5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
#1083
Originally Posted by ShQiPtaR2287
Hi all i'm new here and I just have a quick question. I have a 2000 Maxima and i'm looking to purchase dual halo angel eyes headlights for my max. Is there any advice some of you can give me for example what to look out for or make sure is included when purchasing these?
Then, these instructions should guide you the rest of the way: http://www.innerbean.com/housecor/angel_eyes.html
#1084
Hey I thinkin about doing a y-pipe next on my 2002 max. All I can find available is the warpspeed ... is it worth it? I dont want headers because I can't stand the rasp they make at high rpm, so no headers. Anyways $250 for 20 hp doesn't sound too bad.
#1086
Originally Posted by CoolMax
First, you'll need a set of 2002-03 headlights.
#1087
After going through many of the threads regarding "RSB" and "FTSB" - I am have very interested in installing it to my stock 2002. However, I have neither the tools or the know-how to install it my auto, SE.
Does anybody have the the know-how and the tools for the install? I will compensate for the time spent. I am willing to travel 40 miles radius from Manhanttan. I asked my local mechanic about the RSB/FTSB and he commented that he has no experience in installing it, but he will try.
I thought it may be better if I tried the forum first. Thanks for reading.
#1088
#1089
The RSB may be a little more difficult, and it's nice to have another person to help: http://www.moodym.com/maxima/tech/addcorsb.html
If you really need the help, you can try asking here: http://forums.maxima.org/forumdisplay.php?f=15
There are plenty of Max owners in the NYC area that could probably help you out.
#1090
Thankyou for the reply. Do I really need 2002-2003 lights for those set of angel eyes you posted since they use the HID lighting system? Some of the dual halo angel eyes projectors i'm looking at say they are not to be used with a HID lighting system. I do imagine though the ones using the HID lighting system are a lot brighter?
It seems like you are looking for some eBay projectors and adding the angel eyes to them.
This may help: http://forums.maxima.org/showthread....67#post5322667
IMHO, you're better off buying the 2002-03 headlights and buying the proper angel eyes...then again, you are in NYC, so there's the chance they might get stolen.
#1092
Originally Posted by Topher3284
Thanks for the helps with that Irish and soonerfan. And irish, you dont like the way they look? Like the little pic by the way.
They look terrible on a dark maxima, IMO....but that's just my own humble opinion
#1093
Originally Posted by MetalBlueMaxx
So again, what y-pipes are available for the 2k2 and is it worth it? And what brands. Please help.
With the VQ35, go with headers, or don't waste your money.
On a 00-01, the ypipe eliminates the precats and gives better gains.
#1094
Originally Posted by irish44j
Cattman is the only ypipe you should be considering. That said, ypipe gains on 2k2 are NOT 20whp, IIRC. They are really quite minimal since they do not elimate the 2k2 precats (which is the whole point of ypipe).
#1095
Maybe you can get in for the Group Deal: http://forums.maxima.org/showthread.php?t=509149
http://www.cattman.com/
#1096
Originally Posted by Puppetmaster
Actually, for Cali spec 00-01s, an aftermarket y-pipe only gets rid of one pre-cat. There is still another pre-cat remaining on Bank 2. But even then, a Fed spec conversion to get rid of that pre-cat only nets an additional 3-4 whp.
was speaking in generalities
#1097
Thanks for the responses .
Coolmax - I read in the forum that the only tool you need to install FTSB was a torque wrench (I read 32-35 pounds). I do not have the wrench. I figured it may be easier to have someone install both the FTSB and RSB (presumably the harder of the two). Of course in a heated garage
If there isn't anybody around here, I guess I try my luck with my local mechanic.
#1099
transmission problems
ok so My dad and i have been working on my brothers 2000 maxima's transmission ( 5 spd)... we got it out and of course one of my other brothers decides he wants to take it apart when I and my dad arn't around.... so he takes it apart and he says stuff comes out and we have no clue how the stuff goes back in... but we brain storm and think we finally got it, so we get it back together and put it back into the car, well when we start the car up and when it's suposed to be in nutrual the car wants to move backwards, it wont do anything in first and it will go into and move in reverse..... So we have no idea what is goin on and i need help desperetly on this otherwise were screwed.... and does anyone have a diagram of how everything is suposed to go back into the transmission so i can see if we did something wrong!!!!!
thanks
thanks
#1100
thanks
thanks
http://phatg20.net/modules.php?name=...ownload&cid=73
#1102
I know this is a probably a dumb question or the wrong place for it (wow overload on where certain posts are supposed to go) but I am a novice when it comes to fixing things on a car. Is there someone on here in Western PA, Western MD, Panhandle WV, Northern VA that can fix the O2 sensor problem. I dont really want to go the mechanic or dealer route because I have been ripped off so many times before (not with a Maxima)
#1103
#1104
My 2000 has a problem with morning sickness. The colder it is, the harder it is to keep running. When I start it, it revs higher than usual and stays at an idle speed for 10 secs and then it idles very low and dies. I have to keep the car in neutral at stops and rev the motor so it doesn't die. After about 10 mins of driving the problem goes away.
By the way, the car, even when ice cold still runs strong under acceleration with this problem.
Anyone have any suggestions???? Im at a loss.
#1105
how come i can't open the file i saved ... and what is on these downloads??
#1106
Ive heard good things from a friend with an 04 Max about the Fujita Intake system. My question is with the same powerplant would this work in my 03 Max? Anyone tried it? Im trying to get the best performance from an intake system, but the tons of posts make my head spin lol.
#1107
Ther are honestly 100's and 100's of threads on the intakes for the 5th gens, and all provide minimal gains. Whether you use a WAI or CAI setup, they all provide very similar "gains".
#1110
the org...not what it was
Does anyone know where I could get HID fog lights? Either online, or in Northern CA?
http://doug.maxima.org/showthread.php?t=403059
http://doug.maxima.org/showthread.php?t=481336
http://doug.maxima.org/showthread.php?t=508709
#1112
Sorry, not sure if I can help you with that one.
#1115
Hey all, another question: Where can I find the smoke/black colored side marker lenses for a good price? Anyone know of a good deal?
you can actually "smoke" your stock ones. 2 layers of black followed by layer of clear. the benefit of painting the stock ones is that they will still reflect and light up the correct colors.
#1119
I have a set of Energy Suspension trailing arm bushings. I plan on doing the replacement job in the workshop at my place of employment. As far as mechanical skills go, I would rate myself as the lower end of intermediate, or just beyond that of an advanced beginner.
How long should I be setting aside for completing this job? This is assuming of course that I run into problems with removing the old bushings and installing the new ones. I work 12 hour shifts, of which I could set aside 8-9 hours total time when working a night shift. Is this going to be enough time, or should I make sure that I can keep the car in the shop for a second evening in case I encounter difficulties?
#1120
http://www.digitalpolo.com/2002Maxim...ngArmBushings/
I don't recall how long it took him, but you can pm him, his name is PoLo here on the org.
