Strange Engine Noise
Old Nov 10, 2006 | 11:25 AM
BrazilianMax's Avatar
Hi Folks,
I just started noticing sort of a friction noise
coming from under the hood. Very loud, even
at Idle rpm.
Sounds just like when you apply the brakes and
you have awfully worn-out brake pads, you know..
that metal rubbing metal noise.
Some times you step hard on the gas and it
goes away. Any ideas?
Regards
BrazilianMax
Old Nov 11, 2006 | 02:48 AM
SilverGLE's Avatar
I'm watching you, boy...
Can you smell burning rubber or see smoke? It could be a belt rubbing. Or maybe something with your alternator. Does it happen with the heat and/or AC on? Does it change pitch with RPM's?
Old Nov 11, 2006 | 07:40 AM
no smoke
no, my friend
No burning rubber smell or smoke at all. It happens
with or without the A/C on. The sound`s pitch changes
only slightly with the RPM`s, but yes, it changes.
Thanks for your help.
Old Nov 11, 2006 | 07:51 AM
1996blackmax's Avatar
Have you checked the pulley?
Old Nov 11, 2006 | 02:50 PM
snipes's Avatar
Engine noise
Remove the belt(s) from your engine and start it up long enough
to see if the sound has gone away. It it's gone, you can spin the various
pulleys by hand to see if one feels like it's not smooth.
Good luck,
SJ
Old Nov 11, 2006 | 02:54 PM
SoonerFan's Avatar
Cletus
sounds to me like a power steering pump ceasing up
Old Nov 11, 2006 | 04:39 PM
Today the noise started the moment I started the car.
Then it stopped inmediately when the A/C was turned on.
Regards,
BrazilianMax
Old Nov 12, 2006 | 07:16 PM
NisTech's Avatar
Get a long screwdriver and with engine on put it around different pulleys. Listen at the other end with your ear.Loudest one will be a lot louder than the rest.
You might have diagnosed it yourself though
Bonka
Sep 14, 2015 11:18 PM
thenewguyy
Sep 12, 2015 11:12 AM
ballerchris510
Sep 11, 2015 05:29 PM
jfl330
Sep 4, 2015 01:44 PM
