Cheap mod....
Old Nov 1, 2006 | 08:55 PM
makdaddy386's Avatar
Cheap mod....
Before I say anything, full credit goes to irish for this one. Pretty much carbon copied what he did with a few things different. I removed the entire main ground line that runs from the battery terminal and replaced it making all of my contacts below the battery at the first main ground point as pictured. Anyways I was not posting to show off but to give an alternate method for connecting the grounds to the battery. Just a different way of doing it. This mod was pretty nice too seeing that all the supplies were free via work (car audio has its perks sometimes). I think the total cost was like $2.67 for the shrink wrap. Cheapest mod on the list yet.
Old Nov 1, 2006 | 09:17 PM
Stardust's Avatar
F---ing Kangaroos
What gauge wire did you use?
Old Nov 1, 2006 | 09:28 PM
4 Guage/Gold Ring Terminals/Shrink wrap
Old Nov 2, 2006 | 06:30 AM
NYMAX02's Avatar
Looks good is that a ground kit ?
Old Nov 2, 2006 | 08:12 AM
mist max2000's Avatar
looks good,.. notice any difference before and after?
Old Nov 2, 2006 | 08:49 AM
ktranne's Avatar
NOOB
that looks real nice.
Old Nov 2, 2006 | 09:00 AM
vq356sp's Avatar
El Mas Noob Del Org.
What he said. Any difference?
Old Nov 2, 2006 | 09:08 AM
ghostmax301's Avatar
what he said^
bump
Old Nov 2, 2006 | 10:01 AM
yea....the powerband seemed a tad bit smoother. rev's seem a little bit quicker. Next I will be running a 12+ wire to the alternator. But for the money someone would spend making it themselves I would say it's worth it.
Old Nov 2, 2006 | 04:47 PM
djfrestyl's Avatar
Suspension Yoda
Nice job, but blue makes it look
Get some wire loom
Old Nov 2, 2006 | 06:29 PM
sanjeeve's Avatar
how much did it cost you?
Old Nov 2, 2006 | 07:52 PM
Matt93SE's Avatar
STFU n00b!
so what does the top wire in this pic connect to?
Old Nov 2, 2006 | 11:20 PM
Get some wire loom
Agreed...I said the same thing as I was doing the install. On the other hand, wire loom just looks cheap. The wiring was free and the blue was better than red.
Cost = Freebie. I do car audio for work so the wiring/ring terminals were free. The shrink wrap was the only expense and it was only $2 and change.
I'm not really sure the exact name for it but it's a bracket attached to the intake manifold. As stated above I followed Irish's lead. Sorry...
Old Nov 3, 2006 | 09:43 PM
igzy's Avatar
I Know Kwaliti
This adds about 2 and red wiring would give you 2.5...
lbs
Old Nov 4, 2006 | 03:51 PM
trigger005's Avatar
ur explination is confusing as fawk
from what i could make out... all u changed were 2 lines that originally went 2 the neg batt terminal are now grounded below the battery as shown in the 2nd pic?
how is this any better again?
u did a really clean job on the HG
Old Nov 4, 2006 | 04:29 PM
That wasn't an explanation on how to do the install. I was giving people an idea of a different way to do one aspect of the install. In the how-to by Irish a couple ground contacts were made on the actual neg. terminal of the battery. Instead I ran a new cable from the neg. terminal down to the spot you see below the airbox. This is were my contacts were made. Also I removed the entire wire that runs from the terminal to the inline ground below the batt. to the engine and replaced it with my 4 guage. How is that not better? I think it looks cleaner as well. I did it on MY car and threw the pics up for others to see another way of doing it...period. My install is no better than Irish's, just different.
-Kevin
Old Nov 5, 2006 | 06:31 AM
vinny's Avatar
looks good, have an 1000 watt amp and a 12 inch subwoofer in my car will this setup help to put less strain on the alternator
Old Nov 5, 2006 | 07:19 AM
Decoy036SPD's Avatar
on my old car I bought high temperature 4 gauge wire (30 feet) for 18 dollars. serious ****ing wire. I had to use bolt cutters just to ****ing strip the damn wire to get the ring terminals on. good job on your work though; looks professional.
Pnjboyzz
Oct 7, 2015 10:47 PM
londonflu
40
Sep 25, 2015 09:11 AM
worldwiderecognized
Sep 24, 2015 06:56 PM
pears
Sep 18, 2015 05:25 AM
