard alot about the clutch slipping? What does this feel like?
Old Feb 4, 2008 | 01:58 PM
  #4885
jbrooks870's Avatar
What companies offer performance throttle bodies and intake manifolds for a 5th gen Max?
Old Feb 4, 2008 | 02:23 PM
  #4886
ghostridden's Avatar
wat is DaveB's current email, when i did a search i came across two different addresses so i wanna make sure i got the right now.
Old Feb 4, 2008 | 03:55 PM
  #4887
NmexMAX's Avatar
dot dot dot ...
Thanks in advance!
The 4th gen wont fit, it's a slightly different design. So how can you tell it's bent?
Old Feb 4, 2008 | 03:56 PM
  #4888
NmexMAX's Avatar
dot dot dot ...
None, no one.
Old Feb 4, 2008 | 03:57 PM
  #4889
NmexMAX's Avatar
dot dot dot ...
I would suggest calling him.
1-888-254-6060
Old Feb 4, 2008 | 05:56 PM
  #4890
Scottwax's Avatar
That's Mr. Detail to you
9003's and 9004's are different bulbs with different connections.
Old Feb 4, 2008 | 06:26 PM
  #4891
Tee00Max's Avatar
does a front strut tower bar really do any justice when your car is not lowered? on a (2000 max)
Old Feb 4, 2008 | 06:29 PM
  #4892
NmexMAX's Avatar
dot dot dot ...
Looks pretty. It would probably do more if you're not lowered.
Old Feb 4, 2008 | 06:39 PM
  #4893
Tee00Max's Avatar
how would it do more if your not lowered???? could i also get some more opinions on this from other people as well.
Old Feb 4, 2008 | 06:42 PM
  #4894
NmexMAX's Avatar
dot dot dot ...
Being lowered negates it's affect to some small extent. So therefore it's more noticeable if not lowered.
It's not a huge decision and is very cheap, get it and be done rather than asking a million people their personal opinion. Now if you want opinions, search, the answer you want to see is out there, and so are other opinions that you may not want to see/read.
Old Feb 4, 2008 | 06:51 PM
  #4895
Tee00Max's Avatar
yea i feel what you are sayin...appreciate it
Old Feb 4, 2008 | 07:03 PM
  #4896
Tee00Max's Avatar
I painted my calipers wit some caliper paint about a year ago and its starting to fade......im gonna eventually repaint them but for the mean time is there aything i can put on them to pressure wash the paint off??
Old Feb 4, 2008 | 07:21 PM
  #4897
NmexMAX's Avatar
dot dot dot ...
Best if you sand them, make the surface rough so the next coat ‘sticks’ on there nicely, perhaps even primer it before.
Old Feb 4, 2008 | 07:39 PM
  #4898
daesonn's Avatar
I own a 2k1 maxima with stock wheels and perelli's. When I bought the car a couple months ago I didn't notice anything wrong, but now whenever I even slightly turn the steering wheel to the right I get a seemingly rubbing sound from my front right wheel...kind of like a "nrrr nrr nrrr" rather than a constant rubbing too...Any idea what this might be?
Old Feb 4, 2008 | 07:50 PM
  #4899
Nicktard's Avatar
So will the bulb not fit or what? PIAA dosn't make 9003's from what i found and these 9004's say they are 9003 compatible.
Old Feb 4, 2008 | 10:00 PM
  #4900
Scottwax's Avatar
The biggest thing I noticed was improved steering response. Feels a bit tighter in turns too.
My car isn't lowered, btw. Roads suck around here.
Old Feb 4, 2008 | 10:28 PM
  #4901
vinco's Avatar
Re: rear axle beam
I can lay a straightedge along it and it doesn't lay flat. One of the shock mount welds looks cracked. Plus, the back tires sit at a wierd cockeyed angle. Obvious instant destruction for tires.
Now, the next question: I spent my lunch at a salvage yard today, looking at 4g rear axles, and it does, in fact, mount differently than the 5g part. Not much different, but enough for Nissan to claim a redesign.
I called another yard, and the guy said he had one for a 5G with factory 16" wheels, but not one for a car with 17" wheels. What's the difference? Just the durometer of the rubber bushings, or something more significant? Different width for different wheel offset? He had no idea. WTF, over?
Old Feb 4, 2008 | 10:31 PM
  #4902
Scottwax's Avatar
9004 bulbs:
9003/H4 bulbs:
And yes, PIAA does make 9003 bulbs.
http://www.autotoys.com/x/catalog/PI...24_p_1679.html
Old Feb 5, 2008 | 09:01 AM
  #4903
NmexMAX's Avatar
dot dot dot ...
There's a thread somewhere on here discussing it with pictures, I'll take a look sometime to see if I could find it. But in the long run, you're better off spending a little more time locating a 5g unit and spend less time hassling trying to make it(4g piece) work.
There is no difference.
Old Feb 5, 2008 | 11:15 AM
  #4904
vinco's Avatar
5G rear axle beam
Thank you!
Old Feb 5, 2008 | 12:32 PM
  #4905
MaximaBlack's Avatar
Airbag Question in regards to me 2001 Maxima...
Hello, Basically I got in a light front end crash and both the Driver and Passenger side air bags went off in my 2001 Maxima GLE. I bought two new airbags and the SRS Airbag Module that mounts under the center console- but my question is, Do I have to replace the actual crash sensor that is mounted on the center beam of my radiator support behind the Nissan emblem on the grille, or can I get away with re-using it??? It looks like it is in perfect condition- I just don't know if it is a "one-time use" type of thing or not. Hopefully I can get away with re-using it cause it would save me almost $300 from the dealer. Any help from you guys would be greatly appreciated!! Thank you!!!
Old Feb 6, 2008 | 01:44 PM
  #4906
well i got my car inspected today and it failed emissions (which i knew it would). on the inspection report it said the trouble code was P0420, but they didnt have any comment on that, i just noticed it on the paper when i got home. they reset the computer and said if the SES light comes back on bring it back. then they said this happens alot with these cars and this time it shouldnt come back on. im sure it will tho.......
Old Feb 6, 2008 | 02:12 PM
  #4907
Iceman420's Avatar
(insert witty one liner)
Here is a whole thread on the P0420 code:
http://forums.maxima.org/showthread.php?t=211895
Hope it helps.
Old Feb 6, 2008 | 02:42 PM
  #4908
SoonerFan's Avatar
Cletus
what year?
thats for the front bank cat going bad.
i have that code because the cats are wearing out due to oil burning.
hope yours goes away.
Old Feb 6, 2008 | 03:50 PM
  #4909
Originally Posted by soonerfan
what year?
its a 2000 with 72k on it. OH and the local nissan dealer said they wont cover the cat because the first time i had it there it was the coils and the coils ruined the cat therefore they wont replace it...
Old Feb 6, 2008 | 04:02 PM
  #4910
SoonerFan's Avatar
Cletus
holy low miles!! my 02 has 78K
bad coil will cause unburnt fuel to wear the cat out.
i have oil and unburnt wearing mine out.
Old Feb 6, 2008 | 04:04 PM
  #4911
nebojsa_o's Avatar
How do the coils ruin the cat? Serious question...
EDIT: Nevermind, answered above...
  #4912
SoonerFan's Avatar
Cletus
see above
EDIT: nevermind...you saw it
Old Feb 6, 2008 | 05:56 PM
  #4913
oh yeah and the car stalled a couple times since ive had it (about 2 weeks). it only stalled while it was in park. and only after ive been driving. in the morning when i start it to warm it up its fine and its totally fine while im driving or in gear. it starts right back up tho. it hasnt done it in a while. any advice on that?
Old Feb 6, 2008 | 08:51 PM
  #4914
streetracero1's Avatar
air intake question
i just bought a 2000 maxima auto. i'm looking for a short ram intake that eleminates the stock air box and piping. will an intake for a 99 maxima fit on my car? i already have the maf adaptor but i still want the smooth flow of the aluminum pipe
Old Feb 6, 2008 | 08:53 PM
  #4915
Max Nu-BE's Avatar
Looking for MCA Navi software
Can anyone help me out with Navi disk MCA 6,8, & 9? I have 7 if anyone is looking for it. Thanks in advance. you also cam e mail me @ places584@gmail.com
Old Feb 7, 2008 | 08:44 AM
  #4916
Iceman420's Avatar
Check the FAQ (http://forums.maxima.org/showthread.php?t=28014)
Scroll down and you will find the section on intakes.
Old Feb 7, 2008 | 08:51 AM
  #4917
NmexMAX's Avatar
dot dot dot ...
That section is old and outdated and really doesn't give him the information he needs.
If you have a 5th gen MAF adapter then yes, the 4th gen intake from that 99 WILL fit your car. The only difference between the 2 is the MAF adapter.
Old Feb 7, 2008 | 09:12 AM
  #4918
Iceman420's Avatar
Thanks for clearing things up.
Old Feb 7, 2008 | 05:42 PM
  #4919
thank you very much. i'm going to order one now. i did search first btw just didn't find what i was looking for and all those links in that perfomance thread didn't work for me at all
Old Feb 7, 2008 | 06:35 PM
  #4920
nebojsa_o's Avatar
I've been wondering this for a little while now, but keep forgetting to look/ask.
How much was a fully loaded 2002 Maxima SE? Or if you know, every option except for the navigation system? In US dollars preferably. As good of a guess as you have. Thanks
