need some advice on this test
Old Aug 29, 2006 | 10:45 AM
djbrown's Avatar
-Da MTL Brown Boi-
i got my car to canadian tire and they did the compression test on the engine.
the result are
1: 132
2: 132
3: 132
4: 130
5: 132
6: 132
he said its ok
but i remember with my 98 maxima the psi were higher somewhere around 175
so can u guys tell me if its good or the engine is bout to die?
thx
Old Aug 29, 2006 | 11:19 AM
igzy's Avatar
I Know Kwaliti
Originally Posted by djbrown
i got my car to canadian tire ...
There lies your first mistake
How many k's does it have? Why did you have the test done?
Old Aug 29, 2006 | 11:21 AM
Hoooper
if youre in canada is that still PSI? cause for PSI that sounds pretty low
Old Aug 29, 2006 | 11:24 AM
FriscoMaxima's Avatar
what do you think it's in BARs?
Old Aug 29, 2006 | 11:42 AM
Hoooper
i think hes in canada and theres more than just BARs smarts. Kilopascals? im sure theres others. nice job posting in a thread and not relating to the subject.
Old Aug 29, 2006 | 11:51 AM
igzy's Avatar
I Know Kwaliti
According to FSM, VQ30DE standard is 185, minimum 142 psi...
Considering that all cyl's are almost the same and the expertise at CT, I would go and get a second measurement elsewhere... It could be that all rings are equally worn out but I'd measure it again before making any life-changing decisions...
Old Aug 29, 2006 | 12:09 PM
djbrown's Avatar
-Da MTL Brown Boi-
sorry for posting it at wrong place !
its in psi and it says dynamic compression test results
i went to nissan dealer and another place with the results and after looking at them the both places said its good
car has 140 000 km so around 88000 miles on it
thanks
Old Aug 29, 2006 | 02:35 PM
Hoooper
no, its not good, neither place knows what theyre talking about. they think its ok because based on what most people look at, which is numbers as close to each other as posible, its great. but we know that that is way lower than normal so go get another test and if its the same come back and ask again. if its really 130-132 then youre compression is really low, possibly in the 8s and thats bad for a vq30
Old Aug 29, 2006 | 07:15 PM
igzy's Avatar
I Know Kwaliti
thanks
No prob I think your engine is likely OK but if you want to be safe take it to someone that knows how to do it properly...
Mahmuth
Aug 16, 2024 08:23 PM
tarun900
19
Dec 20, 2021 06:57 PM
gigabyte
Jan 6, 2017 06:05 PM
Pnjboyzz
Nov 16, 2015 12:27 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
