Performace clutch
Old Oct 7, 2006 | 03:33 PM
maxspeed96CT's Avatar
The original VQ...
Performace clutch
I wanna hear your opinions and reviews on some of the performance cltuches out there or the 02-03 max.
Post up what you got and how you like it and etc.
Let me know what out there for performace clutches cause i didnt find much for the 02-03 .
I had a ACT stage 1 on my 96 maxima and i loved it, even tho the pedal was alittle stiff.
I noticed and read a few ppl have spec but im not fimiliar with the brand and how reliable it is .
Old Oct 7, 2006 | 06:16 PM
The original VQ...
so , can anyone help me out with my clutch situation?
Old Oct 7, 2006 | 06:23 PM
irish44j's Avatar
retired moderator
unless you are running serious power (FI), the best clutch is OEM. Better driveablility, and has good enough grip for Maximas under 300whp imo. I autocross (very hard on the clutch) and drive in alot of stop and go...hard on the clutch. OEM ftw...
I would just go OEM, and get a lightened flywheel while you're at it.
Old Oct 7, 2006 | 06:41 PM
The original VQ...
well im prolly going to have only full bolt ons, headers catback etc, only thing is on my 96 stock clutches only lasted me about 5 k, my act lasted 15 and i sold the car with it gripping hard.
Does anyone know if the 350z/g35 clutch is the same, i cant realy find much out there for the 2k2....
Old Oct 7, 2006 | 06:56 PM
irish44j's Avatar
retired moderator
dude...wtf are you doing that your clutches only last 5K miles????? mine is still the original going strong at 110K
if you're that hard on a clutch, maybe you should start looking into getting an automatic
Old Oct 7, 2006 | 07:05 PM
The original VQ...
well thats when i was when i was younger and alot stupider, but ya my 96 had about 4 clutches within about 50k...
I dont beat on my car that much but there was a 330ci i was having fun with on the highway today and i noticed it slipped when i shifted to 3rd, then on my way home i did a 1st to 2nd shift tocheck and there was some very noticable slipage, no tire chirping at all.....
Im gona take it easy for the next few hundred miles and hope it maybe it will get alil better???
I think your prolly right with going with a stock one , i found a ACT kit for about 500 ,and other kits are around the same price range, more than im looking to spend on a clutch
Old Oct 7, 2006 | 07:12 PM
irish44j's Avatar
retired moderator
well thats when i was when i was younger and alot stupider, but ya my 96 had about 4 clutches withing about 50k...
a few things to think about:
1. is your clutch pedal adjusted correctly so it is completely disengaging the clutch when pressed?
2. are you "riding" the clutch without noticing? I sometimes find myself doing that when cruising...using the clutch as a "dead pedal" and applying light pressure until i catch myself.
The onlyreason I ask is that even if you were doing dead-drops all over the place, that should not cause a clutch to go bad so quickly. It seems that one of the two above cases is likely true. Just some food for thought.
Old Oct 7, 2006 | 07:17 PM
DrKlop's Avatar
Driving is the next best thing
As far as I know OEM clutch would be your best bet. Don't have anything to prove my point, but I've been doing a small research about available clutched a few months ago and I came to conclusion that, if you are N/A, OEM clutch will be just fine...
Irish, just curious, are you riding the clutch in the corners when you auto-x? From my experience auto-x is not hard on the clutch at all...
Old Oct 7, 2006 | 07:28 PM
irish44j's Avatar
retired moderator
I feather it occasionally. to help modulate my front end grip....but no, small courses are usually not hard on the clutch. If you're running in a course requiring a 1-2-1 or 3-2-3 shifting because of the speed of the course, though, it can be hard on a clutch IMO.
Old Oct 7, 2006 | 07:40 PM
DrKlop's Avatar
true, such shifts can be hard on the clutch. Thanks god local SCCA branches design courses in such a way that they don't require 2-1 downshifting. Well, maybe it's because I participated in only three events so far.
Old Oct 7, 2006 | 08:27 PM
Derrick2k2SE's Avatar
The 350Z clutch will work with the 3.5 liter Maxima. A flywheel for a 350Z won't work without modification. Fidanza makes a flywheel for our cars. It's a very nice piece. If you do go aftermarket clutch then just search for a 350Z clutch.
Irish is right about the stock clutch being strong. If you're planning all the boltons and drag radials for the strip you might consider a stage 1 or 2. Something with a bit more clamping force and a kevlar solid disk. If not then I'd just do the Fidanza 15 pound flywheel.
I wouldn't do a "sprung" clutch disk with the stock dual mass flywheel. I got a lot of chatter from that setup. When I went to the Fidanza the chatter went away.
Old Oct 7, 2006 | 08:55 PM
vq356sp's Avatar
El Mas Noob Del Org.
You will be fine with OEM clutch, I have full bolt ons and a 75 shot of nitrous on my OEM 02 clutch with 80,000 miles and to me that says something about our clutches. 02-03 clutch =
Old Oct 8, 2006 | 05:08 AM
The original VQ...
werd oem sounds like it will bve good
something tells me the clutch in my car isnt oem, it felt like new when i got the car a few weeks ago, i have a feeling its a cheap autozone clutch or something, dunno.
Irish i didnt think our car had a clutch adjustment ?? please tell me more
Old Oct 8, 2006 | 06:04 AM
The pedal can be adjusted for travel and height. If it's out of adjustment the clutch may not be fully disengaging which will cause it to fail sooner. The clutch itself has no adjustment but the pedal has to be right. There are several threads on how to do it.
Old Oct 8, 2006 | 12:55 PM
The original VQ...
k ill search it up , post up the threads if you got um.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
