What don't my headlamps and foglights match even though they're both 6000k?
Old Sep 30, 2006 | 04:25 PM
spark plugs.'s Avatar
Hi, I drive a Maxima.
i don't know if you can tell in the pictures, but the headlamps look MUCH bluer than the foglights.
Old Sep 30, 2006 | 04:26 PM
oh, and are my foglights properly aimed? i'm not sure where to aim them
Old Sep 30, 2006 | 04:34 PM
808MAX-SPEC's Avatar
What brand of bulbs u got? Maybe your HIDs need time to warm up.
Old Sep 30, 2006 | 04:42 PM
Helios, from the group buy.
Old Sep 30, 2006 | 05:05 PM
ShIft_uR FacE's Avatar
One is an HID reflector and the other is halogen...only thing i can think of besides the bulb thing.
Old Sep 30, 2006 | 05:08 PM
OutMaxxed's Avatar
i think its because the housing of the fogs are smaller. What im saying is maybe you should have gotten a 7 or even 8 k for the fogs if you wanted to match
Old Sep 30, 2006 | 05:52 PM
hm...that could be a reason. tomorrow, i might try switching back to the oem 4300k to see if it's a closer match.
Old Sep 30, 2006 | 06:06 PM
00MaxSE's Avatar
Pointy Elbows
Do the headlight bulbs have the masking on them or are they like D2S bulbs?
Looks good btw. My 6000k fogs look bluish, like your headlights.
Old Sep 30, 2006 | 06:55 PM
djbonsu's Avatar
spark plugs,
my headlight/foglight combo is exactly the same.....it bothered me at first however, i kinda got used to it plus i get alot of compliments on how nice and bright the setup is. i was actually going to sell the helios low beams and probably get some phillips utiliton 6k bulbs and see if there is a difference. if not, my only guess would be the two different ballasts.
BTW: yur car looks like a clone of mine..lol
Old Sep 30, 2006 | 08:42 PM
jokerk01's Avatar
Are you sure that they are 6000k?
I have the same problem. when i put the HID in the fogs with what I thought was 6000k I noticed that they did not match. I did a little research and found out that I was sent the 8000k instead. I also plan on putting back the 4300k in to see if it would look any better.
Old Oct 1, 2006 | 12:56 AM
n3985's Avatar
大陆弟弟
HID bulbs color shift people, wait a few days. Or simply walk a few feet away from the car, you'll notice the light does match.
Old Oct 1, 2006 | 05:55 AM
no masking that i've noticed.
Old Oct 1, 2006 | 05:56 AM
Originally Posted by djbonsu
spark plugs,
would the ballasts really make a difference?
helios kit or another?
Old Oct 1, 2006 | 07:26 AM
spark plugs,
btw: do you have the hp evo's, too? what'd you do about hte center caps?
Old Oct 1, 2006 | 08:54 AM
IWNTMORHP!!'s Avatar
CAN YOU PUT IT ON THE WALL?
I have two takes on this:
1st...have you ever looked at the glass lens on the fogs? it has little rib's or diffusing angles in the glass and the glass isn't perfectly clear-its somewhat frosted...your headlight is perfectly clear and the reflecting surfaces are perfectly polished so there is little degredation in the quality or color of the light. fog lights are supposed to diffuse light and headlights are supposed to be a direct beam (more targeted)
2nd...as mentioned before there is a difference in height and angles...if you were at the same angle and in the focal distances for ea light, my guess is that the color will look the same
Old Oct 1, 2006 | 09:28 AM
jeepik's Avatar
mine match perfectly, but maybe cuz they are the same brand???
both the headlights and the fogs are prolumen
Old Oct 1, 2006 | 10:27 AM
both my headlights and foglights were bought at the same time through the same retailer and are of the same brand, "helios/xenon storm"
Old Oct 1, 2006 | 10:34 AM
xnyc's Avatar
same as my situation. i was told that in order to make the fogs match the 6000k d2r, the fogs would have to be 8000k. at first i thought there was a labeling mistake and i messaged maximabest but then i found out from a friend that it was because the headlights and foglights are different reflection. the fogs get diffused and watnot
Old Oct 1, 2006 | 10:42 AM
00MaxSE's Avatar
Pointy Elbows
Didn't think so.
rnb754
Sep 14, 2015 11:39 PM
minsbang
Sep 11, 2015 08:48 PM
Violator
Sep 9, 2015 10:14 AM
Hdnseek
Sep 9, 2015 05:55 AM
TheMafia
Sep 4, 2015 08:26 AM
