Which Cat?
Old Oct 31, 2006 | 01:23 PM
Cdoc's Avatar
Which Cat?
I got a P0430 code but I'm confused as to which Cat this is referring to. I have a 2000 cali spec. The dealer said it is the main 3-way cat. Is that correct?
Old Nov 1, 2006 | 06:47 AM
Bborges's Avatar
Dunno... but there is a thread on that going on for more details...
Later
Old Nov 1, 2006 | 07:01 AM
absoundlab
P0430 - Catalyst System Efficiency Below Threshold (Bank 2)
Old Nov 1, 2006 | 07:14 AM
Puppetmaster's Avatar
Yup, front bank, like the diagram says.
Old Nov 1, 2006 | 08:00 AM
Cdoc's Avatar
Thanks for the info! That is the one the Dealer specified. (they want $1,000 but my local shop will do it for $300)
That diagram is extremely helpfult but I find it a bit hard to read. Even when I blew it up it wasn't that easy to read. Do you have a larger version of that diagram around that you could send me?
Thanks again!
Old Nov 1, 2006 | 08:07 AM
absoundlab
go here http://maxima.theowensfamily.com/tsb/NTB02-051a.pdf
Old Nov 1, 2006 | 11:30 AM
Max_Gator's Avatar
Unless the light really bothers you, I wouldn't spend any money to fix it.
Heck, many of us 5th geners are voluntarily running without pre-cats.
Old Nov 1, 2006 | 01:37 PM
Cdoc's Avatar
The only thing that bothers me is that PA won't pass my car through inspection w/ the light on. It is incredibly frustrating to me to have to spend money to fix a car that runs fine.
Old Nov 1, 2006 | 01:43 PM
Cdoc's Avatar
Also, my mechanic was confused about what I wanted him to replace. He now thinks the $1,000 quote from the dealer was a good price!!
I'm thinking of replacing the O2 sensors on each side of the pre cat to see if that gets rid of the code. It is a $200 gamble but it might be worth a shot and I'm also concerned that if I get the cat replaced, the light will come back on and the dealer will say "the o2 sensors were bad too".
I figure I have to fix it either way. Even if I wanted to get rid of it, I can't sell a car that won't pass inspection.
I'm actually kind of proud of the fact that the car is 7 yrs old (I bought in '99) and this is the first time I had to take it to the dealer (w/ a little help from the .org).
Old Nov 1, 2006 | 11:51 PM
Yayomax's Avatar
still brewin'
Sorry, won't help. Been there. Done that. Here, catch up on some 'ol readin:
http://forums.maxima.org/showthread.php?t=497967
Anyways, help from the .org 7 years ago. Then your sort of an old school newbie.
Old Nov 3, 2006 | 08:05 AM
Max_Gator's Avatar
If passing emissions is the problem, I would go buy a code reader for like 60 bucks (I think) that enables you to clear the light. Or go by autozone and have them clear it for free prior to driving to inspection.
I've had the code for years since I have headers - when I clear it, it sometimes stays off for weeks, sometimes for days. As long as you go to the inspection after the car has warmed up, you should pass. The pre-cats are only there to meet emissions from the time the car is started until the main cat gets warmed up.
Old Nov 9, 2006 | 03:05 PM
Cdoc's Avatar
My Max had 2 codes: P0420 and P0430. P0420 requires an ECU flash. P0430 is the expensive one.
In an attempt to save $ I replaced the O2 sensor after the bank 2 Cat last weekend. It usually takes my car about 320 miles to re-register a code after a reset. Today I got the SES light. But when I checked it I only had the P0420 code!!!
I know I can get a P0430 code anytime now but I think it is a good sign that it didn't show up right away. Maybe I can just get away w/ the O2 sensor.
Old Nov 14, 2006 | 06:36 PM
Cdoc's Avatar
F F F F F F!!!
The P0430 code came back! I HATE THIS CAR!!!
Old Nov 14, 2006 | 07:09 PM
Y2KMaxGXE-R's Avatar
F F F F F F!!!
it is a pain isnt it
go get yourself a $30 o2 sensor sim and install it yourself...like I am going to do this weekend.
Old Dec 29, 2006 | 06:01 AM
pdtass's Avatar
I had a problem with the rear bank precat and the dealer replaced it along with the main cat and piping in between. The car has more power. My thinking is that the failing precat may have been causing a restriction of exhaust flow otherwise I have no idea why the car has more power.
Old Dec 29, 2006 | 06:17 AM
SoonerFan's Avatar
Cletus
clearing the code < actually fixing the problem
Old Dec 29, 2006 | 06:20 AM
Pugman's Avatar
I believe that code is B2 Pre-Cat.
Old Dec 29, 2006 | 07:04 AM
SoonerFan's Avatar
Cletus
thats already been determined
maxinout93
Oct 31, 2015 02:04 AM
lrb6805
Sep 18, 2015 07:07 PM
Justin Kroll
Sep 2, 2015 11:06 AM
