5th Gen "I AM NEW HERE BUT HAVE A QUESTION" thread
Originally Posted by CCS2k1Max
1) Safety/tamper proof Torx. Sears has them.
2) Recommended by who, the stealer???
. Anyhow, I see no added benefit, technical or otherwise of changing the housing.
Great, that was exactly what i was thinking i could do.... thanks for your help.
I got a quick question I hope is nothing serious, but for the last month or so, that is getting coolder (I don't know if it is related or not) but after I start the car, let it warm for 2-3 mins (as always do), now after a few seconds of start moving (forward or backward) I hear this gas discharge sound just once, does not matter if the A/C was on or off, before I start the car.
Any ideas? should I worry??
Any intake will work, as long as it’s not Injen. Try Dave for all your OEM parts: 1-888-254-6060
Or, check www.pinnalcenissan.com
www.courtesyparts.com, www.thepartsbin.com for better prices than what you paid.
Thanks Matt, is a 2000 se A/T, the noise come from the engine bay, is like gas is scaping from somewhere?? it just last for maybe less than a second, the car has not lost power and as I said, the noise comes up even if A/C or heater has been off for long time ( is getting colder so I have not use A/C for at least 2 mos) no much heater either.
anyone have an input?
can someone help me out with this thread please (post #99), im still a "newb" and having troubles with my 02 recently fitted with an 01 MAF sensor
thread= http://forums.maxima.org/showthread.php?t=258878&page=3
thank you in advance!
have a question....my friend jus got some PIAA fogs that i want and he is selling them to me.....is there a way i can tell if there real???? or is there not such a thing as fack PIAA'a???? thanx
So my wife was driving my car today. She was talking to me on the phone and asked why the TCS Off light came on suddenly. A minute or two later the airbag light came on and she braked to pull over and see what was going on. The car stalled and died, and the battery was essentially dead. I had to drive out and give her a jump. I've had a 420 code for a while now but am not sure if this was related. Gonna take it in this week to see what's going on. Awesome.
I went up to the mountains today with some passengers in my maxima. I think the stuff in my trunk and the all passengers summed up to about 1000 lbs. I went through a dip and a bump and I heard my right back tire scraped the body from the inside. My shocks and springs are OEM and I have a slightly bigger tires. So my questions is isn't there a limiter or something that protects from this kind of insidents???
My shocks are pretty good (stiff).
I was thinking about dropping my maxima about an inch or two front and back but now I think I should reconsider? I was thinking about getting and Eibach lowering springs and just replace the springs. Is there more adjustments needs to be done?
Any experts advises are greatly appreciated. (I'm loving this forum so far... on the other hand it's really tempting to do lots of stuff to my car but I don't have all that expertise). Thanks.
1) sounds like your tire just rubbed against something; not surprising, considering the extra weight + bigger tires
2) your suspension is a mechanical system. There are no "limiters" that can prevent your springs from compressing too much. However, you could get stiffer shocks (aka struts) that resists the spring compression and therefore make it less likely to bottom out like you did.
3) if you get lowering springs, the struts have to work a lot harder. you will probably want to get aftermarket struts. check out housecor's site for some good info on that stuff.
4) check out the sticky about tires/wheels.. here is a calculator that tells you the overall size of your tires with different size rims and tires.. they key is to have an overall diameter that is as close as possible to the original tires.
5) there is a ton of stuff on this site about suspension, especially lowering springs. go to google and type in "lowering springs site:maxima.org" to search for 'lowering springs'. try different searches. If a link is broken, or directs you to the wrong thread, manually change the part of the link that says "showthread" to say "oldthread".
http://www.jic-magic.com/ViewProduct...49&CarMakeID=7
Is this what I need? Will this help at all?
Front Suspension Question
I just installed some G35 18x8 wheels with 225/40/18 tires in the front and 235/40/18 in the rear on my '01 SE and they look great however I do not like the wheel gap it left. The rear gap is tolerable but the front is painfull to look at.
I see some people on these forums swapped out only their front suspension and left he rears stock. What kinda of issues or performance hit can I expect if I choose to only upgrade/lower the front suspension? I do not run the car on a track and just enjoy "spirited" freeway driving on the smooth roads of SoCal.
I am planning on going with the illumina/eibach combo if this is feasable on the front. If not it's going on all 4 corners.
Thanks!
Thanks!
I saw these Headers and y-pipe on ebay for those of you who have y pipes and headers how does the construction of this 1 look.
http://cgi.ebay.com/ebaymotors/95-01...spagenameZWDVW
Thanks!
Thanks!
Eibach/Illuminas are a good choice. I would go all around and not do 'just the front'.
I came accross this Bump Stopper Rubber:
I have ~4.5% bigger tires. I have 6th gen 18 inch chrome that's why I've been thinking about getting stronger suspension and brakes.
You know, I figured it was alternator as well, but what's weird is that it started fine when I got home, including this morning and evening. I was always under the assumption that an alternator either worked or didn't.
I lifted my car and looked under the rear fender and it looks like the tire scraped it.
Thanks for your reply. I really do appreciate it. I will continue on researching. I've been studying my maxima for the last couple of months
ok changed my alternator/battery x2/checked for a parasitic drain and well cant make heads or tails of what im looking for. ammeter shows a drain when everything is off bat reads 13-14 alone, hooked up it starts going down but fast from 12-10 dipping into 8-9 from here im not sure what else to do. any help will be appreciated.
I need to replace my catalytic converter how do i know which cat is right for my car and what are my options other tha random tech. And if anyone knows the price of installation when you had yours replaced.
hey guys. iv tried the search engine. all the links are whacked and have spent the last week searching our website and many others and i still can not find a complete how to write up on the 02-03 HID conversion. any help?
http://forums.maxima.org/showthread.php?t=541117
Cattman sells one as well, look for his threads in the Group Deals forum. Other than that, you'd have to look on eBay for a generic Maxima "hi-flow" cat (make sure you're not just buying a resonated test pipe though, unless that's what you want) or through the 5th Gen Classifieds to see if anyone is getting rid of theirs.
I guess you could also check junkyards to see if you can find one, although, they are technically not allowed to resell junked emissions parts, IIRC.
Design of those is just like the stock shorty headers, less the pre-cats. Look for the other threads on eBay headers. The quality usually isn't very good either, based on other peoples experience with eBay headers. The only headers I might consider getting off eBay are OBX headers, but even then, some Orgers have had issues with certain batches of those.
I used the K&N RD3870 on my Berk:
http://www.google.com/products?q=K%2...firefox-a&um=1
