2k2 vias
Old Nov 6, 2006 | 06:14 PM
  #41
inspiredbykev's Avatar
You should thank my D***
no but I will def do it on wed.
Behind the three bolts what would be effecting my vias if there is vacuum coming out of the intake manifold. It seems as something is not switching the soldenoid valve.
Old Nov 6, 2006 | 06:20 PM
  #42
NmexMAX's Avatar
dot dot dot ...
Check the pins of the VIAS connector.
Old Jul 29, 2008 | 10:10 AM
  #43
2002 Maxima SE's Avatar
I think I have the same problem. VIAS is open all the time, never closes.
I removed the VIAS to check on the screws. The "flap" opens and closes when moving the arm. Mine had a small groove cut into the stopper arm on the outside of the plate, where the closing action had caused it to hit over and over. So it did work at some point.
inspiredbykev ,
Did you find the problem with yours?
Old Jul 29, 2008 | 12:17 PM
  #44
NmexMAX's Avatar
dot dot dot ...
By checking the pins with the values mentioned in the FSM under certain conditions, you could rule out the actuator.
Another area to look at would be the canister (leaks) And yet another, a mechanical blockage/obstruction.
TallTom
57
Oct 14, 2025 05:16 PM
trailer54
Nitrous
Nov 18, 2015 07:44 PM
Turbonut
46
Oct 21, 2015 08:28 PM
King_Ten_Ahead
Sep 27, 2015 02:24 PM
Dasmith
Sep 23, 2015 08:28 PM
