5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Old Feb 8, 2008 | 06:35 AM
  #4921
vinco's Avatar
Ditto with an '00. Fully loaded SE, leather, sunroof, side airbags, 17" wheels, heated seats & mirrors, Bose, 5 spd, homelink, dual power seats, and whatever else you can think of. Anyone got a copy of a window sticker from a car like that?
Old Feb 8, 2008 | 07:28 AM
  #4922
Doggus's Avatar
2000 Maxima ~100k mileage here. P0140 code diagnosed by AutoZone as the O2 sensor. So I bought the generic one and proceeded to replace. I'm guessing there is no way I could have screwed the wire splice up as the one I pulled out was a Bosch and the one I put in was a Bosch. They had identical wire colors. Followed the pamphlet to the letter. Problem is getting worse.
Car dies while sitting at a light. Needs to warm up first before putting in gear or it will putter and die. Exhaust smells really gassy. To me this all points to a bad sensor but I replaced it and still no dice.
Also if I throw another sensor at it, this time the OEM, where does it plug in? I noticed the wiring goes through the panel on the underbelly. I'm guessing that plate comes off and I'll see it under there?
Old Feb 8, 2008 | 07:54 AM
  #4923
hammester's Avatar
My 03 Maxima is fully loaded except for the navigation system and the sticker price was a little over 30K.
Old Feb 8, 2008 | 08:19 AM
  #4924
98maxse5spd's Avatar
What are the differences between a 2002 and 2003 SE?
Old Feb 8, 2008 | 02:06 PM
  #4925
nebojsa_o's Avatar
As far as I know nothing, except for the availablity of the Titanium Edition, which probably added to the price. Maybe the '03's are more likely to have HLSD, my '02 doesn't. It was a early one...
Old Feb 8, 2008 | 02:24 PM
  #4926
nyautostyle's Avatar
exactly. they're the same but the 03's had the titanium edition
Old Feb 8, 2008 | 04:14 PM
  #4927
K20z1_rsx's Avatar
I have an 03 Ti edition but it doesn't have a HLSD. And I had to drive 5 1/2 hours to buy my 6 speed when shopping for a max.
Old Feb 8, 2008 | 04:27 PM
  #4928
nebojsa_o's Avatar
Worth every minute though.
Old Feb 8, 2008 | 08:27 PM
  #4929
ghostridden's Avatar
needing to replace my intake manifold GASKETS, upper and lower, idiotzone only offers the upper, NO OTHER PART STORE even offers either of them. Can someone point me to a damn place that will sell the set for me, THANKS
Zack
Old Feb 8, 2008 | 09:32 PM
  #4930
hooch00's Avatar
2000 maxi se
passenger headlight switches on and off after the car has been idling for 4-5 minutes. as the light switches off, the high beam indicator in the gauges turns on. when the light comes back on, the indicator turns off.
no problem whatsoever when the car is being driven, only after it has idled for a few minutes. all connections seem fine.
ideas?
Old Feb 8, 2008 | 11:58 PM
  #4931
blkAEmax82's Avatar
Glory Glory Man United
Did you try Dave B
DAVEB's number for OEM parts is
888-254-6060 and his email is daveb@adpub.com.
Zack
Old Feb 9, 2008 | 08:09 AM
  #4932
Patrick.R's Avatar
Is a IACV on a 2k max the same as one for a 5.5 max?
Old Feb 9, 2008 | 02:39 PM
  #4933
Nicktard's Avatar
Ok I need a lot of help, I ordered a lot of bulbs and my situation only keeps getting worse, ive made diagrams for better help. Very mad with the outcome so far, I should have just gone with getting an HID kit.
When looking in from above...I see a "female" harness that would take the end of a 9003 Bulb...also, coming from my lamp assembly there is a "male" plug? They plug into each other which and my lamp is an H3? lol. Could I just put a 9003 in and plug my "female" end into it?
Sorry for picture quality and stuff. I tried. Please Help me find the right products!
9003/H4's i have coming in the mail:
http://www.sfxperformance.com/parts/PIA15224.htm
Pic of parts:
http://i26.photobucket.com/albums/c1...ktard/GEEZ.jpg
My lights, and stuff:
http://i26.photobucket.com/albums/c1...ard/lights.jpg
Actual install:
http://i26.photobucket.com/albums/c1...tard/Light.jpg
Ask for any more pics or anything please.
Old Feb 9, 2008 | 05:31 PM
  #4934
jbrooks870's Avatar
I was wondering how much brand new OEM coil springs cost? I cant find them online. Thanks.
Old Feb 10, 2008 | 12:19 AM
  #4935
NmexMAX's Avatar
dot dot dot ...
Browse the classifieds on here.
Old Feb 10, 2008 | 08:32 AM
  #4936
Nightkid08's Avatar
Ok. I have a 5.5 gen and ever since i bought it the driver seat feels very soft or worn. And the question i was wondering is if there are alternative OEM seats or AEM bucket seats in the market that has a solid feel and actually can hold you in the seat when your cornering when your making sharper turns. Thanks.
Old Feb 10, 2008 | 03:19 PM
  #4937
SunDown13X's Avatar
Originally Posted by NmexMAX
Supposed to be the one in front. The wire comes from the O2 sensor cord cluster and goes beneath the mount on the right (if you're facing the engine). If your car is one of the really early ones then I guess it possible it didn't get it, what's the VIN?
Perhaps get under the car, remove the shrouds, and take a better look.
Hmm, does this mean you couldn't care less to get on your back and see the other side of that front mount?
Regarding ELECTRONIC MOTOR MOUNTS...
Here is my vin number, if it helps... I should be back in NC tonight, so I will check for those wires using the link that you posted earlier.
2000 Maxima GLE
JN1CA31A6YT031950
It was build on 05/2000 according to the door sticker.
D.
Old Feb 10, 2008 | 03:23 PM
  #4938
SunDown13X's Avatar
for the record, my buzzing noise happens after i rev the car pass 5k to redline. It doesnt happen when I turn the car off as stated on the link you posted http://www.nissanhelp.com/Ownership/.../NTB01-010.htm
Old Feb 10, 2008 | 09:19 PM
  #4939
Nicktard's Avatar
Okay so after messing with my lights once again, I think with buying my new light assembly it changed the bulbs I need. The factory plug no longer goes from car to light, it goes from car to headlight plug. I think this plug changes my bulbs.
Also, on the front of the assembly, in front of the high beam it says H1, Low beam H3. I bought H3's for my fogs and I put them in my lows temporarily and they fit perfect. So do you think I can order a Xenon H3 HID kit and install should be pretty straight foward or what?
Do bulb types:H1,H3,9003,4,5,6 ...etc, All have the same intensity, just different sizes? or do the different numbers have different intensity? Im just wondering if H3's will be bright enough for my lows.
Old Feb 11, 2008 | 06:08 PM
  #4940
Eastern's Avatar
When looking at pictures of the front seats/dashes of 5th gens, I usually see the DC plug not being used while objects are still being powered that requires a DC plug. Where do you get this power, do you just use the backseat plug?
Old Feb 11, 2008 | 06:22 PM
  #4941
irish44j's Avatar
retired moderator
I have a couple auxiliary DC plugs hardwired into mine (radio shack 2 plug + cig lighter). That's where I power my ipod, phone, etc from. It's mounted to the side of the shift assembly on the passenger's side.
or, use the rear outlet.
Old Feb 11, 2008 | 07:12 PM
  #4942
daesonn's Avatar
Can anyone tell me if i'm going to be happy with these tail lights?
http://cgi.ebay.com/ebaymotors/00-01...spagenameZWDVW
they're aftermarket, is there any difference, or should I go ahead and get these? the stock ones are too expensive for me to get, unless someone online here has an extra pair of SE tails theyd sell to me.
Old Feb 11, 2008 | 07:25 PM
  #4943
irish44j's Avatar
retired moderator
these are depot lights - they should be similar to the OEM SE tails. I don't see anything wrong with them.
Old Feb 11, 2008 | 07:40 PM
  #4944
DrunkieTheBear's Avatar
Turbo'd Saab
you know I really wonder where all this stuff gets manufactured and how they manufacture so many different lights for different cars
Old Feb 11, 2008 | 08:20 PM
  #4945
daesonn's Avatar
they emailed me and said that the lights don't come with the rubber gasket to seal them from water leaking into the trunk, and I can't find out where to get that gasket.
Old Feb 11, 2008 | 08:40 PM
  #4946
Turbo'd Saab
If I remember correctly its not a rubber gasket its some kind of goo that is already on your stock tails
Old Feb 11, 2008 | 08:45 PM
  #4947
daesonn's Avatar
One dealership said he had some kind of tape on special order for 22$ and that was the only thing he could find in his database...
is that what i'll need?
Old Feb 11, 2008 | 08:47 PM
  #4948
Turbo'd Saab
I used chaulk to be honest, it worked fine
Old Feb 12, 2008 | 06:02 AM
  #4949
machinehead131's Avatar
I used roof sealant or something. Worked great.
Old Feb 12, 2008 | 06:38 AM
  #4950
CCS2k1Max's Avatar
ABS Light Flickers During Startup
IMO, this doesn't warrant its own thread and search didn't turn anything up.
The last couple of months I've noticed my ABS light flickering during startup, but it turns off once the engine starts. Anyone had this experience?
Old Feb 12, 2008 | 06:45 AM
  #4951
NmexMAX's Avatar
dot dot dot ...
Unless it stays on, I wouldn't worry.
Old Feb 12, 2008 | 06:58 AM
  #4952
Scottwax's Avatar
That's Mr. Detail to you
Brake fluid might be on the border of being too low.
Old Feb 12, 2008 | 07:06 AM
  #4953
CCS2k1Max's Avatar
Thanks, I'll double check that, but I don't think that's it. Last month or so was the last time I checked it and it was near the max.
BTW, the pedal feels fine and the ABS has been working fine in these icy side streets we have around here.
I am not worried, yet, but the flickering may be a bad sign of things to come.
  #4954
NmexMAX's Avatar
dot dot dot ...
The ABS light does not mean brake fluid. The BRAKE light does though.
Old Feb 12, 2008 | 08:24 AM
  #4955
rkreddy's Avatar
I was wondering if i can get the door to close without the hard thud when its closed hard. I remember when I first got the max it used to have a nice smooth sound. There is no play with the hinges. Also what should i use to lubricate the hinges on he doors?
Old Feb 12, 2008 | 02:36 PM
  #4956
jbrooks870's Avatar
2 questions, first my car has the SES light on and I brought it to the mechanic and no codes came up. He cleaned an air sensor and the light went away for about a week a but reappeared and is still on. Second is it possible to mate an RB26dett engine to a 5 speed tranny and have the engine sit parallel to the front axle?
Old Feb 12, 2008 | 02:48 PM
  #4957
El_PrOfE's Avatar
Can anyone take on the daunting task of updating the Parts List & Web Sites for 5th gen Parts to include the 5.5th gen????? that would be amazing.
Old Feb 12, 2008 | 03:02 PM
  #4958
NmexMAX's Avatar
dot dot dot ...
Tell me what you need and I'll tell you where to get it. Or at least try.
Old Feb 12, 2008 | 03:56 PM
  #4959
Scottwax's Avatar
Still used to my Mazda, one light for both. Forgot we have lights for each. Guess that is why the gauge cluster looks like a Christmas tree when I start my car.
Old Feb 12, 2008 | 04:29 PM
  #4960
Reket's Avatar
Does nissan have to do a TSB if its out for your car, and do I pay for it or is covered by Nissan?
