OEM Electrical System Upgrade II of II: BIG THREE, Grounding Kit Big Brother (HOW-TO)
Old Sep 20, 2006 | 12:00 PM
  #41
XyNoix-HIC's Avatar
hey what group size optima is that?
and if your running your stuff without turning on the car is a blue top better than a yellow top?
Old Sep 25, 2006 | 12:38 PM
  #42
Memphis2k1's Avatar
I'm a n00b so go easy. Do we disconnect the factory power connector completely and replace it with the 1/0? Connect the wire directly to the new fuse then to the alternator?
What gauge is the factory sized cable?
What are those two other wires that Metal has connected to the side post terminal on the battery? Relevant to this?
I'm about to install a new alternator in my ride.
Old Sep 25, 2006 | 01:34 PM
  #43
Metal Maxima's Avatar
SHIFT_om nom nom nom
Yes, this is correct.
I would not rate it higher than 8AWG.
I think you might be referring to the OEM power leads.
Nice! If you go for an alternator rated at 150 - 200A, you won't even need to bother doing this upgrade.
Old Sep 25, 2006 | 01:35 PM
  #44
Originally Posted by D-Bo
I have the HPM terminal with the voltmeter and was thinking about te display being upside down. What are your thoughts Dan? I would rather have it oriented so it's readable from the front. Did it not make a difference or was that easier for routing the cables?
You got it, it was simply easier to orient the cables this way. I could probably remove the LED display from the terminal and reinstall it to read the other way...
Old Sep 25, 2006 | 03:30 PM
  #45
misiek's Avatar
metals setup looks sicks as is and i wish i could have something like that...
i have done something similar on my car and the first thing i did was turn the battery around 180 this way the digital terminal sits evenly on the battery and at the same it faces the front... once i had that placed i ran the wires to fit this setup... worked out pretty good and the wire lengths were only 4-6inches different then metals.... just my .02
Old Apr 22, 2007 | 08:39 PM
  #46
VQuick's Avatar
Chassis Freak
Bumping a great thread. What's the reasoning behind the fuse on the alternator to battery positive connection? If I used 4AWG wire for that I would want a smaller fuse, right? 100 amp?
Also, you said your third connection was engine block to chassis but it looks to me like you connected it to the timing chain cover, not the block. Is that good enough or is there a reason to actually connect to the block?
Old Apr 23, 2007 | 02:58 AM
  #47
Jess's Avatar
SHIFT_In2D
Another bump for this thread since I will be doing the same mod to my car next month. Now I just need to find some more 1/0 awg wire for this!
Old Apr 23, 2007 | 04:38 AM
  #48
brusk's Avatar
Would you want the fuse to match the wire or the alternator. I would think you would want to match the lower of the two. This grounding and big 3 was actually less wired than most grounding kits I've seen. Granted I used to drive a honda but the recommendation there was always a star pattern of intake, exhaust, frame connected to one location on the block and then that going to the battery or some variety of that but the intake mani and exhaust were always included in that. Never understook the exhaust but I've seen several cars stock that had the exhaust grounded.
Old Nov 20, 2007 | 11:25 PM
  #49
eK9aT10pSi's Avatar
up for pix!
Old Sep 29, 2009 | 12:13 PM
  #50
Skunk83's Avatar
cant see the pics
Old Sep 29, 2009 | 02:42 PM
  #51
This one will be updated with new pics this weekend. I don't know where my pics are, but I will be redoing this for another member on Friday...so...sit tight...
Old Oct 3, 2009 | 06:37 PM
  #52
Skunk83's Avatar
Sweeet!
Slamrod
Apr 10, 2016 05:24 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
subwayhello
Aug 23, 2015 05:18 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
