Door adjustment?
Old Aug 16, 2006 | 05:23 PM
irish44j's Avatar
retired moderator
Door adjustment?
Can't seem to find my FSM CD-ROM. I know it's probably pretty simple, but has anyone adjusted their door to close more smoothly?
My driver's door is sagging a bit so it hits the striker pretty hard and I frequently have to re-close it when I get in, since it doesn't close smoothly. Is it easier to adjust the door hinge bolts (or possible, for that matter) or just adjust the striker itself?
thanks in advance.
Old Aug 16, 2006 | 05:25 PM
LA02MAX's Avatar
mine is doing this as well, and from what i can see, the hinge is just not tight enough...i just keep on forgetting to tighten it up (unless of course I'm somewhere that I don't have the means to do so )
Old Aug 16, 2006 | 05:39 PM
SoonerFan's Avatar
Cletus
you can adjust the striker...i had to do it on my old car
Old Aug 16, 2006 | 05:41 PM
irish44j's Avatar
retired moderator
why don't you come over and fix it for me, player.
Maybe I'll give you a stage 1 LTB now that I have a stage 2 sitting here.
btw, sorry to hear about your loss...if you're not at work on Friday, give me a call. I'll be around the house doing a few car projects.
Old Aug 16, 2006 | 05:47 PM
Stardust's Avatar
F---ing Kangaroos
See if this helps
http://www.yousendit.com/transfer.ph...DDD6FF276A8500
Old Aug 16, 2006 | 05:52 PM
irish44j's Avatar
retired moderator
many thanks...
I'm still a bit p1ssed that I can't find where I put my FSB CD
Old Aug 16, 2006 | 06:24 PM
RA030726's Avatar
I'm nutty for Nissans
The problem is most likely the brass bushings in the hinge pins. They wear out and cause the door to fall when opened. Dont bother moving the striker down because then the bottom of the door will hit the rocker panel and will have misaligned gaps when closed. If you try and adjust it on the other end you could end up chipping the paint when the door swings out. If by some luck you get it adjusted right and it looks OK and shuts OK, it will come back sagging soon enough. Just buy new/used hinges and install them.
Old Aug 16, 2006 | 06:28 PM
Kevlo911's Avatar
Kevlo for President
www.phatg20.com
download fsm
Old Aug 16, 2006 | 10:07 PM
ctrent86's Avatar
I have this problem Irish. If you dont mind doing a walk thru it would be appreciated.
Old Aug 17, 2006 | 06:57 PM
nexus_7's Avatar
new hinges.
I have had them sitting here for about a year now....kind of got a new primary car, so I have gotten Maxima lazy.
Greg
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
BobTX10
Oct 7, 2015 08:43 AM
leatherneck
Sep 30, 2015 09:16 PM
