LTB 2 Install Advice/Help
I am planning on installing a LTB 2 from blemco and have heard it can be a bit difficult without access to a lift.
I really wanted to do this, is it as hard as it seems?
I don't have a drop or any other suspension modifications, starting with this and the RSB.
Thanks for the input
car is a 2003
car is a 2003
Originally Posted by machinehead131
where should i jack on the front mound and let the car sit on the stands?
you will probably need liquid wrench for the bolts...i know i did.
the control front control arm bolts were a pita to get back on mine. i had to use two sockets. one was put on one bolt, then the other on the other bolt. then the whole ltb mounted. i could not get one of the sockets on, if the ltb was in place.
MaxLife17
Jun 27, 2019 01:37 PM
